Wake County P25 switch
scannerpro
I am just seeing this thread, been inactive for awhile what is wake county transferring over to Phase 1 or Phase 2 P25?
Wake county switched to P25 Phase 1 on October 27 2021, it is now on the Cary Core, but separate from the Cary system, and it is now listed under the Cary/Wake system in the database.
scannerpro
Thank you so much. I can still use my Whistler 1040. I need to invest in a Phase 2 scanner here soon.
K4XOR
After re-aiming the Yagi I've had some good progress! While it's still not where I want it, I'm getting decent audio now. Clicks and pops but I can follow some conversations. Decode rate bounces around from 80-98%. Here's the approximate orientation:
What really helped was directly connecting the scanner to the antenna in the attic, and slowly sweeping in the direction of my target tower by-hand. Then locking it in to position. Once I felt good about my aim I hooked the scanner back up in its typical spot downstairs.
I'm glad tower 3 is working this well, because that's also a VIPER tower. I'm getting perfect decodes from that VIPER site, as well as from the Wake North Durant Rd site.
Might end up getting on SDR and splitting this antenna to that and the scanner: SDR for Wake P25 and the PSR500 for VIPER. I'll keep playing with this for now though, to see if I can eek out that last 5-10% decode rate! :cool:
drayd48
If you are wanting an RTL-SDR for the Wake system, you will need to get two of them because they only cover a 2.4 mhz frequency range. The Wake county frequency range is 4.425 mhz.
N1FJB
Morrisville, NC
I have been inactive for quite some time. I updated my library on my ws-1080 (pro-668) and still not hearing raleigh pd? any thoughts? I live in morrisville top of the hill chapel hill road and morrisville parkway? I am very confused as to what I need to do to make my scanner work again.
JohnDistai
If I remember correctly, there was a change where RPD moved to Cary/Wake Simulcast. When I updated my programming, I think I eliminated all the Cary-related talk groups, and possibly the Cary-related frequencies from the list. Experiment with those variables and see what happens.
When you import the new Cary/Wake P25 system you need to create two systems, one will have ONLY Site One for Cary and those TGs, the other will have ONLY Site Two for Raleigh and Wake County and those TGs. Currently running 4 whistler scanners TRX-1, WS-1080, and WS-1098, plus Unication this way and it works fine.
N1FJB
Morrisville, NC
When I import wake county it puts both sites into one group. Do I need to do two imports and delete wake out of one and Cary out of the other? Not sure how you are saying you did it? I don’t usually create my own. I just use the preprogrammed stuff in the scanner. Would you be available for a call?maybe some time? I am a ham and I am good on qrz. You could email me and we exchange contact info.
JohnDistai
Yes, import twice, cut and trim twice if you want both Cary and Raleigh systems. I only have the one for Raleigh.
In the trunked Radio System tab select the system (Click on it so it is highlighted), select DUPLICATE button on the right. Go to the first system lockout Site 2, Go to the second system and lockout Site 1.
If you have issues DM me.
After speaking with a knowledgeable person within the RFD/Wake EMS, they informed me the encrypted Raleigh Fire and Wake EMS talkgroups were added when the new P25 system came online due to issues encountered a few years back during protests downtown Raleigh. These TGs are apparently full time encrypted and used mainly for special events involving EMS or Fire. Wake EMS TGs include 46971, 46975, 49776 and 46977, while the RFD TGs are 47027, 47028 and 47028. These have been submitted to RR database.
OnYourSix
Were these the TG's you were missing previously?
Awz1287
Monmouth County, NJ/now Wake County, NC
I am trying to set up my 436hp, I haven't used it in about 8-9 months. I turned it on and got nothing. I did a search and I see that there is a new system.
I updated my database and my list on the scanner, but so far I am not getting any transmissions.
Do I need to update anything else?
I deleted the old stuff in the list and added the towns of holly springs and fuquay Varina from the p25 cary/wake tab.
Make sure you have it entered as two separate systems one for Cary and only use site one, the other for Wake Co and use only site two.
Chris0516
Pittsboro, North Carolina
Going on what N1GAW said. Here are the CC's:
Cary- 856.6625c 857.9875a 858.9875a 859.9875a
Wake- 853.925c 853.150a 853.4625a 853.9625a
Sounds like the Cary/Wake P25 system is testing new dispatch radio IDs on RFD Batt 4 TG 46954 today. There is simulcast broadcasts from various TGs, both RPD and Fire/EMS using new dispatch RIDs.
For those interested, I have just submitted 25 new TGs to the Cary/Wake system for the Wake County side. Hopefully they won't take long to be added. Some, as marked below, have encryption, most do not. They included the following;
46897, WSO CID 6, WSO CID 6, LAW TALK, WAKE SHERIFF
46898, WSO CID 7, WSO CID 7, LAW TALK, WAKE SHERIFF
46899, WSO CID 8, WSO CID 8, LAW TALK, WAKE SHERIFF
46900, WSO CID 9, WSO CID 9, LAW TALK, WAKE SHERIFF
46915, WSO TRANSP2, PRISONER TRANSPORT, LAW TAC, WAKE SHERIFF
46935, WSOSRT OPS1, SHERIFF SRT OPS, LAW TAC, WAKE SHERIFF
46936, WSOSRT OPS2, SHERIFF SRT OPS, LAW TAC, WAKE SHERIFF
46937, WSOSRT OPS3, SHERIFF SRT OPS, LAW TAC, WAKE SHERIFF
46938, WSOSRT OPS4, SHERIFF SRT OPS, LAW TAC, WAKE SHERIFF
46939, WSOSRT OPS5, SHERIFF SRT OPS, LAW TAC, WAKE SHERIFF
47005, GOTRIANGLE MX2, GOTRIANGLE TRANSIT MAINTENANCE CH 2, TRANSPORTATION, GOTRIANGLE TRANSIT
47033, RFD INV, RALEIGH FIRE INVESTIGATORS, FIRE-TALK, RALEIGH FIRE
47128, WTCC PD 4, WTCC POLICE 4, LAW TAC, WAKE TECHNICAL COMMUNITY COLLEGE
47129, WTCC PD 5, WTCC POLICE 5, LAW TAC, WAKE TECHNICAL COMMUNITY COLLEGE
47141, FV FIRE COMM, FUQUAY VARINA FIRE COMMON, FIRE TALK, TOWN OF FUQUAY VARINA
47161, FV PD OPS, FUQUAY VARINA POLICE, LAW TALK, TOWN OF FUQUAY VARINA
47172, GAR COMMON, GARNER COMMON, MULTI TAC, TOWN OF GARNER
47178, GAR PD 2, GARNER POLICE CHANNEL 2, LAW TALK, TOWN OF GARNER
47179, GAR PD 3, GARNER POLICE CHANNEL 3, LAW TALK, TOWN OF GARNER
47181, GAR PD INV1, De, GARNER POLICE INVESTIGATIONS, LAW TAC, TOWN OF GARNER
47182, GAR PD INV2, De, GARNER POLICE INVESTIGATIONS, LAW TAC, TOWN OF GARNER
47183, GAR PD INV3, De, GARNER POLICE INVESTIGATIONS, LAW TAC, TOWN OF GARNER
47251, WF PD INV1, De, WAKE FOREST POLICE INVESTIGATIONS, LAW TAC, TOWN OF WAKE FOREST
47263, WF PUBSVC, WAKE FOREST PUBLIC SERVICES, MULTI TALK, TOWN OF WAKE FOREST
47273, ZEBWEN FD COMM, ZEBULON/WENDELL FIRE COMMON, FIRE TALK, TOWN OF ZEBULON
