Where do I download sentinel software for the sds100
racing1
A direct link would be greatly appreciated. This is my first uniden scanner coming from the whistler trx 1.
Sent from my SM-G965U using Tapatalk
jonwienke
More Info Coming Soon!
VA
Right-click on the folder, Properties, Security tab.
racing1
This is the error I'm getting
srpawski
Can saved scan list files for the 436 be directly written to the SDS 100, or does a new list need to be made? I know the ones for the 436 and 536 were interchangeable.
jonwienke
VA
Right-click on the Sentinel icon, Run as Administrator.
racing1
Thanks. I'm up and running. As I said I'm completely new to uniden entirely including their scanners. What should I read up on before I get it?
phask
zanesville
Can I use the auto locate feature without an antenna?
No - it uses reception of P25 systems to determine location, usually zipcode is closer - or manually enter your lat/lon.
racing1
Oops I didnt mean antenna I meant gps
UPMan
In Memoriam
Arlington, TX
GPS and Auto Locate are two completely different methods that use completely different technology. If you have a GPS, you really have no reason to ever use Auto Locate. I've used Auto Locate when I go to another city and don't know the local zip code (and am too lazy to ask Google).
racing1
How do I properly update the firmware without corrupting the scanner? I read your suppose to, download the update,it writes to scanner, you disconnect the scanner from windows via safely remove hardware,THEN while leaving it plugged in I turn the scanner back on and it updates automatically? Does this sound correct?
UPMan
In Memoriam
Arlington, TX
Read the PC screen prompts. Basically what you said, but it tells you what to do.
