2024 MOSWIN Sites/Talkgroups
SWMORadios
Polk County, Mo
Interesting to note, I live in Nixa and have not heard Nixa or Ozark PD on Christian 911 Emergency Services for quite awhile. The only traffic I hear is the fire services and the Sheriff. I think I might program those frequencies in the scanner and see if I hear any control channels…..
if you’re not hearing nixa or Ozark you may need to check your ptoamming. I went through a week ago with no problem on the DMR system. You’re not going to hear anything on the 700 sites for some time. I don’t beleive any buildout has begun yet.
W0RS
Nixa, MO
Shouldn't be my programming, I haven't touched it for three years...Its on a Whistler TX-1.
I will do further research and see where they are hiding. 🤔
llzel
St Louis, MO
Programming for someone else, does MSHP Troop C communicate on MOSWIN Washington700 tower or St Clair or both? They live in Washington MO
wbloss
Human
Joplin MO
Jasper County has added 2 new Phase 2 TDMA Talkgroups: 42295 & 42296 on the Joplin 700 Site 1-49.
wbloss
Human
Joplin MO
𝗝𝗔𝗦𝗖𝗢 𝗠𝗢𝗦𝗪𝗜𝗡 𝗶𝘀 𝗼𝗻 𝘁𝗵𝗲 𝗮𝗶𝗿 - mostly testing but some comms.
Shows as Zone 4 Site 2, NAC 1C2. Phase 2
Control channel 856.4625.
Not sure if ALL simo sites are up. PHASE 2
WRXW863
856.0125
856.4625c
856.775
857.05
857.775
858.0375
859.25
Added to database.
scanman1958
St. Louis
Yes, the Washington site is one of many sites MSHP, Troop C uses on MOSWIN. Note...if that is the only site you program you may miss radio transmissions if a trooper is too far away to acclimate???? to the Washington site. I am sure there is another name for it.
wbloss
Human
Joplin MO
@scanman1958 "affiliate" is the word you wanted!
wbloss
Human
Joplin MO
@scannerowner - there is a pdf attached to the application stating (Bold added)
October 3, 2024
Federal Communications Commission
45 L Street NE
Washington, DC 20554
To Whom It May Concern
Region 24, Missouri, is in receipt of this application from the Missouri, State of (MOSWIN), requesting a new
license to add a 5 site, 12 channel 800 MHz system in Cole County, CAPRAD Application Number CAP24082116008583.
Region 24 has performed an analysis of the technical parameters submitted on this application and determined those technical parameters for the frequency pairs 851/806.1125, 851.806.4375, 851/806.5375, 851/806.7375, 851/806.9625, 852/807.1750, 852/807.3750, 852/807.6125, 852/807.9125, 853/808.1250, 853/808.4250 and 853/808.6625 falls within and satisfy requirements of Region 24’s plan. The frequencies requested also fall in the Cole County allotment of 800 MHz NPSPAC channels.
Region 24 has also verified the technical parameters applied for will pose no interference to any Region 24 or adjacent region licensees.
Please accept this as Region 24’s letter of support for this application.
Thanks, and if you have any questions, please do not hesitate to contact me.
Sincerely,
Scott Bigham
Scott Bigham, Chairperson
Region 24, 800 MHz, Regional Planning Committee
So YES it looks like a new simo site at Jeff!
wbloss
Human
Joplin MO
Here's a little more info:
When the ARPA-funded Jeff City/Cole County Simo comes on, it will join Zone 1.
The Christian County 700MHz new Simo system is under construction now and will join MOSWIN as site 3 in Zone 4.
Also, there is top-level MOSWIN discussion to split Zone 3 into Zone 3 & 5.
Not sure when.
Starcom21
IL /MO/Global DB Adm!n
EDIT: Sorry, the previous posts did not show up when I first went to post this.
Missouri State FCC Application / New License WSFI528
Cole County/Jefferson City Simulcast Site
Add
1​
1​
FB2​
1​
40.000​
115.000​
Add
1​
2​
FB2​
1​
40.000​
115.000​
Add
1​
3​
FB2​
1​
40.000​
115.000​
Add
1​
4​
FB2​
1​
40.000​
115.000​
Add
1​
5​
FB2​
1​
40.000​
115.000​
Add
1​
6​
FB2​
1​
40.000​
115.000​
Add
1​
7​
FB2​
1​
40.000​
115.000​
Add
1​
8​
FB2​
1​
40.000​
115.000​
Add
1​
9​
FB2​
1​
40.000​
115.000​
Add
1​
10​
FB2​
1​
40.000​
115.000​
Add
1​
11​
FB2​
1​
40.000​
115.000​
Add
1​
12​
FB2​
1​
40.000​
115.000​
MissouriMule
Springfield, Missouri
Funny I live in Springfield and use a trx-2 and it's almost non stop on dmr.
I use a 996 for the p25 traffic.
I programmed all of Christian Co.
Use a mobile antenna in my house.
MissouriMule
Far as I know for now its just traffic on the call tg to Springfield. For requesting assistance.
W0IFM
Eureka, MO
New TG for St Louis City???
I am hearing TG 10140 in the city District 4 police. Non enc. Been hearing it for a few hours now. I don't want to say some traffic in the city is non enc and get in trouble. The TG looks to be related to the park police in the city. Not sure. Take a listen if you want.
Check out www.openmhz.com they have all of the city of St. Louis talk groups, several they say are 99% encrypted but I hear them talk on it all the time.
scanman1958
St. Louis
You can hear SLMPD off and on in the clear. Not a lot but sometimes enough to bring back memories if you are older like me. For a few days straight a month or two ago you could hear certain district in the clear for hours. Mostly dispatchers clear with officers still enc. You can always keep the districts programmed just in case.
Meebs11
I can receive both Imperial and the STL City simulcast site for Troop C, but not Weldon Spring. Am I correct in thinking to program both sites to hear as much traffic as possible? Or would either site suffice for the metro and surroundings?
scanman1958
St. Louis
Depending on your location. I forgot where you listen. It will not harm anything at all if you program a few extra nearby sites to expand your listening enjoyment. I live in SW St Louis city and can hear only three MOSWIN sites due to my low elevation. The city's simulcast, Weldon Spring and Imperial. But because of how trunked systems work I can hear troopers talk in almost every county south of the city and a bit less up north.
Amazing really because when I am in Laclede Co scanning on a good day I can monitor almost 14 sites in surrounding counties.
Good luck.
