Cheeseburgers
- Joined
- Jan 9, 2018
- Messages
- 632
You think I could it it from Avon?
Is the active Control Channel still 853.6125?Have they turned on the Hartland site, getting a much better signal from the Troop B simulcast cell
OK yes thank you for the confirmation Chris. Still no joy down here on the G5. I have all of the control channels in as conventional FM just to zero in on them with the Yagi's. Still no difference since the new site improvements. The only 2 sites I don't get (unless some band enhancement) are still the B and D.There is one on Talcott already so if you are not getting it decent the new East Hartland site will likely not help.
Yes, still 853.6125
None that I saw.Any new TGs pop up today with the incident on the gold star ?
I get Troop A once and a while on the Troop G site but someone on the system has to be affiliated with the Troop G site on the Troop A talk group for that to happen.Is there less "overlap" of TGs on CLMRN as opposed to the old system? I used to pick up Troop A here in Norwalk but not since the change. I don't think it's a reception issue as I get G clearly.
For those of you updating your radios in The State’s CLMRN … Norwich Fire is now being simulcast on CLMRN, both City and Vol dispatch.
The Talkgroup for Norwich Dispatch is 20422 , the Talkgroup for Fire Ops is 20424.
If I had to guess, they're only active when there's a radio affiliated to themsefrischling any idea what is going on with the Norwich channels they only seem to be active from the time of Norwich city’s morning roll call and radio check until about 12 recently? Just found it to be sort of strange, is it being patched as a trial period or test?
At this time the simulcast is not full time. It was for a few days, but now it is only when the dispatcher enables it. As such, you primarily hear it on the City radios, which are VHF, rather than the volunteers, who are on 33mhz. I have asked Norwich Chiefs about it, and there seems to be no rhyme or reason as to when the simulcast is switched on at present.
Radio service has been out to the Vol Cos, with installs beginning.The radio IDs in Norwich indicate it is a console patch as there are no RIDs other than one of the PD consoles. The City FD are supposed to get mobiles and portables first, then work through the VFDs.
