Kenwood nx-5000 with ftdi cable
kd4efm
EL98 Florida
you can run the gamble on Ebay items. this cable may work, but the issue is if you brick the radio on a firmware update, it is not covered under warranty.
Ask anyone whos been down the road, and chances are, they will say getting OEM was a wiser choice.
The OEM lists 162.00, and there are dealers out there where you may find it from 10% to 40% over cost.
Yes, as a radio tech even I go OEM, because I have to service and warranty these radios.
HAM or hobbyist, I see people drop loads of money on a QRP HF rig, but play with a beoufang, why? Get OEM, save the headaches.
Jolokey
Thank you. So, on a side note, If I had a radio such as the nx-300 (which I just so happen to in a box somewhere) and the cable works fine on the 300, it would more than likely work on the 5000 series?
kd4efm
EL98 Florida
Yes, the KPG-36UM or XM cable will work fine. The XM uses a FTDI chip (afaik) and writes faster (like 115200) the usb plain jane 36UM is a slower speed cable, and is the multi-pin portable programming cable for most Kenwood portables in the x00 or xx00 series. The KPG-22UM, still in production is a two pin cable for the 20 and 40 series two pin spkr mic radios.
EFM
KK6ZTE
California
The KPG-36XM has a switch allowing direct usb (for NX5000, at speeds much greater than 115200) and for the TTL converter (for earlier radios).
The newer are direct usb devices like Motorola, it's just a simple USB cable (internally) for the full speed. When you install a driver for the XM, technically it's the radio that the driver is for.
The KPG-36UM is maxxed out at 115200 due to the TTL level change.
bryanhendrix
persistent
Imperial County
Buy an OEM cable and do so from kd4efm.
Signed,
TK2312 owner.
---- great recommendation ---- great advice
so, if one or two of us out here we don't want to fuss with a cable - - - - we could probably work out where to send the non computer item at the end of a programming cable
just a thought; and, perhaps an invitation to use the conversation feature, a 'message' some other person feature, or - check a R R premium subscriber profile for a contact email
