SF Rebanding?
Ameriscan
Phoenix, Az
re: SF Rebanding
so. as of 7:35am, the control channels are both gone again for SFFD? both the primary and alternate are not working, any ideas?
Radiobern
San Leandro
They added 851.4 as a new control channel. I re-ran Unitrunker and it is still marking 851.15, 851.4 and 851.425 as control channels. They just switched back to 851.425 again just now at 9:30. I suspect we will see some changes and tweaks as they reband the system.
For those with 996XT issues, I was able to get 3 working using the Freescan software. If you would like for me to take a look at yours, I am in Hayward.
Ameriscan
Phoenix, Az
Hey does Unitrunker work on the 996xt? is it easy to set up? im right in the middle of the city, should be able to pick up the info to and help out
Radiobern
San Leandro
Since I don't own a 996XT, I can only provide general steps. Note that UniTrunker is used to analyze the system, it does not program your scanner.
1. Dowloand and install UniTrunker here: Index of /download.
2. Connect your 996XT to your computer first.
3. Now, open UniTrunker you just installed.
4. Create a new receiver, select "Inline".
5. On the new window that pops up, select "996XT" under model.
6. Configure the serial port settings as necessary, make sure they match Device Manager in Windows.
7. Tune your 996XT to an active control channel and a new window should pop up.
8. Click the various tabs to see current activity on the system, system frequencies and which channels are marked as control channels, etc.
9. Use this table (http://home.ica.net/~phoenix/wap/TRUNK88/Motorola Channel Numbers.txt) to convert from LCN to frequency. Remember to look at the rebanded column.
See how based on the control channel, it can automatically find all the voice frequencies in the system? This is why I keep saying you only need to program in the control channels and the scanner will do the rest. As long as you have the rebanded tables and necessary settings put in correctly, your scanner will do the rest. There really isn't a point to keep track of which voice frequencies are active. It is important to see which channels are marked as control channels so when they switch, we won't be left in silence.
officer_415
SF Bay Area
CERS (Citywide Emergency Radio System)
851.1500
851.4000
851.4250 - control channel
851.5875
851.7625
851.8125
852.0625
852.0875
852.2125
852.2625
852.3875
852.6750
852.8375
853.0875
853.2250
853.4125
853.4375
853.6250
853.6500
853.7875
853.8875
PWRS (Public Works Radio System)
851.2500
851.6125
852.3625 - control channel
852.8625
853.2500
853.8125
856.2375
Radiobern, can you run Unitrunker on PWRS and see if anything has changed with the control channels?
Radiobern
San Leandro
For PWRS, UniTrunker indicates 852.3625, 852.8625, 853.8125, and 853.25 as control channels. It also indicates this is an 8 channel system.
For CERS, it indicates it is currently a 35 channel system. The same control channels 851.15, 851.4 and 851.425 are marked as such. From running UniTrunker for just a few minutes, it looks like there is no more voice activity in the 866-868 range.
officer_415
SF Bay Area
Thanks, I'm getting the same results the old-fashioned way. I just saw 857.2375 come up on PWRS, bringing us to 8 channels as indicated. 35 channels sounds like a lot for CERS, which has previously been a 23-channel system. I'm up to 21 channels from observation, with just 2 outstanding frequencies on my list (851.1250 and 858.2375). I haven't seen these come up, but maybe someone else has...
Ben96cal
Livermore, Ca
re: sf
Since they've started this BS today I'm getting some strange CC bleedthrough of some type on 852.0875. It usually pops up on tg 14832. I'll hit scan and hit goes away for a couple minutes and comes back.... it doesn't sound like a normal CC sound, higher in pitch and faster...
w0web
San Francisco Bay Area
You know who I feel sorry for are the folks who bought the Home Patrol Scanner and are still waiting for the database to catch up with the rest of us...
officer_415
SF Bay Area
The database has the control channels and indicates that it is a rebanded system, so the HomePatrol should work with current programming.
Ameriscan
Phoenix, Az
using the control channels we have been talking about, 851.4250 zero transmissions for over 10 mins. do we have another CC change? again? any ideas anyone?
Ameriscan
Phoenix, Az
STARTING to get some transmissions in, but off and on, maybe they are doing some adjusting again lol..
