SDRTrunk - p25 decoder test release
DSheirer
Fulton, NY
It`s not on RadioReference. How can i check if its Moto Type II or not ?
If you look at the Moto Type II control channel in the zoomed in spectral display, it should look like bat wings forming spikes/ears at each of the two FSK signalling frequencies. A P25 control signal will visually look the same as the P25 traffic channel signals, with an overall rounded appearance.
If you want to compare by listening, there are recordings here:
Motorola Type II - Signal Identification Wiki
http://www.sigidwiki.com/wiki/Project_25_(P25)
sameehosen
HAMPORG
I thank everybody
It failed to build jmbe-x.x.x.jar file systems on Windows and Linux
Would you allow place the file is ready for download ???
It will work on another ???
Thank you
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I thank everybody
Thank you
No. As mentioned before, you must compile JMBE yourself. Nobody is going to make that publicly available to you.
Mike
DSheirer
Fulton, NY
I thank everybody
Thank you
Can you post the error message that you're seeing? Maybe we can help you to build the library.
sameehosen
HAMPORG
Thank you for your attention and assistance
When activating make_jmbe_library_windows file
A message appears and disappear quickly I could not read it
It was create a folder named jmpe inside another folder named (.get)
Jmpe put the folder inside the folder sdrtrunk_20160101_0929_0.2.0. beta2
Then ran View run_sdrtrunk_windows
Get those messages
C:\Users\sana\Desktop\sdrtrunk_20160101_0929_0.2.0.beta2>java -XX:+UseG1GC
-cp "SDRTrunk.jar;*;libs/*;config/*;images/*" gui.SDRTrunk
23:26:42.407 INFO gui.SDRTrunk -
23:26:42.417 INFO gui.SDRTrunk -
23:26:42.418 INFO gui.SDRTrunk - **********************************************
23:26:42.419 INFO gui.SDRTrunk - **** sdrtrunk: a trunked radio and digital dec
oding application ***
23:26:42.420 INFO gui.SDRTrunk - **** website: https://github.com/dsheirer/sdr
trunk ***
23:26:42.420 INFO gui.SDRTrunk - **********************************************
23:26:42.421 INFO gui.SDRTrunk -
23:26:42.422 INFO gui.SDRTrunk -
23:26:42.441 INFO gui.SDRTrunk - Home path: C:\Users\sana\SDRTrunk
23:26:42.451 INFO p.SystemProperties - SystemProperties - loaded [C:\Users\sana\SDRTrunk\SDRTrunk.properties]
23:26:42.452 INFO p.SystemProperties - SystemProperties - application propertie
s loaded [C:\Users\sana\SDRTrunk\SDRTrunk.properties]
23:26:42.471 INFO settings.SettingsManager - SettingsManager - loading settings
file [C:\Users\sana\SDRTrunk\settings\settings.xml]
23:26:43.025 INFO playlist.PlaylistManager - PlaylistManager - loading playlist
file [C:\Users\sana\SDRTrunk\playlist\playlist.xml]
23:26:43.783 INFO s.r.RecordingSourceManager - RecordingSourceManager - discove
red [1] recording configurations
23:26:43.837 INFO source.mixer.MixerManager - loading system mixer devices
[LOADED] Output: Primary Sound Driver CHANNELS: [MONO, STEREO]
[LOADED] Output: Speakers / Headphones (IDT High Definition Audio CO
DEC) CHANNELS: [MONO, STEREO]
[LOADED] Output: DAX RESERVED AUDIO RX 1 (DAX RX Audio) CHANNELS: [M
ONO, STEREO]
[LOADED] Input: Primary Sound Capture Driver CHANNELS: [LEFT, RIGHT
, MONO]
[LOADED] Input: DAX Audio RX 1 (DAX RX Audio) CHANNELS: [LEFT, RIGH
T, MONO]
23:26:44.231 INFO source.tuner.TunerManager - LibUSB API Version: 16777474
23:26:44.234 INFO source.tuner.TunerManager - LibUSB Version: 1.0.18.10866
23:26:44.366 INFO source.tuner.TunerManager - discovered [12] attached USB devi
ces
23:26:44.384 INFO source.tuner.TunerManager - usb device [8087:0024] NOT LOADED
: Unknown Device
23:26:44.385 INFO source.tuner.TunerManager - usb device [8086:1C26] NOT LOADED
: Unknown Device
23:26:46.246 INFO source.tuner.TunerManager - usb device [0BDA:2838] LOADED: RT
L2832 SDR/R820T #00000001
23:26:46.247 INFO source.tuner.TunerManager - usb device [1033:0194] NOT LOADED
: Unknown Device
23:26:46.248 INFO source.tuner.TunerManager - usb device [0A5C:21BC] NOT LOADED
: Unknown Device
23:26:46.249 INFO source.tuner.TunerManager - usb device [1BCF:2880] NOT LOADED
: Unknown Device
23:26:46.250 INFO source.tuner.TunerManager - usb device [093A:2510] NOT LOADED
: Unknown Device
23:26:46.251 INFO source.tuner.TunerManager - usb device [8087:0024] NOT LOADED
: Unknown Device
23:26:46.253 INFO source.tuner.TunerManager - usb device [1D6B:0001] NOT LOADED
: Unknown Device
23:26:46.255 INFO source.tuner.TunerManager - usb device [0781:5567] NOT LOADED
: Unknown Device
23:26:46.258 INFO source.tuner.TunerManager - usb device [0BDA:0138] NOT LOADED
: Unknown Device
23:26:46.260 INFO source.tuner.TunerManager - usb device [8086:1C2D] NOT LOADED
: Unknown Device
23:26:47.137 ERROR o.j.swingx.JXMapViewer - JXMapViewer could not load 'loading.
png'
23:26:48.020 DEBUG m.d.p25.P25_C4FMDecoder - Demod Filter tap count:115 coeffici
ents:[7.73343E-6, 1.5951486E-5, 1.6646947E-5, 4.765035E-12, -4.119169E-5, -1.082
7376E-4, -1.9452887E-4, -2.8466267E-4, -3.5633767E-4, -3.8371581E-4, -3.4254737E
-4, -2.1597858E-4, -2.4709793E-10, 2.9260828E-4, 6.3084206E-4, 9.6722925E-4, 0.0
012429629, 0.001396024, 0.0013713323, 0.0011314928, 6.6640705E-4, -1.580838E-10,
-8.0746686E-4, -0.0016624933, -0.0024471341, -0.0030329088, -0.003298436, -0.00
31485925, -0.0025326181, -0.0014583424, -2.7325373E-10, 0.0017022766, 0.00345226
52, 0.005016531, 0.00615089, 0.0066318265, 0.006289246, 0.005036523, 0.002893666
5, -2.5332886E-10, -0.0033862302, -0.0069025722, -0.010110914, -0.012537664, -0.
013721873, -0.013266318, -0.01088598, -0.006448268, 1.2080243E-9, 0.008222612, 0
.017802909, 0.028171724, 0.038652048, 0.048516367, 0.057051066, 0.063621484, 0.0
67730695, 0.0690661, 0.06752871, 0.063242316, 0.056541167, 0.047938067, 0.038075
72, 0.027667023, 0.017430158, 0.008025411, 1.1753407E-9, -0.0062537827, -0.01052
3434, -0.012782225, -0.01317676, -0.011998339, -0.009642087, -0.0065589, -0.0032
05794, -2.3892321E-10, 0.0027184905, 0.004712615, 0.0058603357, 0.00615297, 0.00
5681273, 0.004611991, 0.0031584892, 0.0015495288, -2.474136E-10, -0.0013130674,
-0.00226692, -0.002800759, -0.002914719, -0.0026613004, -0.0021312358, -0.001436
2801, -6.91582E-4, -1.3413513E-10, 5.597347E-4, 9.3989336E-4, 0.001125341, 0.001
1303112, 9.914588E-4, 7.5871305E-4, 4.8557657E-4, 2.204238E-4, -1.8156904E-10, -
1.5416017E-4, -2.3622996E-4, -2.538593E-4, -2.2398747E-4, -1.6771416E-4, -1.0529
3584E-4, -5.2179752E-5, -1.6755872E-5, 1.475824E-12, 3.065221E-6, 6.390127E-7, 8
.596976E-7]
23:26:48.103 ERROR m.d.p.a.P25AudioModule - Couldn't find/load JMBE audio conver
sion library
23:26:48.274 INFO module.log.EventLogger - Creating log file:C:\Users\sana
\SDRTrunk\event_logs\20160318_232648_New_System_New_Site_New_Channel_binary_mess
ages.log
23:26:48.326 INFO module.log.EventLogger - Creating log file:C:\Users\sana
\SDRTrunk\event_logs\20160318_232648_New_System_New_Site_New_Channel_decoded_mes
sages.log
23:26:48.331 INFO module.log.EventLogger - Creating log file:C:\Users\sana
\SDRTrunk\event_logs\20160318_232648_New_System_New_Site_New_Channel_call_events
.log
23:26:48.409 DEBUG m.d.p25.P25_C4FMDecoder - Demod Filter tap count:115 coeffici
.596976E-7]
23:26:48.497 INFO module.log.EventLogger - Creating log file:C:\Users\sana
ages.log
23:26:48.503 INFO module.log.EventLogger - Creating log file:C:\Users\sana
sages.log
23:26:48.508 INFO module.log.EventLogger - Creating log file:C:\Users\sana
.log
23:26:48.544 DEBUG m.d.p25.P25_C4FMDecoder - Demod Filter tap count:115 coeffici
.596976E-7]
23:26:48.658 INFO gui.SDRTrunk - starting main application gui
DSheirer
Fulton, NY
Sameehosen,
You have a couple issues with your setup.
1) Download the latest Version 0.2.0 beta 8 software: https://github.com/DSheirer/sdrtrunk/releases
2) When using P25/C4FM decoder, you can't use the analog aux decoders. Uncheck 'Enabled' and hit save to stop the channel. In the 'Aux' tab, uncheck the Fleetsync, LJ1200, MDC1200 and Tait 1200 decoders and then hit save. Finally, click 'Enabled' and hit save to restart the channel.
3) Download the latest JMBE builder software Version 0.3.2 Update 1: https://github.com/DSheirer/jmbe/releases
4) Unzip the JMBE builder and execute the build script. The script will pause at the end allowing you to see if there were any errors. Please post those errors here.
cheers,
Denny
sameehosen
HAMPORG
This is a picture of the message after you open the file make_jmbe_library_windows
To stay about a minute and then this message will disappear and produce a folder named jmpe and inside a folder as the last .get
BM82557
Berkeley Co WV
Have you downloaded and installed the Java Development Kit for your version of Windows and set the JAVA_HOME variable?
dave3825
Suffolk County NY
I to am having issues. I did download the kit. How do you set the JAVA_HOME?
I ran the builder and it tells me,
STEP 1 FAILED add the jdk installation to your PATH environment variable. Bla Bla Bla
My bin is in C:\Program Files\Java\jdk1.8.0_74\bin
the only path I see is set to the same.
Below is pic showing my installed java location, my PATH, the file jmbe-interface-0.3.2.jar in my sdrtrunk folder, and the builders error message.
sameehosen
HAMPORG
That's what got it too
Despite Preparatory to the variables of the environment
dave3825
Suffolk County NY
Mine says JAVA_HOME and C:\Program Files\Java\jdk1.8.0_74. Are you saying the 64 bit is screwed up?
DSheirer
Fulton, NY
Two Java setup tasks are required to build the JMBE library:
1) Add the JAVA_HOME environment variable that points to your Java JDK installation (without the bin directory)
JAVA_HOME = C:\Program Files\Java\jdk1.8.0_74
This is specific to your computer - where you installed the JDK
2) Edit your PATH environment variable to include your JDK bin directory. These are just shortcuts for windows to find the program by its name instead of forcing you to type the full directory path. Your path entry for java should be the same directory that you set for JAVA_HOME, but with a /bin/ on the end of it.
PATH = SOME_PATH_A;SOME_PATH_B;C:\Program Files\Java\jdk1.8.0_74\bin;SOME_MORE_PATH_C;...
You can then test that your PATH variable is setup correctly by typing both commands::
Code:
java - version
javac - version
NOTE: if you previously setup your path variable to point to the Java JRE, you have to change it to point to the Java JDK version. The JDK version has everything needed to run java programs like sdrturnk and everything needed to compile/build programs like the JMBE library. The java program runs your software and the javac program compiles your source code.
Denny
sameehosen
HAMPORG
Well Well
I thank everyone for assistance
I try my all windows systems
Now on windows10 64 bit system
After application of the environment variable, as you suggest
It has been successfully building jmpe View
Volume jmbe_builder
And it did not succeed to build the file from the folder
jmbe-0.3.2.update1
These pictures show it
Is this enough?
Is there any tips before the start of the work I am excited much?
BM82557
Berkeley Co WV
You need to copy jmbe-0.3.2 (executable Jar file) into the same windows folder folder you have SDRTRunk installed in. This is normal, it has to be manually done.
sameehosen
HAMPORG
My friend DSheirer
We have prepared a lot and try readied loaded more than once, and the result's the same
The build file successfully during my use of the folder jmbe_builder
When I use the file located in the jmbe-0.3.2.update1 gives this message
On the whole I thank you for attention and assistance is already underway workout program
Please accept my respect
dave3825
Suffolk County NY
S U C C E S S
Everything was set as you described above. Java worked but javac did not. Searched pc for javac and it yeilded no results.
GOT FED UP ! ! ! !
TOOK ACTION ! ! ! !
UNINSTALLED ALL JAVA ! ! ! !
Started over.... Installed this java Download Free Java Software
Then this Java SE Development Kit 8u74 for 64bit Java SE Development Kit 8 - Downloads
Now I have these as PATHS,
JAVA_HOME = C:\Program Files\Java\jdk1.8.0_74\
And my PATH = C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Java\jdk1.8.0_74\bin\
I ran the Jmbe builder. It did its thing...said failed to load org.s1f4j.impl.StaticLoggerBinder bla bla bla. (see pic below)
I copied jmbe-0.3.2.jar over to sdrtrunk folder anyway.
Loaded sdrtrunk, says jmbe audio conversion library successfully loaded.
A W E S O M E I have sound for the first time... Wow I have clear digital audio being decoded. Sounds pretty good..
I also have audio when there is ENC Is there a way to lock out Enc audio?
Thanks to all for your input, suggestions and help....
