KSP Discussion Thread
People have told me that "no one should have the frequencies for KSP" does KSP know that so many listen??
I talked to other people and they said they have talked to troopers and they said that nobody will ever find the frequencies.
This website is good. Does anyone have the 10 codes for Shelby County, Kentucky?? I have looked on this site and googled it.
ShawnCowden
London, Kentucky
my gosh eribenboim please put it to rest already I mean ksp will probably be able to be heard as long as they dont start arresting alot of people with digital scanners then they will probably go encrypted and that will mean NO ONE PUBLIC WISE WILL BE ABLE TO HEAR THEM. not trying to be rude its just u have your answer and its the truth
unitcharlie
a Kentucky DB Admin...
far from Nonesuch, Ky...
I have been asked by a faithful rr.com user if I could modify the Aplha Tags for KSP.... He has asked that I move the "B" and "A" designation next to the Post number, ie: KSP 08-2B would become KSP 08B-2, instead of next to the tower number.... I will be doing this thru the afternoon today... so that is the change. I am also modifying the text box... no freq changes, just housekeeping, as it were....
ofd8001
Louisville, KY
UnitCharlie - You've done a right fine job fixing this stuff up and it is most appreciated. It must have take a good bit of time.
Now that I've slobbered you up with the good stuff, didja know that 460.4125 is showing up as both a post 4 and post 12 frequency with the transmitters being in Bullitt County? I think that it is really a post 4 channel frequency.
thanks!
jerk
jerkville
thanks!
I kept hearing that one while traveling 42/36 outside of Carrollton, then while on I 71...
May have to check the license data on that one, I'm redoing my Uniden because the current set up didn't work for this trip to Cincy. Definitely need NAC decoding or digital only setting on scanner.
catbird
Paducah, KY
Here in Post 1 453.8500 is designated "Post A". Anyone have frequency designated "Post B" ?
Thanks,
Richard
unitcharlie
thanks!
Thanx Chief, that means a lot coming from you! It is a labor of love! A while back a friend of mine sent me some information concerning KSP... I tested his information using the Posts I can monitor (4/5/6/7/8/11/12) and it was good. As a result I cleaned up a lot of stuff in the KSP data base.... That freq was driving me crazy, actually, and is why I went on the KSP quest....
Richard, are you hearing 453.850 as a "B" Channel in your area? The info doesn't have it listed in either capacity.... as soon as I post this I will look at my list again and make sure I didn't remove it inadvertently.... If you are hearing traffic on that freq let me know and I will put it back into the data base...
unitcharlie
BLUSHING HERE:
Richard, you are correct.... you were hearing it.... according to my stuff it is an "A" Channel but I had double posted the "B" channel in the "A" Channel slot as well... 460.13750 is the "B" Channel/453.85000 is the "A" Channel--both on the Paducah Tower...
Anyone else hearing something different than the posted speed limit with KSP? Let me know.... I'll try to go thru the listing as quickly as possible and correct my mistakes....
SORRY!!!
collier
catbird
Paducah, KY
It is a little confusing with same frequencies allocated to different site but I believe 460.3125 is "B" for Livingston county (Salem) site.
Richard
catbird
Paducah, KY
KSP "Post 2 A"
Does anyone know if 453.5500 is designated for Post 2 "A" ? Seems to be assigned to all Post 2 towers just as 453.8500 "Post 1 A" is assigned to all Post 1 towers.
Thanks,
Richard
