Free phase-ii tdma firmware for all G4/5 coming 8/17/18!!!!!!
KevinC
The big K
Super Moderator
1 point
It will only push audio setup like this I'm assuming that it is a bug in phase 2 systems being programmed in the g4.
Are you positive you have the correct RFSS and site ID? Those should have zero effect on a call being TDMA or FDMA.
In my other P25 systems, I have both of those values set at FF. Those systems are working for my area.
My problem was that I left those 2 values empty, I recall the default is set to "1". So I added those 2 values to reflect "FF" and it should work. I'll report tomorrow as I'll be in that area. But I'm pretty sure that I will be able to pick up the P2 system.
Again...
Thanks Seth for helping me troubleshoot this!
KevinC
The big K
Super Moderator
1 point
Mine is working I was just helping maximus, I use FFF as well for RFSS and site ID because it won't push audio with the actual values per the database and the scanner.
I understood that. My point was TDMA or FDMA shouldn't make any difference with regards to the RFSS or site ID. I suspect you don't have the correct RFSS or site ID values and that's the issue.
And I'm not arguing with you as I don't have a G4 and I have no idea what system you are referencing, but on my G5 I use the correct values and it works just fine for TDMA.
APX8000
Sarcastic Member
AES-256 secured
Maximus you still need the correct values for that system ?
I should be OK now that I have actually put in those 2 values. I'll give it a try early tomorrow morning and see if that works.
I honestly think that will work as that was my mistake in not inputting any values.
seth21w
Somewhere monitoring the air.
I have the correct values but with the Harris system I'm listening to and the firmware in my g4 it wouldn't push any audio with it setup with the correct values. Even had Ray look at it remotely.
APX8000
Sarcastic Member
AES-256 secured
Which system? I’ve found many times that the radioreference database is incorrect when it comes to RFSS and Site. The easiest way is to use the FF value and the G4/5 will actually display the correct value. You can then add those correct values and reprogram your device. Please make sure you submit corrections to the DB. The other biggest mistake is people using the DEC instead of HEX values.
APX8000
Sarcastic Member
AES-256 secured
Maximus I sent you a PM with the correct values you should be using.
Seth, I guarantee you do not have the correct values. Just because it’s Harris, it doesn’t matter. I have 35 systems in my G5 all with correct values, both Big M And Harris...all come in just fine.
maus92
The OP
Unication owes the people who paid $150 for the Phase II upgrade something to retain their goodwill. I'm glad they can offer the upgrade for free, but they essentially trampled on their most loyal customers who upgraded when Phase II first became available (only a few months ago.) If Uniden tried to pull something like this, the fanboys would have been all over the Uniden threads. This was an avoidable cockup.
seth21w
Ok well im sitting here looking at it right now it says 10/10 on my g4 and that is what i got on my uniden as well and i tried putting 10 10 in the pps and nothing...
parma,ohio
i would read the other posts on this some had GOOD POINTS on this with people crying over and over.
KevinC
The big K
Super Moderator
1 point
You need to enter "A" and "A". The G4/5 display in decimal, but PPS uses hex.
KevinC
The big K
Super Moderator
1 point
To all the people upset about the free Phase 2 upgrade, I would suggest you voice your concerns to Unication directly as their is no guarantee they will see the complaints here.
Below is a link to their "contact us" web page...
https://www.unicationusa.com/location--by-product
Let's keep this thread about technical issues or general info about the upgrade,
Thank you in advance for your cooperation.
KevinC
The big K
Super Moderator
1 point
I will try A A tonight. Is there any benefit to having this correct even if it's working fine with FF?
If you have other sites in the area with the same system ID and WACN it ensures you hear only the specific site you want to hear. With all F's you hear any site.
Plus the satisfaction of knowing your G4 is actually programmed properly.:p
seth21w
Only one system on a Harris multi site lsm with all red control channels. But I did put A in system site and RFSS and it is working thanks for helping me get it properly set.
KevinC
The big K
Super Moderator
1 point
Yea! I've gotten 2 things right this year. That's a record for me (according to my wife anyway).
