American Electric Power (AEP) P25 WACN 92715
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I fixed this. When I start Unitrunker it always shows 1F9 delegated to FFF-FFFFFF. I have to manually select 1F9 and delegate it to 1F8 before I decode anything on either system. That makes Unitrunker behave properly but for some reason it won't save it.
At one point in my life I understood the delegation stuff (I think I remember using it on the Ohio MARCS system back when it was type II). I forgot how/when to use it though and just don't understand why it is even necessary. P25 systems give out a tremendous amount of information, and I think enough info is given out on the control channel that UT should be able to determine everything without delegation. Just my thoughts on it. I haven't used UT in years though.
Mike
mtindor
FMP24 PRO USER
If anyone wonders what was changed in the DB for the AEP P25 system that may have caused your county to go green, it was an inconsequential change. Basically on the main RR db page I changed "various" under cities to "Various" -- yeah a capital V. And I had briefly changed the name of the system from "American Electric Power P25" to "American Electric Power (AEP) P25". However, I changed it back because I wasn't prepared to have to go through and edit all of hte wiki links. I will be eventually changing the name to include "(P25)" in the name, but i'll do that when i have time to go through the wiki and modify the appropriate links.
Mike
nd5y
Wichita Falls, TX
Good band opening to the north right now.
I can decode site 22 Elk City & 27 Hinton.
There was some activity on 22 and I added the TGs to the wiki.
Confirmed site 9 Ft. Cobb really exists. All I could get was the CC 854.7125 NAC 009 with old DSD+. Not strong enough for Unitrunker.
mtindor
FMP24 PRO USER
Thanks, Tom. Great work with Fort Cobb. That has been an oustanding ? for some time. Glad to see it filled in completely.
Mike
nd5y
Wichita Falls, TX
I got a full decode on 1F9-009-009 Fort Cobb, OK and submitted an update. It was showing
854.7125C
855.1375A
855.3625A
Also I got it's neghbor 24 miles to the north 027-027 Hinton for the first time. It was showing
855.1375C
855.7625A
857.4125A
This is another case where some frequencies don't match with FCC licenses.
mtindor
FMP24 PRO USER
854.7125C
855.1375A
855.3625A
855.1375C
855.7625A
857.4125A
Yep, that is definitely an odd one -- not only is 855.1375 not part of the Hinton site license, BUT it is currently advertised as an alternate CC on Fort Cobb (a direct neighbor of Hinton). Either somebody fat-fingered things when setting up, or the stole a freq from a neighboring site for some other reason. Who knows. But IF fort Cobb actually could switch to 855.1375, that would likely present a problem for roamers between Fort Cobb and Hinton.
Mike
nd5y
Wichita Falls, TX
This TG is under AEP Ohio but I logged it on one of the Oklahoma sites.
2701 a8d TTECH 2701System technicians Utilities
It's probably systemwide then.There probably needs to be a systemwide subcategory.
mtindor
FMP24 PRO USER
2701a8dTTECH 2701System techniciansUtilities
I moved it back to the Radio Maintenance cat, which is a systemwide cat.
Mike
mam1081
Next to a scanner...
The Abilene 55-55 was decoded mid-August while driving nearby there - sorry if it didn't stay there! I occasionally go through that area and try to run dsd while around there, but it was a one-time decode and check.
Also on the Hinton, OK site...it seems many years ago on the EDACS system that their frequencies didn't exactly line up with the FCC license I found back then...I had a difficult time trying to work on that one.
firemantom26
Wintersville Ohio
Tropo is excellent this morning. Pedro is on line and submitted to db....
Site: 107.107 NAC=06B ; Pedro
Neighbor: 92715.1F6-51.51 ; Crown City Scottown
Neighbor: 92715.1F6-55.55 ; Ironton
Neighbor: 92715.1F6-57.57 ; Minford
Neighbor: 92715.1F6-59.59 ; Portsmouth
Neighbor: 92715.1F6-60.60 ; Oak Hill
Neighbor: 92715.1F6-62.62 ; South Point
Neighbor: 92715.1F6-67.67 ; West Portsmouth
Neighbor: 92715.1F6-71.71 ; Gallipolis
Neighbor: 92715.1F7-33.33 ; Huntington
Neighbor: 92715.1F7-73.73
Neighbor: 92715.1F7-74.74 ; Catlettsburg
Channel 0-277: 854.4625 CC
Channel 0-293: 854.6625 SCC DATA
Channel 0-525: 857.5625 SCC
nd5y
Wichita Falls, TX
The band has been open here a lot lately also but I haven't found anything new yet until maybe this morning.
Today there is either a new site or CC rotation and another CC on 857.2875 appears to be wiping out 104 Woodson TX. That's also one fo the freqs used in Abilene so maybe it came back or never left because Wooson was always stonger here.
ralexander5
Mathis, Tx
1F8 Site 52 NAC 032 is active this morning on 854.0875 with alternate of 854.6125. Should be Freer, Tx site.
nd5y
Wichita Falls, TX
Site 1F8 091-091 Oklaunion, TX just came online.
WPCM993
855.1125
856.4125
857.8375
NAC 05B
Neighbors
1F8 93.93
1F9 13.13, 37.37, 41.41, 43.43
CC is rotating a lot now.
firemantom26
Wintersville Ohio
New site on line
Site: 73.73 NAC=049 ; Greenup Ohio
Neighbor: 92715.1F6-50.50 ; Rome
Neighbor: 92715.1F6-107.107 ; Pedro
Neighbor: 92715.1F7-2.2 ; Fallsburg
Neighbor: 92715.1F7-75.75 ; Hitchens
Neighbor: 92715.1F7-76.76
Channel 0-259: 854.2375 SCC
Channel 0-297: 854.7125 SCC
Channel 0-431: 856.3875 CC
Channel 0-471: 856.8875 SCC
