You only need the control channels programmed. The system tells the scanner which frequency to go to for each transmission.
Hey Friends I have only Primary Control channels & Alternate Control channels programmed in my Uniden BCD 996p2 For Sacramento Countywide & Davis! The Issue I see is That Un programmed channels will show up when a Unit Keys Up! Such as 853.9000 That Channel is not programmed in the Scanner I think this issue effects the Transmission or am I wrong? Any Advice would be Awesome![]()
If I'm understanding your problem correctly, I believe the scanner is working as it's supposed to.
The rest of the unprogrammed channels are the voice channels that the units actually talk on. Your scanner only needs the control channel frequencies programmed and will know which voice channel frequency to switch to when a unit keys up, whether or not you have them programmed in.
For example, on Site 12 (Countywide Simulcast), there are 30 total frequencies for the site. 4 of the frequencies are control channels. The rest of the 26 frequencies are what the units use as voice channels. Not to complicate things, but the actively unused control channel frequencies (3/4) can also be used as voice channels IF all other voice channels are busy, which is rare.
I'm not sure I understand what you are saying here. You only need to primary and alternate control channels programmed in the scanner. The scanner will switch to the traffic/voice channel on its own to receive the transmission.Question Regarding SRRCS Control Channels
Thanks As Always
If you have the control channels for both sites programmed into the same system you may want to separate them as that can cause the scanner to lock on one site or the other and it will not receive traffic from both sites. Each site should only have 4 frequencies programmed in it.
Thank You SirI'm not sure I understand what you are saying here. You only need to primary and alternate control channels programmed in the scanner. The scanner will switch to the traffic/voice channel on its own to receive the transmission.
Has anyone else noticed that Fire Dispatch A (TGID 3325) seems to hang a lot in the last week or so? The automated dispatch system keys up, announces the fire call, and then holds the frequency and talk group open with dead air for 30-60sec before finally dropping. Seen on my SDS100 and confirmed via watching activity in UniTrunker.
It seems to be affecting FD radios as well because human dispatchers have had to come up on the dispatch channel and ask that a particular apparatus come up on A2 or A3 for traffic far more often than they usually do, presumedly because the FD radios in the field are also holding on DSP A and the dead air.
Thoughts?
851.32500 |
851.43750 |
851.67500 |
851.75000 |
851.82500 |
853.26250 |
Last week the DOJ sent memo out reminding Public Safety Radio Operators of Privacy Laws regarding Transmission of personal info! I think we will see many Agencies Encrypting at least a tac channel in order to comply. I have also noted Hospital's starting to build out new Radio Systems so I think Ambulance to Hospital Communications will also see Encryption! Wonder if this is tha cause of the Local changes?Hello all!
For anyone who uses software to monitor SRRCS, has anyone else noticed that Site 12 seems to only be using 24 of the 30 available frequencies? Even during busy traffic periods, it only seems to be using 24/30 frequencies?
These frequencies seem to have been taken out of Site 12 channel pool. I'm wondering if there's some plans to implement a new site somewhere with these? Or maybe they're just being worked on?
851.32500 851.43750 851.67500 851.75000 851.82500 853.26250
Also, DSDPlus logged Site 14 going in and out of isolated status multiple times earlier this week.
Also, the old "C SP 4" (3739) and "C SP 5" (3741) appear to now be used by Sac RT. I believe it may be for their Elk Grove transit operations, since they took over Elk Grove's service. Elk Grove Transit (e-tran) was using at least two talkgroups on the Fisher Wireless TeamTalk DMR system prior to Sac RT taking over the service.
I can add them to the DB. Did these replace 3317?
Without knowing all the little details involved, the first thing that struck my mind was Phase I vs Phase II (or similar) as earlier systems could only handle 24 frequencies and only the newer systems can handle 30. It's like the system may have 30 frequencies, but its limit is somehow set to 24.For anyone who uses software to monitor SRRCS, has anyone else noticed that Site 12 seems to only be using 24 of the 30 available frequencies? Even during busy traffic periods, it only seems to be using 24/30 frequencies?
Hello all!
Perhaps they need space for microwave upgrades?One month later, and this still appears to be the case, only 24/30 frequencies used in the channel pool. Anyone know what's up?
Six frequencies=six repeaters. That's a whole rack in the vault. I'm wondering if they needed room for something else in their tower sites.
