SDS100/SDS200: Firmware 1.05.01M Public Beta
rbrtklamp2
Dupage County, Illinois
I'm actually kind of surprised we haven't seen a update this week it's been almost a month with out a firmware update I really hope that means this next update will address multiple issues and not P25 stuff. DMR and NXDN aren't great and neither is analog on my side of things I am really hoping we see some kind of update that improves this in the up coming week or so.
Sent from my SM-N960U using Tapatalk
WX4JCW
Stow, Ohio
Im in Memphis today, somewhat having a difficult time tracking the Memphis/Shelby system, the voice is P25 but the control channel is Motorola type 2, this system overloads easily and i don't think it is tracking properly i.e. missing calls, signal strength on the system is -45 and for the most part there are little to no errors on voice decode, I have attached a small log
https://www.dropbox.com/s/s4xqroqvdfqwr0n/debug.zip?dl=0
Ubbe
Stockholm, Sweden
Whenever you see signal strenght values of -45 or stronger you could add the attenuator option to the frequencies to reduce it down to -65 which should still give more than a satisfactory signal to monitor and you will avoid getting any overload. Or so the theory goes.
/Ubbe
signal
/Ubbe
When I have a signal of -45 the decode is perfect, why attenuate?
maus92
The OP
Read message #142 above - the poster was complaining about the transmit power of the Memphis Shelby system overloading his radio. Sounds like attenuation might help. Worth a try.
WX4JCW
Stow, Ohio
Voice Decode is perfect, but for some reason it has some issues with the analog old Type 2 control channel, i mentioned attenuate as part of the diagnostic steps
That's ok, I have issues with my town on VHF high band, don't feel bad; on the dispatch channel sometimes while they are transmitting this radio makes undefined noise (like a burst of another channel for a half a second) Why does it happen? Who knows. I know its an SDR
slylingus
Audio Recording?
Firmware version 1.05.01 Sub 1.01.05
Audio recording wont turn on for me
Function hold record/replay says no recording session press any key
am i missing somthing?
card is empty.
I have the same favorite list on a BCD436HP and this function works
EDIT
All good reset user settings and worked Tracking RMR Vic network with no problems
Cheers
kruser
Well Known Member
W St Louis Cnty, MO
Sounds similar to my problem on VHF from very nearby VHF paging transmitters.
Discussed in this thread: https://forums.radioreference.com/uniden-tech-support/377046-desense-overload-issues.html
I've been playing with 152 MHz Notch Filters this morning and can get one of the P25 sites with the stronger CC signal to work when either paging site is transmitting but the notch filter simply knocks down the CC signal from the other nearby P25 site to a level you can barely hear it with a really good receiver and a scanner like the SDS100 can't hear it at all. Of course the band I need to attenuate with the notch filter is also the same band I'm trying to receive with the SDS100. The fact that I can attenuate paging enough with a notch filter to make one of the P25 sites work again pretty much proves that the SDS100 is suffering from desense. Don't know I I'll ever be able to use my new SDS on our statewide VHF P25 system. All other scanners are not affected by the paging signals.
If someone made a notch filter with a MUCH sharper skirt over what the PAR 152 MHz filter offers, I may be able to tune it to the worst paging frequency and get things working again but such a filter would probably cost me an arm and a leg!
If anyone knows of notch filters for the 152 MHz area of the bands that have super tight bandwidth for filtering an offensive frequency, please let me know.
edit: Sorry, I meant to point out that this Beta firmware version or any other release or beta firmware versions make no difference as far as my desense issue goes in the VHF band.
nessnet
Eastside of Lake WA
card is empty.
EDIT
Cheers
Don't you just press function, then press record (no hold)?
Maybe the holding is causing your problem...
