DSDPlus DSDPlus 2.444 available
bravo14
Polk County FL
A few mints ago got a update box for 2.444
DSD+ 2.444
Fixed console log output formatting.
Added checks for bases files integrity. Functionality is controlled via the DSD+ Misc menu.
jhsands
Texarkana, Arkansas
I'm getting an error when downloading the base files. I am able to access sites with browsers; ScreenConnect, and TTD are working fine.
dave3825
Suffolk County NY
Please share on the 2.444 thread.
1700749091814-png.151756
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
In response to that, I clearly was speculating. And apparently I speculate more than I should.
In reality, base files checks are done by DSD+ by reading and checksumming those
files already in the DSDPlus folder. No Internet access required or used.
Example (seen on startup of DSDPlus if you look in the command prompt window):
Testing Base Files:
File: FMP24.exe PASS
File: FMPA.exe PASS
File: FMPP.exe PASS
File: FMP-Map.exe PASS
File: LRRP.exe PASS
File: Survey.exe PASS
File: airspy.dll PASS
File: lame_enc.dll PASS
File: libfftw3f-3.dll PASS
File: libusb-1.0.dll PASS
File: msvcr90.dll PASS
File: msvcr100.dll PASS
File: msvcrt.dll PASS
File: pthreadVCE2.dll PASS
File: rtlsdr.dll PASS
File: rtlsdr_FC0012.dll PASS
File: rtlsdr_V4.dll PASS
File: sdrplay_api.dll PASS
In addition, for anyone who doesn't want DSDPlus to reach out for version update checks or new versions of base files, use the menu system.
MISC --> disable Automatically Check for Updates
MISC --> disable Automatically Test Base Files at Startup
If the first is checkmarked, DSDplus will check (at least on the first start of DSDPlus on a given day) for a new version of itself
If the second is checkmarked, then each time you fire up DSDPlus it will perform the checksum test on base files in the DSDPlus folder and will delay in starting up until that is complete.
Just disable either/both if you have concerns about DSDPlus (not FMP24) delaying in startup or just don't want DSDPlus to try and phone the internet to check for a new version.
bravo14
Polk County FL
When I updated to the 2.444 and fired up dsdplus and had a error on the screen 2 missing/corrupted files. I decide to look around and I decide to copy all dll files and pasted them into the dsd folder and that fixed the problem.
b1tr41d
Raider of bits
36°44'34.30"N, 95°56'9.45"W
What do you have set here?
I'm also having the same issue with the sites file not loading.
Trying your suggestion, when I set "load nothing", then try to load a site via control --> Open Network/site loader window, it crashes with the following error.
Error
1R DSD+ 2.444
Unrecoverable error encountered:
Exception number = 0xC0000094 (Divide By Zero)
Instruction address = 0x45F363
Thread = #16
Register dump:
DS: 0000002B CS: 00000023 IP: 0045F363 EAX: 000001F4
ES: 0000002B SS: 0000002B SP: 314ECAE0 EBX: 00000000
FS: 00000053 Fl: 00010246 EBP: 314EFF70 ECX: 00000000
GS: 0000002B ESI: 0045F33E EDI: 0045F33E EDX: 00000000
Press Ctrl-C to copy this text to the clipboard
OK
Not sure what changed between 2.443 and 2.444 to make the data in the .siteloader file invalid. But nothing in the files has changed on my end.
Too bad the error is not more verbose that might indicate what is in error or what line it thinks is messed up.
jhsands
Texarkana, Arkansas
Error
1R DSD+ 2.444
Thread = #16
Register dump:
OK
last time I had that happen I used sfc /scannow and it fixed whatever the issue was.
Code:
sfc /scannow
merlin
DN32su
A Q ?
I have check base files at startup checked, does that mean I should randomly download base files, or only if there is a response ?
bravo14
Polk County FL
A Q ?
If you did a check and no error(s) or red text you are good. If shows red/missing than you need to download the basefiles.
dave3825
Suffolk County NY
If there is red text and it indicates issues with network, sites, or freq files, they changed the way those files are read so anything not within the formatting rules in the top of those files will trigger that.
I used to put cc (control channel) after entries in the freqs file after the color code spot.
So this,
will now trigger this,
bravo14
Polk County FL
So this,
on the CC isn't correct should be something like this
this is a example
Con+, 115, 14, 5, 454.44375, 0.0, 0 ; DCC=14
mtindor
FMP24 PRO USER
Error
1R DSD+ 2.444
Thread = #16
Register dump:
OK
Please send this exact report to dsdplusfastlane@gmail.com
