Akiralsdr
Brazil
Can anyone help me out ? everytime i try to open SDR# appear this message
i already installed everything, Zadig, .NET and it keeps like this.
rabbit108
S.E. VA
Hello, Akiralsdr; welcome to the forum.
I got the same message because I had downloaded the installer, but had not installed .NET.
If you have installed .NET, it should show up here in settings:
or here in Control Panel:
CanesFan95
Analog already is interoperable.
FL
Same here. Just had the exact same issue. There's 2 different versions. One called "x64" and "x86", whatever that means. The download page doesn't explain it, which is not helpful. So just try one and if it doesn't work, then do the other one and it should work.
CanesFan95
FL
Oh, and when you get SDR# working (supposedly), it will be BUGGY.
rabbit108
S.E. VA
The download page has a direct link to the correct version:
which takes you here:
monty22001
Latest version of SDR# are crashing like crazy.
#1732 seems like the last version that is both stable and works with Frequency Manager.
rabbit108
S.E. VA
Yeah, I like v1732. I can't use any version later than 1784 for the Airspy R2 SDR and Spectrum Spy software. Spectrum Spy isn't even listed in later versions.
rabbit108
S.E. VA
Learning new software can be difficult, but you are not expected to know everything about it at the beginning. This is called "climbing the learning curve." Some users consider working with software fun. I don't; I consider it challenging. But, I do get satisfaction from meeting the challenge and getting the software to work.
On the download page, Airspy says that .NET 5 Desktop x86 Runtime is a Pre-requisite. Translation: If you don't do this, SDR# will not work.
From Wikipedia:
x86 is a term used to describe a CPU (Central Processing Unit in your computer) instruction set compatible with the Intel 8086 and its successors, including the Pentium and others made by Intel and other companies.
x86 refers to a 32-bit CPU and operating system while x64 refers to a 64-bit CPU and operating system.
SDR# is 32-bit software, so it must have 32-bit .NET Runtime.
Older computers only had 32-bit CPUs. Newer computers have 64-bit CPUs, so they can run 32-bit and 64-bit software.
Akiralsdr
Brazil
i bought a sdr a long time ago and didnt work in my computer but and i kinda feel ok because i connected in my cellphone and used Sdrtouch but now i want to connect directly to my computer and use normaly but... i think Zadig is trolling me lol. i opened the sdr and found a chip saying 2832u in it but Zadig identified as 2838u, this can mistake can make the sdr to not work properly ?
rabbit108
S.E. VA
I think you should be OK. My RTL-SDR.COM V3 SDR dongle does something similar with Windows 10. I used the Zadig driver that came with SDR# v1810:
and the Device manager looked like this:
Akiralsdr
Brazil
i have it for a long time now and i cant connect it in my computer, i installed Zadig, installed drivers always appers error or no sdrs found. example below
softwares that i tried using (SDR#, SDRuno, Virtual Radar)
rabbit108
S.E. VA
What is the name of the old rtl-sdr device you are using?
Did you open install rtlsdr?
Did you use the Zadig driver that comes with SDR#? For me, both windows in the red rectangle say the same thing:
Does your device show in the Device Manager?
Open SDR#:
rabbit108
S.E. VA
Sometimes it is necessary to remove and then reinsert the device after setup if your computer doesn't recognize the device. You should hear a USB sound when you do that each way.
I use a USB extension cable to connect my device to my laptop. It reduces the strain on the computer USB connector from the weight of the dongle..
Akiralsdr
Brazil
Open SDR#:
i did everything, its a generic ones.. (DVB-T+DAB+FM)
nothing is working for me
