That was changed over a year ago with the rollout of the RRDB v2.0Whats the deal with no more primary CCs and alternates... are they all control now?
Yeah, not sure tbh I saw it with BTConfig last night, so maybe they're close? I'll check the cc freq tonight see if I get anythingWhat’s the 4188905 for and did Avon do radio testing at all
Yes, they all (RED) can be a Control ChannelWhats the deal with no more primary CCs and alternates... are they all control now?
Double check your programming.how can i listen to the new CSP system with my BCD996p2
i am in connecticut for a few months and i am 6 mintues from bridgewater ct and 15 mintues from washington ct and 10 mintues away from roxbury ctDouble check your programming.
Are you sure you're in range?
You might not be close enough.
Connecticut Land Mobile Radio Network (CLMRN) Trunking System, Statewide, Connecticut
Connecticut Land Mobile Radio Network (CLMRN) Trunking System Profilewww.radioreference.com
Edit:
It looks like you are at least 2 hours away if you are in Warren, NY
Great!i am in connecticut for a few months and i am 6 mintues from bridgewater ct and 15 mintues from washington ct a
what kind do antenna do you useGreat!
So you should have no problems with your 996P2. Mine works great on the system.
Just program it in. Good luck!
i programmed it with freescan andall TGs you want to hear are programmed, and not set to L/O?
what do you program with?
I use a Discone mounted on the chimney.what kind do antenna do you use
But you shouldn't need much of an antenna. Troops B and L are closest to you.
I wonder if it has something to do with the lack of new low band equipment. As it goes bad they're running out of replacement pieces in the 33mhz portion of the band.Tolland radio IDs (142***) testing in East Windsor today on 8511. Maybe TN is finally switching them over from the old LTR system, or coverage testing for mutual aid?
As I see you don’t have what I have checked on mine
