New GSP mobile repeaters
MTS2000des
5B2_BEE00 Czar
I already knew the answer, just wanted to see what crock of **** you would cook up this time.
Like all snake oil salesmen and quacks, you attempt to cloud the issue with techno-jargon, rhetoric, etc. but when it comes down to it, it's just hot air from a used car salesman.
There are no widespead reports of narrowband systems going deaf as you would claim. No reports of users crying into their narrowbanded radios saying "this sucks...I can't hear you. We should have gone digital! It will solve all our problems! The dead are rising from the grave. Please send help fast!"
All your double talk doesn't change the fact that there aren't any major problems with narrowband. It's a problem for you because you don't get to upsell your overpriced digi-crap. Show me ONE major user complaining of degraded performance...nevermind. you can't and you won't because it simply does not exist.
Nice try asshat.
ButchGone
Ringgold, Georgia
My 2-cents...
As an amateur radio op I know that a narrower signal does travel farther and does not restrict it's usable range. Take VHF sideband as an example. When working long distances on 144MHz we'll use upper sideband which has a 3KHz bandwidth, much narrower than AM or FM mode. This compresses more energy into a smaller window and allows the singal to penetrate over a longer haul. I have worked all up and down the East Coast, into Canada and the western states on 144MHz sideband (narrow) from Chattanooga, TN. Now granted we do work band openings that help and have big yagi antennas, but the narrower signal does punch through. Same as HF, a narrower signal does punch through the mud more efficiently. What's more, the narrower the bandwidth of a transmitted signal the less transmit power is needed to get through in most cases.
Of course there can be some rare exceptions but those are limited to atmospheric conditions or the stations output power and antenna system.
My two pennies in the bucket, no flames please!
BG..
N
N_Jay
Guest
BG..
No flames, but you need to read up a little more on FM as opposed to AM modulation types.
Yes, a narrower AM signal can can be more tightly filtered on the receiver end, reducing noise, (That is where the apparent gain of a narrow SSB signal comes from)
FM is quite a bit different.
At least you have put forth a logical assumption with enough information to rationally discuss it.
MTS2000des
5B2_BEE00 Czar
So once again the great N_Jay exerts his superiority over the rest of us RR peons.
So to prove the theory true N_Jay, there must be tons of narrowband systems (since narrowband radios and hardware have been available for a decade now) experiencing the loss of coverage you proclaim.
How about naming one of them so you can further drive home how inferior it is to wideband?
Here though, is an example of a decent sized conventional analog public safety system that did narrowband, for less than 5,000 dollars versus replacing it with an overpriced alternative, and NO REPORTS IN COVERAGE LOSS using the SAME EQUIPMENT were documented.
Narrowband analog radio system conversion - A case study | Daryl Jones' Weblog
(hint hint..he'll steer around this one like a Nascar driver, watch and enjoy!)
b7spectra
EMS Dispatcher
Cobb County, GA
OK ladies. Don't make me get out my badges! :) Only kidding. Lets keep it civil here before we get this thread shut down! Lets adjourn this one to the WasteLand? That way we can make German specticals out of ourselves!
N
N_Jay
Guest
Oh Daryl, . . . .
(From the link: )
Conclusion
Our experience has consistently shown that the difference in coverage between wideband and narrowband systems is imperceptible to the radio user. This is especially true for multisite voted radio systems that cover a relatively small geographic area. We have yet to see a compelling set of circumstances to justify a digital police or fire radio system.
So let me get this strait, a "multisite voted radio systems that cover a relatively small geographic area" does not show a loss of coverage at the fringes???
Give me a friggin break!
Yes, let me say one more time clearly (because otherwise our resident narrowband expert, MTS will miss it), the reduction is 1.5 to 3 dB. This may be insignificant, especially in overbuilt networks (like "multisite voted radio systems that cover a relatively small geographic areas"), but can be very significant in many existing VHF and UHF systems.
Why don't I have any examples? Because the fools that do this stuff don't hire me, they use teh "free" expertice of the local know-it-all (who probably never head of errors and omssions insurance, nor could get it if he tried) and once they have screwed up, are not about to brag about it.
Do the friggin math! Take a class of two on radio propagation.
All your (and Daryl's) whining and moaning about evil digital, and evil trunking, and evil XXXXX (Insert your favorite "to hate" vendor here) is going to change the laws of nature and the movement of the market.
N
N_Jay
Guest
Oh, and (Hint Hint) the post was not to you as I would not expect you to "put forth a logical assumption with enough information to rationally discuss".
Have a great night!
MTS2000des
5B2_BEE00 Czar
I'm not the expert N_Jay, so I'll concede to you, but wouldn't a digital FM carrier have the same problem when bandwidth is decreased? Aside, on the fringe coverage area, would not the user be considered going outside the systems intended area of coverage anyway regardless of the modulation or bandwidth used?
I'm sorry I just don't understand, I know I'm just a "Georgia boy" and don't have all those fancy degrees on the wall, but I guess I'm just not understanding the gravity of the situation.
N
N_Jay
Guest
I am not sure your question is serious, but I will play along for our home audience.
Why yes, and that us why P25 using 12.5 kHz channels can run at 9600 BPS and NXDN using a 6.25 kHz channel only runs at 4800 BPS, even though both are 4 level modulation.
When you get to a digital system you have more parameters to "play" with in the design than with simple analog FM.
So when you design a digital voice protocol like P25 or NXDN (or OpenSky, or iDEN, or TETRA) you trade off the modulation type, the modulation rate, the amount of Forward Error Correction, against the amount of payload data you require and the minimum signal level, minimum signal to noise, or minimum carrier to interference ratio you anticipate.
A digital system can then be tailored to work at the a path loss value similar to FM, greater then FM or less than FM. (Really any value the protocol designer wants to set as the margin the system designer has to provide in the system design)
Note, the design of the protocol and the design of a system using the protocol are somewhat at odds.
P25 was designed intentionally to provide the same or just slightly better range than 25 KHz FM (the standard of the day, when it was first designed). Hence it has slightly better performance than 12.5 kHz FM (when all else is the same)
Yes, it would be nice if every system could be designed like a cellular network, where you can expect to always be above the minimum threshold, and hand off to another site before you reach any fringe areas.
Unfortunately, most public safety design is site and cost limited, and both are traded off against coverage. In any large area system you are likely to find some areas where you are working at the edges of your designed signal level margin. In these areas, small reductions, such as the one created when you transition from a 25 KHz FM system to a 12.5 kHz FM system can cause issues, if not addressed elsewhere in the design. (Adding power, better antennas, lower loss line, additional sites, etc.)
That is a shame, because I have a good friend who is just a Georgia Boy with no degree hanging on the wall and he is one of the best RF engineers I know.
MTS2000des
5B2_BEE00 Czar
"Why yes, and that us why P25 using 12.5 kHz channels can run at 9600 BPS and NXDN using a 6.25 kHz channel only runs at 4800 BPS, even though both are 4 level modulation.
Unfortunately, most public safety design is site and cost limited, and both are traded off against coverage. In any large area system you are likely to find some areas where you are working at the edges of your designed signal level margin. In these areas, small reductions, such as the one created when you transition from a 25 KHz FM system to a 12.5 kHz FM system can cause issues, if not addressed elsewhere in the design. (Adding power, better antennas, lower loss line, additional sites, etc.)"
So while I agree that a digital carrier (C4FM) occupies the same space it can indeed yield a better S/N than analog, but on the interference limited design, does not digital modulation present another issue of interference or high BER being transparent to the user UNTIL the signal has deteriorated to the point of no return? For example, at work I am in a pretty tough RF environment being inside a building, we use an Astro 25 SZOL 6.xx simulcast system, originally on an analog Smartnet II prior. The digital radios suffer from robotic sounds, dropouts, and poor audio quality that are from a either weak RF, or strong inbound interference. There is no indication of SQE, BER or anything to let a user know you are in a marginal coverage area or strong interference. The indication and tone options in CPS don't work well enough in my experience and often times not at all.
Problem is, we have no way of knowing we are in a weak or marginal area UNTIL the failure in the link occurs whereas with analog FM, the user is generally aware of the deteriorating conditions (i.e, the decrease in S/N that is very apparent, static, Rayleigh fading, etc) and this allows for the operator to correct (relocating, identifying the source of the interference and eliminating it "by ear") for it. With digital this all or nothing reality can prove quite dangerous for users who generally have little to no indication their radio is operating at it's fringe or in an area high with RFI, Nextel interference, or other source because the decay isn't apparent until it's already "too late". We've all experienced this on our digital cellphones where a perfectly "good" call is dropped due to strong inbound interference (e.g. being on a mountaintop with a CDMA phone and a rouge PN causes your handset to bump you, etc) with no "warning" where as in the analog days there usually no doubt you were in a marginal area or being interfered with (e.g. crosstalk, static, fading, distortion, etc) and it was easy to predict the link was going to fail.
So while yes, a 1.5 to 3dB is significant enough on the outskirts of a coverage area with narrowband versus wideband, is it any different than a high BER on a digital system in the same scenario? At least with the analog carrier, the users will be highly aware he/she is approaching the edges of the system or encountering interference, with digital it's all or nothing, and sometimes nothing comes too soon with little or no warning to the user who's life depends on the radio to function when needed most. I am sorry, I just don't see this as acceptable and don't see how public safety benefits from this. At least with analog FM (narrow or wide) the user is usually very well aware when his/her radio is working poorly or in a poor coverage area or getting interference. That isn't the case with digital, unless you are so advanced you ears can decode the raw packets themselves, for the rest of us, we are 100 percent reliant on the vocoder, DSP and combination of so many other things to come together to produce the intelligence from the modulated carrier. Our brains have been removed from the equation, at least with analog FM we can still use them to pull that signal out of the noise "manually". We (the users) are provided with much more to work with, and when lives are in our hands, we should expect nothing less.
A poorly designed radio system with inadequate coverage is a poorly designed radio system, regardless of what kind of modulation, topology, or whatever is used to implement it. Digital will not solve these problems nor make it go away. It just presents a different set of issues altogether and they aren't any less perplexing than the limitations of analog. Just more expensive to implement and fix, and more evasive to track down in many cases.
"That is a shame, because I have a good friend who is just a Georgia Boy with no degree hanging on the wall and he is one of the best RF engineers I know."
see we are not all idiots N_Jay, thank you for coming clean for a change.
N
N_Jay
Guest
Of course the issue we were discussing was narrow vs wide FM, and you spent considerable time saying there is no difference. Quite obviously there is.
Putting that aside, you have decided to go back to your anti-digital theme.
While there is some amount of comfort in hearing the static and knowing you are in a weak signal area with an analog system, in the REAL WORLD (that would be defined as the area outside Georgia, where the laws of physics have been suspended) it is still better to have coverage where you can hear but not understand the digital signal. (using the FACT that a p25 system will operate satisfactorily at a signal threshold below a 12.5 kHz FM signal)
http://f1.grp.yahoofs.com/v1/sG4eSt...y_25k/analog to p25 comparison on 443_325.wav
P.S. About your off-hand "coming clean" comment, I challenge you to find ONE PLACE in my previous posts where I was not.
I have no problem pointing to many where you were completely off-base.
BTW, there is a really neat "Quote" feature in the forum software.:wink:
MTS2000des
5B2_BEE00 Czar
the link you gave is dead.
I disagree actually having dispatched on both systems. I can make much more than "comfort" out of a noisy FM carrier than a P25 (or any digital carrier) when the signal is on the threshold. Hams do it everyday, whether it be on HF, SSB, FM or AM- and this is what separates a skilled operator from the average ones. The same skills are needed when you are on the other end of a radio (or any other instrument) where someone else's life is in your hands. I want every piece of possible intelligence available from that carrier, wouldn't you? I bet if you were on the other end screaming for help, you would. You would also want the person on the other end to have everything available to him/her so they can send an appropriate response.
I still don't see how narrowband falls so short that it has the same problems as digital. Fact is there aren't any systems hitting the headlines where the small if at all perceivable difference as there has been documented with P25. The cost to narrowband in most cases, is considerably less than replacing the system altogether.
But I would not expect an objective response from someone who makes their living selling the replacement systems, just as I would never expect a new car salesman to tell me to keep my 76 Chevy that runs fine, is economical to maintain, and in some aspects is better than the current lineup when his primary interest is selling a new car.
None the less your response is just as entertaining.
N
N_Jay
Guest
This is 25 kHz analog vs, 12.5 kHz P25 same radios, same location
And yet, again, you have shown you are incapable of making a post without including incorrect information or assumptions.
My guess is you have a lot of trouble keeping what you "Know" and what you "Think you might know" (assumptions) separate in your thinking.
  • analog to p25 comparison on 443_325.zip
MTS2000des
5B2_BEE00 Czar
and yet again, you post some rhetoric that is hardly relevant, an old file of a couple of hams playing with their Astro radio toys 12 seconds long hardly qualifies as credible data. That's the best you can do?
I can do that with my XTS5000 and Astro Saber...BFD.
the file is a bunch of static followed by Donald Duck saying something at the end, 12 seconds long total run time- hardly enough for a real comparison and done by hams using personal equipment (as noted by the frequency of the file: 443MHz). No information about the system, topology, power, noise floor- it doesn't amount to squat as most of your ramblings. 128K MPEG compression removes much of the audio anyway, hardly room for an accurate spectrum analysis to be performed.
I thought a degree touting so-called engineer could do better. (you know, some white papers, real case studies..)
Nice try though. Still waiting for that list of under performing narrowband public safety systems you will never cough up.
N
N_Jay
Guest
Sorry the WAV files was too big to post. Yep, should have listened to the MPG before posting. It is crap.
Here is a link to the file location.
You may have to join the Yahoo group to get to it.
http://groups.yahoo.com/group/APCO25hamradio/files/
Since the test is two messages immediately following each other, we can fairly safely assume that all the variables you mention are the same.
Yes, this is an assumption, but a much better one that most of the (wrong) assumptions you seem happy to post in your threads.
ButchGone
Ringgold, Georgia
Hey now,
While I find this ongoing debate over narrow bandwidth gains/losses a robust and at times amusing volley isn't this particular thread supposed to be about those new 700MHz GSP vehicle repeaters? I'd hate for this thread to get closed because of the side conversations! I'd still like to hear from folks around GA what they're hearing on 700Mhz as it relates to GSP. Apparently some folks have said GSP is still using 450MHz in some spots. I'd love to see the debate over narrow band comms on another thread. I've seen good threads on RR killed because of side conversations.
Smoking the peace pipe,
BG..
N
N_Jay
Guest
I apologize for the off topic posts.
Maybe we need a healthy discussion of narrowbanding and digital vs. analog, and trunking vs. conventional, in separate tavern threads.
N8IAA
Fortunately, GA
BG..
Back to the topic. BG, they are active on occasion in the Metro area. I have heard them. Always not near enough to get full conversations. Heard them last weekend on the way up to NC.
Larry
