NYPD Trunk?
SCFDCOMM
The data stream is identical on all towers on a simulcast system. It can't be different or it would cause reception errors.
From what I have heard, third hand and unconfirmed, ESB may be only active site.
as of now you are correct
718164878013
The Magnificent
Brooklyn
As of 21:00 today, the 46/48 (Zone 13), 47/49 (Zone 14), 50/52 (Zone 15) have moved to the +PBBX encrypted zones. I’m wondering if there’s gonna be a TRS channel for them down the line.
rr60
KVL 7000
TV 16 has been rolling in frequently as of late. I have watched numerous times, however not continuously. I have not seen the 483.xxx CC roll. Has anyone?
pro106import
Milford, Ct. perched high above Long Island Sound
Yes the CC has stayed the same since Aug. 1st. The CC's on the NYCICN system haven't changed for at least a year, so it's not unusual it seems.
K2NEC
5F6
Regarding this system:
New York City Police Department (NYPD) Trunking System, New York City, New York
It appears that their TGID Scheme is rather simple and follows this channel layout almost to a T
CW1=301
SI CW1=302
CW2=303
Man 1/5/7=101
Man 6/9=102
Brx 40/41=110
Brx 42/44=111
Bkyn 60/61=116
Bkyn 62/68=117
Qns 100/101=127
Qns 102/106=128
etc.
Is this something worth submitting as an update or not because it's unconfirmed that's the actual traffic being passed on that TG? Seems like it's just incremental following the precinct number.
k2hz
Rochester, NY
CW1=301
SI CW1=302
CW2=303
Man 1/5/7=101
Man 6/9=102
Brx 40/41=110
Brx 42/44=111
Bkyn 60/61=116
Bkyn 62/68=117
Qns 100/101=127
Qns 102/106=128
etc.
Submissions should be based on confirmed information, not speculation.
richee2000
Has anyone heard any actual activity on this system within the last week?
K2NEC
5F6
So how do we know that 104 is MTS/17/MTM if it's encrypted? Would be pretty difficult to tell from strictly RIDs
k2hz
Rochester, NY
The issue is that the system is still apparently in the buildout and testing phase and not in service. There is no reliable information about the actual intended use of the system or if traffic heard now is only for test purposes. If it was actually in service, activity on the encrypted TG could by matched with activity on the suspected associated UHF channel to confirm continued use.
There is a strong possibility, even when the system is actually in service, activity on any TG may be sporadic since it will be active only when a subscriber unit is affiliated regardless of activity on the associated UHF channel.
K2NEC
5F6
If the P25t is simulcasted with UHF, sure. But if they are standalone or trunking is a replacement for conventional, there's no sure fire way to tell that this TG is being used for x purpose if it's encrypted unless someone personally verifies that info with a subscriber.
ff026
ff026
Terrible logic.
This “test” system’s purpose in unknown.
The only way to figure out what is what, watch activity and see what it follows.
It the activity lines up with those commands then it’s probably true.
They are multicasting right now.
There are no “users” of it.
If the activity lines up then it’s probably true.
It’s not like they switch the whole division to an untested system and abandon the conventional system for 20-45 minutes at a time.
It’s not like you can just do that. Lots of planning takes place when a division is shut down.
seagravebuff60
Forensic Scanist
That would be a terrible idea. As @k2hz points out, submissions should be based on confirmed information only and not speculation. The RR submission guidelines mention that:
We are interested in the following information that you have personally gathered and confirmed to be accurate, either on your own or as a group, but please keep in mind that we do not accept data drawn directly from the FCC database. You must personally verify that a frequency is in use before you submit it.
TG 104 was broadcasting in the clear for this system before it went encrypted.
Most of the TGs are multicasted with their respective UHF conventional counterpart, so it's just a matter of waiting and listening for traffic.
GTR8000
NY/NJ Database Guy
BEE00
And of course, sometimes we have sources who provide info that is not readily available to the general public. Just because you can't hear it, doesn't mean that someone else can't and/or doesn't know what it is. I'm not saying that's the case with this specific system, but it's fairly common.
Anyway, yeah, we don't accept submissions based on guessing or speculation.
brndnstffrd
CT
CW1=301
SI CW1=302
CW2=303
Man 1/5/7=101
Man 6/9=102
Brx 40/41=110
Brx 42/44=111
Bkyn 60/61=116
Bkyn 62/68=117
Qns 100/101=127
Qns 102/106=128
etc.
A good place for unconfirmed, but potential info to be posted is in the wiki. Not sure if there is one for this system yet, but since submissions are intended to be confirmed information only, I find the wikis are a good place to share and crowdsource info such as this until it is confirmed accurate.
DaveNF2G
Latham, NY
How would any RIDs be known since this is a new system if it totally encrypted?
They wouldn't. On systems that are partially encrypted, or part-time encrypted, my comment stands. However, one of the previous posters said that the talkgroup was previously in the clear, so there was an opportunity to identify RIDs before encryption.
