G-Series Trunking Free Scan Beta Test II
Charlie1068
Houston, TX
Another thing I notice when using the trunking free scan mode when I use the scan list the pager attempts to retrieve a signal then freezes and reboots after a bit
werinshades
Chicago , IL
With the public v1.3 firmware the G-series can be keyloaded with AES, DES, and ARC4 keys. It is also multi-key capable. Previous firmware versions also had encryption capability, but I believe it was limited to a single AES key.
The keyload software is not really restricted that I am aware of other than not being publicly downloadable on Unication's website. As others have said, contact your dealer.
I am not a beta tester so I cannot comment on the capability in the v1.4 firmware, but a friend of mine who participated in the first beta reports the updated keyload software does not recognize his G5.
Very interesting, thanks.
firemun
Concord NC
Just uploaded the new firmware in my G5. Have not tweaked any programming because...the G5 boots up finds a site then promptly shuts off. I can cycle the power, it boots up, finds a site then shuts off. Battery shows full charge and I also charged the battery until I got a green light before upgrading firmware. I am thinking it still may be battery issue but the pager was working fine before. Anyone else having a similar issue?
Jeff
Hit_Factor
Saint Joseph, MI
Jeff
Try applying the firmware again. I think, with the pager off, you can plug it into the USB cable and wait for it to show connected.
Good luck.
kikito
North Pole, Alaska
I see that on V1.4-T02J, Unication fixed one of the issues when the pager screen dims out. Now the Hold timer continues even when the screen is dark like it should. However, the other minor part of the problem still there, the power supply or computer won't be recognized until the screen is activated again.
jjcamilli
Under FW1.2 I tried the following BT receivers:
  1. https://www.amazon.com/gp/product/B082DVD367/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  2. https://www.amazon.com/gp/product/B078J3GTRK/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
  3. https://www.amazon.com/gp/product/B016NUTG5K/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I was only able to get number one to work. Upgraded to FW 1.3 and the G5 will connect to number 1 but no sound and I have toggled
"BT Headset Incoming Call Notification"
Upgrade dto the beta FW1.4 no change BT still not working.
Contacted the selling dealer who told me to contact Unication. So email, FB message and voice mail to Unication and no response yet.
jjcamilli
SORRY WRONG THREAD
W4KRR
Coconut Creek
Just did the upgrade to FW 1.4. I was hesitant at first because of the whole “you can’t go back” thing. The upgrade went smoothly, with no issues. Just a couple of observations:
While operating in Trunking Free Scan mode, it would be nice to be able to assign an alias to the line at the bottom of the screen where you now see “RFSS/Site:0x0x1/0x0x1”. Multiple systems often will have this same information, and it would be nice to differentiate them quickly.
I notice that the background colors that I have assigned on the “Group ID Setting” page don’t get used in Trunking Free Scan mode.
Otherwise, everything is working very well, so far.
Webodisk
Silent key.
Virginia Beach,VA
Known Issue for both, sent to unication
blackbelter
These are the reasons I will continue to hold off upgrading to 1.4 . Currently, The 1.3 works great and ability to scan multiple sites is not a major factor for me until all the 1.4 issues have been addressed.
trido
Southern In
I sure agree with you.
JASII
Memory Capacity
I agree, too.
Railbender
NW PA
They did such a good job with 1.3 it is hard to jump into the uncharted waters of 1.4 Beta right now.
Ed6698
Evansville, Indiana
I find that the 1.4 beta works fine for me. The TG delay, which allows time to press Hold and the ability to create scan lists makes this pager exactly the way I was looking forward to when I decided to buy my G4 a few weeks ago. I use my pager in Trunking Free Scan mode all the time now.
KevinC
Encryption
I'm everywhere Focker!
So has anyone else tried reverting back to the public versions? I've gone back and forth several times with no issues noted.
firemun
Concord NC
Hoping for a more clear and less error filled set of instructions soon for programming. There are so many misspellings, typos and poor syntax that many parts of the instructions are nearly unusable. o_O
kruser
Well Known Member
W St Louis Cnty, MO
Are you saying you went back from a 1.4 freescan beta version to 1.2 or 1.3 or even earlier?
If so, I thought they said that can't be done! Either way, no, I've not tried this but only because of their warning about not being able to downgrade and beta 1.4 users must wait until regular 1.5 before they can get rid of the freescan version.
KevinC
Encryption
1.4 (the Beta) back to 1.3.
KevinC
Encryption
Cool, good to know.
I'm not having any issues with either 1.4 beta but at least I now know I can go back if needed.
Thanks for trying this!
Keep in mind that I'm not suggesting anyone else do this. I have gone back and forth several times will no ill effects noted, but maybe I was just lucky or haven't discovered the reason not to yet.
