Wackyracer
use sdr# 1732...I had a hell of time getting it to work in sdr# 1810
merlin
DN32su
i bought a sdr a long time ago and didnt work in my computer but and i kinda feel ok because i connected in my cellphone and used Sdrtouch but now i want to connect directly to my computer and use normaly but... i think Zadig is trolling me lol. i opened the sdr and found a chip saying 2832u in it but Zadig identified as 2838u, this can mistake can make the sdr to not work properly ?
View attachment 101673View attachment 101674
Reason is your chip is a Chinese clone. Zadig will install the driver for it but I think you need a script or it is complicated. the driver will work but not without minor flaws.
merlin
DN32su
i have it for a long time now and i cant connect it in my computer, i installed Zadig, installed drivers always appers error or no sdrs found. example below
softwares that i tried using (SDR#, SDRuno, Virtual Radar)
Make sure you have the right USB port selected, I ran into that before.
rabbit108
S.E. VA
i did everything, its a generic ones.. (DVB-T+DAB+FM)
nothing is working for me
Sorry to hear that. Maybe you should try version 1732 of SDR# as suggested by
download version 1732 from this site:
Index of /software/SDRSharp
extracted zip folder
extracted file
Connect SDR dongle to USB port of computer and make sure you are connected to the internet.
Click on install-rtlsdr:
If you are not connected to the internet when you click on install-rtlsdr, this is what you will see:
If you are connected to the internet when you click on install-rtl-sdr, you should see this:
Install Zadig driver:
Check Device Manager for your device:
If you have a problem, please show us a screenshot of your computer screen using prtscr key, paste into Paint, and make it an attachment to your post.
In order for us to help you, we need a screenshot to see the problem. Just saying "it doesn't work" isn't enough.
Akiralsdr
Brazil
i did everything, downloaded Zadig, installed all drivers and nothing is working, probably is with my pc idk, when i connect to my cellphone by otg cable works well
rabbit108
S.E. VA
That's good, but you must leave Radio there and have Source below it. Don't X-Out Radio. Like this:
You need to have Radio there for its Settings.
rabbit108
S.E. VA
Push the Play triangle, then click on the wheel to bring up the RF Gain control:
I have selected NFM mode for this signal and moved the Zoom control up to make the signal wider:
rabbit108
S.E. VA
Is the dongle in the Device Manager?
If not, then start the setup again from the beginning.
If that doesn't work, your dongle probably doesn't work with SDRsharp software.
You need to order an RTL-SDR.COM V3 dongle when it becomes available:
Buy RTL-SDR Dongles (RTL2832U)
