Metro-25/MTA MRRS P25 System
jgorman21
Glenmont N.Y.
I'm in North Greenbush, only a few miles as the crow flies from Corning Tower. I've picked up groups 3001 (NYSP NYC) and Group 6092 (????). As for radio ID's, numerous 772xxxx's and a single 423xxxx
Interesting and thanks! Which frequencies do you have programmed in.
And oh, to GTR8000. I did not have 769.90625 in. Put it in. Still nothing. “Out of range!”
jgorman21
Glenmont N.Y.
Well now. I had quite a few “operator errors” on my programming which was done quite awhile ago.
Fixed the WACN and System ID. Put this updated frequency in. Listened to 769.90625 on my PSR 500 and I can hear it. But nothing n the G5! Must still be missing something. As I am located in Glenmont NY I have to be just as close (or closer) than “diver” to the site and...nada! Zilch,
Of note is that this G5 can pick up the Saratoga 800 system which is approximately 40 miles away. Any/all suggestions are welcomed and appreciated!
dave3825
Suffolk County NY
Most of the rid's I have logged that are 771XXXX and 772XXX are NYS Pd.
@GTR8000 posted this back on page 3 MTAPD 700 MHz P25 System
With that said, how is the receive sensitivity of a g5 compared to your scanner? Are they using their stock antenna's or sharing an outdoor antenna?
GTR8000
NY/NJ Database Guy
BEE00
Can someone in range of the Corning Tower site please run DSD+ or Unitrunker or Pro96Com on the site to determine the other frequencies in use? Thanks.
jgorman21
Glenmont N.Y.
Stock antenna on the G5. All the other system I monitor are awesome!
GTR8000
NY/NJ Database Guy
BEE00
And while I have the attention of the Capital District crowd...can someone check to see if that "NYS DHSES" site is still on the air? Site 020-020 of SysID 26D, channels are listed in the database. Thanks.
dave3825
Suffolk County NY
If only this was asked 2 weeks ago. Just came back from Lake George. Had airspy and laptop and drove right thru there.
APX8000
Sarcastic Member
AES-256 secured
Check the RFSS and Site in the G5. It’s HEX not DEC....that usually gets most. If all else fails use FF’s and it will work.
chrismol1
P25 TruCking!
769.90625
Network WACN:91FE8[597992] SYSTEM:26E[622] NAC:086[134] LRA:86[134]
Current Site
SYSTEM:26E[622] NAC:086[134] RFSS:86[134] SITE:86[134] LRA:86[134] STATUS:ACTIVE RFSS NETWORK CONNECTION
PRI CONTROL CHANNEL:1-145 DOWNLINK:769906250
SEC CONTROL CHANNEL:1-311 DOWNLINK:770943750
SEC CONTROL CHANNEL:1-645 DOWNLINK:773031250
SEC CONTROL CHANNEL:1-687 DOWNLINK:773293750
SEC CONTROL CHANNEL:1-771 DOWNLINK:773818750
CURRENT DATA CHANNEL:0-0 DOWNLINK:851000000
AVAILABLE SERVICES:[GROUP_VOICE, INDIVIDUAL_VOICE, INDIVIDUAL_DATA, UNIT_REGISTRATION, GROUP_AFFILIATION] SUPPORTED SERVICES:[GROUP_VOICE, INDIVIDUAL_VOICE, INDIVIDUAL_DATA, UNIT_REGISTRATION, GROUP_AFFILIATION]
Neighbor Sites
SYSTEM:26D[621] NAC:086[134] RFSS:01[1] SITE:01[1] LRA:01[1] CHANNEL:0-3 DOWNLINK:851037500 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
SYSTEM:26E[622] NAC:086[134] RFSS:15[21] SITE:15[21] LRA:15[21] CHANNEL:1-193 DOWNLINK:770206250 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
SYSTEM:26E[622] NAC:086[134] RFSS:33[51] SITE:33[51] LRA:33[51] CHANNEL:1-185 DOWNLINK:770156250 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
SYSTEM:26E[622] NAC:086[134] RFSS:51[81] SITE:51[81] LRA:51[81] CHANNEL:1-235 DOWNLINK:770468750 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
SYSTEM:26E[622] NAC:086[134] RFSS:6F[111] SITE:6F[111] LRA:6F[111] CHANNEL:1-149 DOWNLINK:769931250 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
SYSTEM:26E[622] NAC:086[134] RFSS:8D[141] SITE:8D[141] LRA:8D[141] CHANNEL:1-65 DOWNLINK:769406250 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
Frequency Bands
BAND:0 FDMA BASE:851000000 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:-45000000
BAND:1 FDMA BASE:769000000 BANDWIDTH:12500 SPACING:6250 TRANSMIT OFFSET:30000000
BAND:8 TDMA BASE:851000000 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:-45000000 TIMESLOTS:2
BAND:9 TDMA BASE:769000000 BANDWIDTH:12500 SPACING:6250 TRANSMIT OFFSET:30000000 TIMESLOTS:2
GTR8000
NY/NJ Database Guy
BEE00
Current Site
Much appreciated, database updated. Any luck with the 26D "NYS DHSES" site up in that area?
jgorman21
Glenmont N.Y.
Soooo...thank you first of all. Everyone.
I still get out of range on the Mrrrs Corning Tower. However, I’m getting full bars now on the DHSES. Honestly. Totally confused. Must be more errors. But, I Do have the 769.90265 in both systems with the other frequencies listed.
one other thing. Not hearing a peep on the full bars system.
Tank67
New York
Picked up TGID 1541, they were talking about an RMA and a dispatcher replied. Think it’s MTA PD
jgorman21
Glenmont N.Y.
OK I was away for a bit Trying to get back to this.
I am in the same place I was on my previous post. Full bars on the DHSES site Nothing on MTA site. This is on my G5. So I must be missing something if others nearby are hearing it. Any suggestions?
Thanks!
jgorman21
Glenmont N.Y.
Update. I went through all my settings and found a major error in my programming. Corrected and working on the Corning site. Full Bars here. Nothing on DHSES. But now that its programmed correctly I can go in that general vicinity and check soon. Ive added wildcards to both to see what I get.
Thank you all.
