Kenwood ADP/ARC4 Encryption
firemedic834
I'm looking for help and guidance on the following trouble with a P25 conventional frequency with ARC4 encryption not transmitting or receiving between Kenwood and Motorola radios.
  1. P25 Conventional Frequency
  2. ARC4 Encryption
  3. Motorola APX8000, Kenwood NX5200, and Kenwood NX5700 with the proper encryption modules installed.
  4. Frequencies match in the Motorola and Kenwood programming software.
  5. Key ID, key name, and key data all match.
  6. The frequency will encrypt between two Kenwood radios, however; not a Kenwood and Motorola.
Any suggestions or ideas?
Thank you.
tweiss3
Is it time for Coffee?
Ohio
Just to confirm, radio ID's are different, correct?
Is encryption strapped for the channel? What about talkgroup strapped?
What is the P25 modulation, LSM or C4FM?
kd4efm
EL98 Florida
Typically the encryption KEY ID is in hex with Motorola, decimal with kenwood.
So, with the Kenwood you will need to match the decimal number to the M hex key ID. I posted this a few years ago in this forum.
kd4efm
EL98 Florida
Here is an example, decimal (hex)
P25 CKRID 1 DES Alpha KEY 13(000D) 0110203140516170
P25 CKRID 2 DES BRAVO KEY 15(000F) 01020407080B0D0E
P25 CKRID 3 AES ALPHA KEY 49(0031) 66546A576E5A7234753778214125442A 472D4B6150645367566B587032733576
P25 CKRID 4 AES BRAVO KEY 50(0032) 5970337336763979244226452948404D6351665468576D5A7134743777217A25
P25 CKRID 13 AES CHARLIE KEY 60(003C) 7C69C8D0EC9F5620803819DB5427155668A591B12ECD95522B03AECE5EED621C
firemedic834
Yes, the radio IDs are different.
Yes, the encryption is strapped for the channel and talk group.
P25 modulation is C4FM.
firemedic834
The Motorola HEX was converted to decimal. The conversion produces a twelve (12) character decimal, however; the key data field in the KPG-D1N has a ten (10) character limit.
The key data field I'm referencing is Encryption > Multi-Key List - Key Data (Fifth column in the table). Is there a solution to that?
AM909
Radio/computer geek
SoCal
... Motorola APX8000, Kenwood NX5200, and Kenwood NX5700 with the proper encryption modules installed. ...
Just to pick a nit, on the NX-5xxx, P25 ARC4 is a free option and DMR ARC4 is a (cheap) license key. The hardware module (KWD-AE30K or KWD-AE31K) is only needed for AES/DES.
otobmark
NC
Also, the fact that you CANNOT use a keyloader to enter ARC4 keys even with the hardware module is why NX5xxx were decertified for use on our statewide trunk system. We require keyloading via KVL for ADP and AES256 for comsec which NX5xxx doesn't do.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Lol. There is no such thing as 'COMSEC' using 40bit ADP.
ADP should not EVER be an offered option for users on a public safety communications network, the ONLY algorithm in use should be AES256, and it should be mandatory to require OTAR as well for keying subscribers. The only use of a KVL should be for the initial loading of a UKEK, after that, it should only be used if a radio is intentionally(by the user, a consol or if someone gets a hold of is and tries to tamper with it) or unintentionally zeroizes it.
If you are manually keying and rekeying radios, with TEK's, you are introducing potential points of compromise of your security.
otobmark
NC
Are you kidding…we have serious back up encryption such as calling target “package” instead of suspect or by his name. And for locations we reference them to where Billy Ray shot the 10 pointer or use street names that were changed 50 years ago. Euphemism256 encryption.
