New towers on KSICS as of 01/31/2011
While running Pro96Com on the Wichita tower today, I noted there were several new sites listed in the adjacent site table;
Site #138 with a control channel on 851.73750, which comes back to license WQLY760. I have temporarily named it Butler #2 on my system. Not sure of the actual location yet. The FCC database shows 5 different towers licensed with that callsign all in Butler County. My best guess would be Potwin due to signal level and decode rate.
The active last is Site #144 with a control channel of 856.93750. I can't hear that one tonight (but then the weather is pretty nasty tonight and 800 MHz reception in way down due to path loss. I'll try that one again in a few days when the air dries out about Thursday.... (plus, I REALLY don't want to go up the tower this week to hook the beam antenna back up. I pulled it a few months ago to use the coax for another antenna)
If someone in Butler, eastern Sedgwick, northern Cowley, Elk, or Greenwood counties could try to pull the data off of them, that would be wonderful.
There is also Site 143 with a control channel also on 851.73750, but it is showing as "Failed, Current" in the table on the Wichita site, so I am guessing it isn't actually "up" yet, but is in the final build stages. Site #138 also lists a Site #220 as “Failed, Current” and I am assuming it is in the same category.
I've already submitted Site #138 control data, but if someone else can pin it down as to where it is exactly, we can give it a name…..
System ID : 1B2
System Name : Kansas Statewide Interoperable Communication System (KSICS)
WACN : BEE00
Tower Number (Decimal): 138
Tower Number (Hex) : T0126
Tower Description : Butler #2
Control Capabilities : Data,Voice,Registration
Call Sign(s) : WQLY760
Timestamp : Mon Jan 31 19:42:01 2011
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Frequency(/Slot)
"00-0051","i",851.32500,806.32500
"00-0067","a",851.42500,806.42500
"00-0117","c",851.73750,806.73750
"00-0169","v",852.06250,807.06250
"00-0293","v",852.83750,807.83750
"00-0427","v",853.67500,808.67500
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
101,"T0101",1b2,"00-2487",866.55000,"Severy"
109,"T0109",1b2,"00-2577",867.11250,"Virgil"
111,"T010B",1b2,"00-2597",867.23750,"Dexter"
112,"T010C",1b2,"00-2517",866.73750,"Eldorado"
113,"T010D",1b2,"00-2577",867.11250,"Wichita"
143,"T012B",1b2,"00-0117",851.73750,""
144,"T012C",1b2,"00-0949",856.93750,""
214,"T020E",1b2,"00-2637",867.48750,"Cottonwood Falls"
220,"T0214",1b2,"00-0209",852.31250,""
