2018 VHF Low Band Logs
edweirdFL
Daytona Beach, FL
I can confirm that Pike Electric is using 49.58 on their trucks that are doing work in the Daytona Beach area. Usage is infrequent.
nd5y
Wichita Falls, TX
43.2400 151.4 Police Dispatch - repeater output
43.3000 131.8 Fire/EMS Dispatch - repeater output, related to 43.24, Eastern Time Zone, steady tone following transmissions
These are Part 22 auctioned paging channels (43.2 - 43.66 and 35.2 - 35.66). This is the first time I have noticed public safety use of the low band paging channels.
Is the steady tone 2175 Hz tone remote? It might be voting receiver or remote site links.
Maybe the user got the frequencies from https://selectspectrum.com/3543.html
kkn50
Long Time Member
Hill Country Village, Texas
I don't know the tone frequency. I will save the audio file if I hear them again and post it.
Yes, Part 22 channels. The transmissions I heard on 43.24 and 43.30 are related, sounds like part of the same system. The only landmarks I heard were "Desiree Road" and "Santo Domingo Road". I think the band was open to the west.
These are Part 22 auctioned paging channels. Is the steady tone 2175 Hz tone remote?
mancow
N.E. Kansas
So where is cow's low band logs using his hot new antenna?
I have the COM201B back up now after finally fabricating a missing top portion out of the threaded part of an OE fiberglass section and an aluminum tube. It's working great now. I'm hearing 6 meter repeaters now and stuff all across lowband.
46.460 seems to be one of the strongest.
prcguy
Gee, where could a fella get one of those antennas?
prcguy
They are expensive new but the performance is way better than you can imagine for a small-ish ground plane. Its only a dB or two down from a resonant 1/4 wave ground plane but it does that consistently across the 30 to 88Mhz range. The antenna it replaces in the field was 16ft tall and had 19 separate parts, and the COM201B works better.
If you want a terrific omni directional VHF lo band monitor antenna you will probably not find anything better.
kinda why i posted that
as i ran across pricing and now i know why war is expensive
not a very attractive price for a groundplane with extra added built in lossiness
902
Downsouthsomewhere
I very rarely see antennas on their vehicles anymore. Seemed like every one of them had low band antennas going back a while. Thanks for the area post! Were they using CTCSS?
marvinsuggs
Richmond, TX
Thank u very much Tom
I'm really excited to set up my listening station. I used to enjoy low band skip when I was a kid. In 1979 I was picking up CHP and Oregon State Police here in Texas and tons of new England FDs.
nd5y
Wichita Falls, TX
Back in the 80's the first time I lived in Wichita Falls I had a vertical dipole cut for about 39 or 40 MHz up about 25 feet for a while. I heard stuff from all over. There was some local stuff over 100 miles away I could hear most of the time.
marvinsuggs
Richmond, TX
Hi tom
So my dipole would have to be vertical? Looks like there's still lots of low band skip to listen too.
nd5y
Wichita Falls, TX
I usually don't even try any more. I don't have outside antennas and there is too much noise in my neighborhood.
