N8WCP
I’m guessing Fairlawn and Copley PD will be their own Talkgroup when Copley joins SECC in the spring . So this is just temporary, no need to reprogram radios twice. Just a guess.
Correct, temporary solution to allow Bath to monitor Fairlawn until Copley joins. At that point Copley and Fairlawn will share a TG.
KWs
Kent , Ohio
Talkgroup 62661 … nothing has changed.
you can also hear them on MAC 13 but that’s only temporary.
tweiss3
Is it time for Coffee?
Ohio
Heard Falls on the primary this morning. They identify by Falls #, same for Silverlake, Fairlawn, etc.
Wilhelm1234
Akron
I don't get it?... I now only receive EMS calls on 62661...no police activity whatsoever.... probably since the middle of last week
tweiss3
Ohio
What are you using to listen to?
My CF PD/FD feed still captures it, but I'm not seeing it show up on the calls platform. I do hear PD on 62661 on my scanner.
Wilhelm1234
Akron
Uniden 996XT, I stand corrected, I am receiving the Falls EMS calls over a different band ..62661 has somehow disappeared from my program....but the system does seem to be in a state of flux as I only started hearing Mogadore and Tallmadge on Stow's band a few weeks ago, I'll probably just wait for things to stabilize and do a new download
WX4JCW
Stow, Ohio
NEW Untrunker Hits
62780 - Munroe Falls FD Join
62719 - Hudson FD Join
62660 - Cuy Falls PD Join
62569 - Akron PD Join
54991 - 950#### ID Range
54964 - Summit SO Join
54914 - 940#### ID Range
54102 - 940#### ID Range
54747 - OSP Join
32510 - Copley FD
32504 - 940#### ID Range
940#### has some OSP Units confirmed but not many
950#### all encrypted so no confirmation
Swipesy
Northern Ohio
NEW Untrunker Hits
54747 - OSP Join
32510 - Copley FD
The 32510 and 32504 TG's are in the range of Medina County Interop TG's. I would guess Copley may have been on a Mutual Aid call in Medina County but 35210 certainly is not a Copley Talkgroup. Same for 32504. Probably some Northern Border Patrol activity on an Medina Interop TG that has not been previously identified.
Jphila20
Retired LE. Honor our Fallen.
Southern Lorain County, Ohio
I researched the talk groups and ID on my Unitrunker setup and found the following.
I may not be hitting the same site and that's why mine is different. I'm pulling for 002-001 whose peers include 002-002.
62780 - Munroe Falls FD Join 2 Hits
62719 - Hudson FD Join 0 Hits
62660 - Cuy Falls PD Join No hits
62569 - Akron PD Join Had 1 hit on Jan 15th
54991 - 950#### ID Range A lot of hits and only show Joins. 950#### are federal
54964 - Summit SO Join XEComm 31
54914 - 940#### ID Range Feds - encrypted
54102 - 940#### ID Range Feds - encrypted
54747 - OSP Join Is probably Medina County since the ID’s start with 529####. I have seen some 940#### which is the Feds.
32510 - Copley FD 2 hits for Joins
32504 - 940#### ID Range Is also probably Medina County since the ID’s start with 529####. I have seen some 940#### which is the Feds.
940#### has some OSP Units confirmed but not many Anything starting 940 is Federal.
950#### all encrypted so no confirmation These are tech’s and the support desk for in car computers which use MARCS and usually is not encrypted.
  • Ohio_MARCS_Radio_IDS.pdf
Wilhelm1234
Akron
Does the Unitracker program load the department names along with the ID numbers?..Scanner Pro used to but the last time I programmed it only loaded the numbers
