MRRS System (MTA PD)
k2hz
Rochester, NY
From all my experience, scanners really do struggle with this p25 simulcast distortion so bad that I immediately appreciated the difference with the Unications.
The only scanners designed to handle the simulcast issue are the SDS which work well for that but have other issues. No simulcast reception problems with Unications but they lack some "scanner" features.
Finest23186
So if I go down the street I picked up PC. When I headed down to the Rye Pc area I hear everything. Picking up PC, MTA down at GCT. Basically where I am located (7mikes from nearest MN station and 600ft elevation I don’t get anything. All about the location and maybe getting a better antenna?
GTR8000
NY/NJ Database Guy
BEE00
The talkgroups will be active on whichever cell(s) have at least one subscriber affiliated. That may mean that you'll hear activity on both cells, or perhaps intermittently on the more distant cell from the agency's area.
GTR8000
NY/NJ Database Guy
BEE00
If a radio is affiliated with that talkgroup on the Zone 3 cell, yes, otherwise no, as I stated in my previous post.
scannerfreek
Yorktown,New York
What other issues does the SDS radios have that I should be concerned about if I wanted to get one?
GTR8000
NY/NJ Database Guy
BEE00
The SDS series is pretty solid on 700/800 MHz P25 systems, especially where simulcasting is a factor. You should be fine for scanning the MRRS and probably also the Westchester system, but it also wouldn't hurt to purchase the scanner from a place that has 30 day no-hassle returns in case you aren't satisfied. And of course hold off on purchasing any DMR/NXDN keys until you know you'll be keeping it, as those are non-refundable and non-transferable keys...they are married to the scanner's serial #.
k2hz
Rochester, NY
You should also research the problems with the SDS series scanners if you are in an an area with high levels of RF from nearby transmitters resulting in desensitization and spurious responses. Fine for listening to your immediate local system but a problem in monitoring adjacent area system in the same band. Also various other weird effects as described in this thread:
dave3825
Suffolk County NY
They go long periods of time without firmware updates. Then when one comes out, it has negative effects for a good amount of people. Other than that, and besides the cheaper than cheap Chinese parts used, it’s a great radio.
Tank67
New York
Someone was checking their radio on TG 9142 on the Metro simulcast but didn't see a UID.
dave3825
Suffolk County NY
Tg 1000 MTA PD District 3 radio 420xxxx was talking to NYSP radio772xxxx on 4/8 clear
This tg was active again yesterday for a few hours on Zone 1. This time 2 42044xx District 1 & 2 users talking to a 7720xxx radio. Encrypted.
joeya7
Has anyone had any success in being able to monitor the MTA system on a BCD996P2? I know it's not the preferred scanner but for other reasons it's what I'm working with.
Alarms50
Ossining, NY
As has been mentioned in this and other threads, with any simulcast system this is not the best scanner to use.
With that said, I have had success using the BCD996PD in a base mode, where I used to work. There were six of these scanners there, only two were receiving the MTA System, four were not. All six were successfully receiving the Westchester County P25 Phase 2 system. Researching the issue I found that the four that were not receiving were connected to the same antenna splitter, I could not find where to the two "good" scanners were connected to.
So, yes it is capable of receiving the MTA System.
ericg123
Westchester County, New York
Not sure why when scanning this system on Zone 3 with my SDS100 I have it setup to only scan the Westchester Local Police Departments. I have an issue with Eastchester Police Department Dispatch (TG: 9252) where it is not picking up communications when in Scan mode. I can hear a lot of communications on Harrison PD Dispatch (TG: 9563.) When I am holding on Eastchester, I can hear some communications but not much.
Can anyone give me insight in to why this might be happening? Thank you.
joeya7
Interesting I pick up everyone else but Harrison PD.
4-crime
NY, NY
Just heard the Dsitrict 4 sergeant advise the dispatcher to “have all district 4 units switch to the district 4 tac channel”.
Does anyone know what talkgroup that might me? I see there are tac channels for all the other districts except 4.
