GRE-PSR 800 Sweeper.
gyjerry
Was wondering if the spec . sweeper is same as close call ?
If it is ...how do you activate what the manuel calls special mode.
I understand what the search service and freguency search does.
bottom line ...."Is special mode same as close call" ?
HOW IS THE SPECIAL MODE ACTIVATED.??
Following is from Psr-800 manual.
Special Mode
Spectrum Sweeper sweeps through frequency ranges in 1 MHz
blocks, looking for transmissions from nearby strong signal
sources. When Special Mode is enabled, Spectrum Sweeper will
skip any 1 MHz block where you have skipped five or more
frequencies using the SKIP key. Special Mode is useful when
you are close to many high power transmitters that are close
together in frequency. Use the ▶/II/SEL key to toggle Special
Mode enabled/disabled status
gyjerry
Yeah Dave....strange to me that nobody else has noticed this little flaw in their manual!
I'm really happy with my gre-800 ..great radio.
