Mammoth Mtn. Ski Area Identifying Talkgroups
es93546
A Member Twice
Right Side of CA on maps
I completed the addition of two portions of the Wiki covering Codes and Terminology used at the Mammoth and June Mountains Ski Area. This should aid those listening to this radio system by explaining the unique terms you will hear. If anyone hears some that I haven't provided an explanation for, please post the code or term here and I will see about getting it included in the wiki.
553Eng
Mammoth Lakes,CA
well.. not a lot of info to report. Need a better setup outside of the house. I believe the control channel for the top is 854.425, chalet 854.125 and rainbow 854.475. I was able to hear talk group 2001 talking about lifts. I was also able to hear Mammoth Mtn on 854.650, ski patrol and lifts. Going to give it a go again in a couple weeks.
es93546
A Member Twice
What do you mean by the "top?" June Mtn. has two sites, Rainbow, which is at the top, top of Chair J6 on Rainbow Ridge. The other is the Chalet site and the antenna, as well as I can tell from Google Earth, is in the center top of the Chalet building. By the top, do you mean the top of Mammoth Mtn., or some other location?
es93546
A Member Twice
The two sites I mentioned is taken from license data. Your reference to the top, are you speaking of the top of Chair 7 (J7)? It is highest point for any facility at this ski area. However, most of the electronic gear on the mountain seems to be at the top of Chair 6 (J6).
WirelessMike
Small update for the Mammoth system. The "Chair 12" 855.0375 is currently the control channel and 855.3625 is not. I was only able to confirm with a scanner, as I can not recieve that site from my place with a PC.
855.0375 is not currently marked in RR as a control channel. es93546 had asked that he make updates.
I hope to run a log on Chair 12 but doubt I will have the time, since I am only visiting and not easy to do mobile.
officer_415
SF Bay Area
Thanks, DB updated.
es93546
A Member Twice
I'm logging some additional talkgroups. Since Sunday I've been logging the Events 2 & 3 talkgroups, but I wasn't at my desk to hear what type of event was being conducted. I've also logged additional lodging related talkgroups. Again I was not at my desk to determine if the traffic indicated the function of the channel. I wish I could wave a magic wand and gain the ability to record my logging.
I continue to log traffic on the following talkgroups, but I'm either away from my desk or I hear the traffic and it does not have any conversation that indicates the function of the talkgroup. Here are those talkgroups:
1001 - Administration? Upper management communications with receptionists?
1002 - Administration?
1005 - I haven't heard anything since last fall so it might have a summer function only. Golf holes mentioned. The Sierra Star Gold Couse, owned by the ski area, has an exclusive talkgroup of 1025. It would not make sense to allocate this talkgroup, separated by 20 other talkgroups, to golfing.
1007 - The old system had a rarely used talkgroup for what the mountain calls "Staff Accommodations" or in plain English, "Employee Housing." The 1006 talkgroup is building maintenance and it would be logical to group Staff Accommodations right below it.
1008 - Not logged very often.
1034 - The old system had alternate or second talkgroups for each ski school. I'm wondering if this new system allocates one second talkgroup for all three ski schools (Main, Canyon and Eagle Lodges). I log this talkgroup with regularity.
1038 - Fairly frequent logging in the past 2 weeks, several times per day, and only in the daytime.
1039 - Persons using first names only. Logged once in January.
1040 - Never logged. It may not be programmed into this system.
It is difficult to be right here at the computer, notice the scanner stopping on an unidentified talkgroup and have conversation indicate the function of the talkgroup. I've identified 80% of the talkgroups where 99% of the traffic occurs. If any Mammoth Lakes resident members can get a hold of a MMSA radio and see how each channel (talkgroup) is identified. I would appreciate that resident getting a hold of me, via direct message so I can get my hands on a MMSA radio.
I'm still looking for someone to figure out the channel numbers (LCN's) of the two June Mtn. Ski Area sites. I know someone tried, but had equipment issues. The end of the season at June is coming up so we don't have much time to figure it out. I appreciate any help that anyone can give me.
danieljkim
Thanks for all the info. I used FreeScan to upload the system into my BCD325P2 recently. Finally up here for a trip, and I'm not hearing anything on the scanner. Just noticed some of the recent updates, so will have to reprogram when I get home and try again. Funny though, sounds like I should have been able to hear some patrol traffic or something this am even with the previous info. I had the old system programmed and could hear things fine, but havent had a lot of luck since Mammoth put up the new system. Will try again...
es93546
A Member Twice
You have to make sure you have the correct channel numbers, which are shown when you click onto each site. Make sure you have all three sites programmed into the radio, those being Lincoln Lift, Chair 12 and Mammoth Mountain Summit. Click on the site name and scroll down to the frequencies. Enter each frequency exactly as shown, with the correct order, LCN and color code. All frequencies are entered twice, just as shown in the database. Ignore the "Channel ID" as there isn't anyplace to enter it in the 325P2.
The talkgroup information is updated as of yesterday. I've been logging traffic all morning long, including two talkgroups that I haven't identified a use for yet. However, I wasn't at the desk when they were received so I didn't hear what I needed for ID purposes.
I've never used FreeScan so I don't have any specific discussion of what to look for in your programming. I use ProScan and am more than satisfied with it.
es93546
A Member Twice
Has your 325P2 been upgraded to receive DMR radio systems? The basic, from the factory, radio does not support DMR systems and must be upgraded to be able to receive such systems. I think the cost is around $150 or so. Not having this upgrade would certainly explain why you aren't receiving the Mammoth Mountain radio system.
danieljkim
Yes, I did have it upgraded. I'll have to wait to get home to program using FreeScan. But I tried just programming it manually through the scanner, just to see if I could get something while I'm up here. I started a New System, chose DMR/MotoTRBO as Sys Type. Then MotoTRBO Trunk at the next entry. I hit "E" to confirm yes.
Then I went to "new Site", and tried the Lincoln Lift site info. Went to "Set Frequencies", and using the table at Mammoth Mountain Ski Area Site: Lincoln Lift, entered 854.8625 with LCN 69, and Color code 0. But if I try to enter the same frequency again, it says "frequency exists" and doesn't let me enter it again...
officer_415
SF Bay Area
You shouldn't have to enter them twice. If you enter it with LCN 69, the scanner will know that corresponds to LSN 139/140.
If you have all of the frequencies/LCNs programmed, and the system in ID Search mode, you should be receiving traffic.
es93546
A Member Twice
I have each frequency programmed in twice in my ProScan software. Someone told me to do that in that long thread where I asked for help getting this system to work for me. Putting them in twice matches what the database shows. So your advice here confuses me. It did though, help this member to start receiving so for him it was good advice.
officer_415
SF Bay Area
It could be that the programming software is a different interface than programming the scanner by hand. In any case, LCN 69 = LSN 139/140 (each channel contains 2 slots).
es93546
A Member Twice
Suddenly, around the 1st of April, I'm not able to receive the "Lincoln Lift" site. It is programmed just like the database shows. It won't scan through the Chair 12 site either. It scans the Mammoth Summit site only. It's like these sites are locked out. The BCD325P2 is a very complicated radio for me. For those of you who are familiar with this radio I would appreciate any tips you can give me to get this thing to scan the other sites.
es93546
A Member Twice
I posted on the Software forum and eventually solved my problem. I finally had to reset the scanner and reload my program. I don't know what caused the scanner to stop scanning all three sites on the Mammoth Mtn. Ski Area site. There were other problems that I've had for a couple of years which were also cleared up.
I made an assumption about this radio system that turned out not to be true. I thought that any radio traffic on one of the sites or repeaters would be transmitted on the other two sites. I noticed that while scanning on just the Summit radio site that traffic appeared to be lighter than average. I also noticed that I hadn't received any traffic from the Tamarack Lodge talkgroups. Once all three sites were being scanned traffic seemed heavier once again and I started receiving Tamarack Lodge talkgroups once again. I'm going to try to get up to the main lodge this week and listen to all three sites at the same time. I'll report back on this thread what the results are.
I'm also thinking about buying a laptop computer, with on reason gaining the ability to run that software that figures out all the Logical Channel Numbers for a system like the Mammoth and June Mountain Ski Areas. June Mtn. closed on Easter Sunday, so I won't figure out much as far as talkgroups until the end of the year when the area opens for next winter. But at least I can program in the basic framework of the radio system. This presumes that June Mountain will keep the radio system "on" all summer. If I get a laptop and figure out the LCN's I will of course report such here and submit the information to the RR database.
es93546
A Member Twice
Canyon and Eagle Lodges have been shut down, as well as the back side of the mountain (Chairs 12, 13 and 14). Radio traffic is a little bit lighter, however, there is traffic having to do with the closures and putting things away for upcoming summer. It will likely be 4-8 weeks until the summer Adventure Center at Main Lodge, the Sierra Star Golf Course and the Bike Park will be up and running. The Adventure Center includes scenic gondola rides to the top of the mountain. I think Woolly's Adventure Summit tubing and mountain coaster will run for a portion of the time between now and around mid-September.
I will follow the system throughout this time to figure out the summer channel plan. There will be traffic involving summer maintenance of most of the chairs. I think only one or two chairs, plus the Gondola, are needed to run the bike park.
I worked hard to figure out what I've figured out so far. If I had figured out the system and my scanner better last fall I would have identified more talkgroups by now.
By the way, ski patrol held a memorial service on the mountain for the ski patroller that was killed in that avalanche. Unfortunately, the 2024-2025 season will not go down as a wonderful one because of this.
