Wake County P25 switch
The Wake system depreciated wasn't P25 it was Motorola Type II, but you are correct that everything is on the Cary/Wake system. However, if you want to hear the Wake traffic you only program in Site Two as @pjb3589 has done. I'm not sure why he is having issues, I hear all traffic, including WSO, fine, maybe it has something to do with the SDS filters. I do not have the SDS so perhaps you can reach out to the Uniden forum and ask about filters. The other thing may be what TGs you have programmed, RFD/Wake fire uses talkgroups 46800-46838 and 46940-46969 mostly.
Chris0516
Pittsboro, North Carolina
Instead of my trying to figure out Site 1 and Site 2, within the same system. I split it in to two systems. I did the same thing with Durham/Fayetteville.
PKnight56
If everything is programmed right you should hear everything fine.
WCSO is facing critical staffing issues right now. In unincorporated areas (everywhere that's not a city/town/municipality with its own PD) they are supposed to have 28 deputies covering a population of 1.5 million. However, on a good day/night, they will only have 7-10. Their traffic is always diminished since other agencies pick their calls up.
jthorpe
Yep. They are in survival mode
Chris0516
Here's how I have my system programmed for WSO - is this correct?
According to the RR database-
46880 b720 D WSO DISP 1 WSO DISP 1 Law Dispatch
46881 b721 D WSO DISP 2 WSO DISP 2 Law Dispatch
46882 b722 D WSO DISP 3 WSO DISP 3 Law Dispatch
46883 b723 D WSO DISP 4 WSO DISP 4 Law Dispatch
46884 b724 D WSO PAT 1 WSO PAT 1 Law Dispatch
46885 b725 D WSO PAT 2 WSO PAT 2 Law Dispatch
46886 b726 D WSO PAT 3 WSO PAT 3 Law Dispatch
46887 b727 D WSO PAT 4 WSO PAT 4 Law Dispatch
Regardless of the fact(in your graphic), you have the Patrol grouping first and the Dispatch grouping second. The major problem, is. Your TG #'s are ALL wrong. Also, Check your Control Channels. If you put in Cary's Control Channels' in for Wake, that would be an additional problem. Here are Wake's Control Channels-
851.0375 851.150 851.200 851.2625 851.2875 851.4625 851.5375 851.625
851.650 851.7625 851.9625 852.150 852.2625 852.650 852.7875 852.9625
853.150c 853.200 853.2625 853.4625c 853.650 853.7625 853.925c 853.9625c
855.4625
pjb3589
855.4625
You're right - thanks for pointing that out. What's interesting is that I never manually configured them - I just pulled the database from RR using the Uniden Sentinel software. I did just pull the latest update and they are correct now so I've gone ahead and updated my scan list.
I figured it was something I had configured wrong. Thanks again!
Chris0516
I'm glad I could help. (y)
jimmymac434
raleigh nc
I've got a question . . what am i doing wrong .. my scanner (bcd325p2) stops on the talkgroup, but i cant hear anything .. only does this on a few t/g's, the raleigh fd and wake co fd alert channels are good, along with a few tac channels, i notice alot on raleigh pd and wake so.
OnYourSix
NY --> NC
It may be encrypted channels. What TG is it?
spencerwww
All fire is hnceyptee right only.raleugh pd and sherffic tags encrpyred are special ops and drug channels i was in wake and heard them talking on carting channels they had big call so switched ops
Do you have it programmed correctly? You only want to program the control channels for SITE TWO if you want to hear Wake/Raleigh, do not include site one. For Cary/Apex/Morrisville only program site one. You need to keep the two in separate systems or you will have trouble receiving them.
LoneOwl
Missing Raleigh Police Dispatch
I'm at wit's end. I just happened to notice the only RPD dispatches I'm getting are 47050, 47051,47053.
NOTHING from 47052, 47054, or 47055.
These are the only ones I've checked out. There may be other TGs missing.
Using Site 2 freqs, & re-verified freqs.
Any suggestions/help?
