BCD325P2 / BCD996P2 Major Improvement Update
n9mxq
Belvidere IL
Sorry for the double post. Been fighting with Tapatalk.
Sent from my SM-G930V using Tapatalk
CanesFan95
Was Homeboys-Scanna
Banned
FL
Well then forget my question. You just need to figure out the LCNs.
n9mxq
Belvidere IL
And now that the scanner is following them better, it should be a breeze to compare them to DSD+ or DMRDecode.. Just need the time to actually get it done.. hehe
CanesFan95
Was Homeboys-Scanna
Banned
FL
Well, that's a comparison I did already in that link. So if this update doesn't fix it, then we might basically back to square 0 on this issue.
CanesFan95
Was Homeboys-Scanna
Banned
FL
I don't truly understand a lot of these bullet points. Maybe someone could help?
Released this morning v1.07.07. This update applies the following improvements to both models:
  • Support hang time after voice termination in trunking DMR systems
What does this mean? Doesn't the scanner already have a scan delay setting? If a repeater has hang time, then what is it that the scanner is "supporting"?
  • Support private voice grant message in Capacity Plus
Does this "private voice grant message" basically mean we can now listen and trunktrack private calls? How do we program this in the scanners and is there a wildcard?
  • Improved the reception sensitivity of all digital systems
Awesomeness.
  • Speed up scanning of DMR systems
Does this mean the scanner will no longer get hung up and stay stuck on a frequency that is only transmitting data but not a voice call? DMR frequencies have an annoying way of keying up and transmitting lots of extra junk even when there's no voice call going on.
  • Support RAS detection in Tier 3 (including CapacityMAX) and DMR One Frequency systems
So what does this mean? The scanner will display "RAS" on the screen and that's it?
  • Fixed the issue of P25 band plan
What was the issue? And what is a "band plan"?
  • Modified to not display "LNK" by receiving terminator in staying on P25 control channel
Sorry, don't understand this at all. What is a "receiving terminator" and what does "LNK" mean?
  • Fixed the issue of displaying false DMR TGID
That would be a good thing!
  • Modified detection criteria of encryption in Capacity Plus
What is this "modification" and what does "detection criteria" mean? If the scanner thinks a talk group is encrypted, what does the scanner actually do?
  • Strengthen track of voice slot in DMR One Frequency systems
Really can't understand what this means. What are we "strengthening"? Does this mean some sort of improvement on being able to tell which slot a transmission is on? Is this for trunking or conventional?
  • Added recovery processing for the missing of avoidance TGID in DMR One Frequency systems
Again, can't understand this. What does "recovery processing" and "missing of avoidance TGID" mean? Does this have something to do with locking out a talk group ID?
  • Modified judgement criteria for Hytera XPT
What "judgement criteria" are we talking about? I'm not following you here. What are we "judging" and what does the scanner actually do differently now?
CanesFan95
Was Homeboys-Scanna
Banned
FL
Well, here's another big question. I keep getting an error and can't do the update.
"The operation has timed out."
Why would it time out? The update software has no problem detecting the scanner, so I know I've got the right COM port number. It actually starts off running and the two progress bars start running. But then about halfway through, it just stops suddenly and it gives this error:
Ubbe
Stockholm, Sweden
I'll give it a try.
Scanner used to instantly go back to control channel and wait for next PTT. Now it waits on the voice channel, the same as the radios in some systems does. It doesn't miss as many conversations as before as the control channel PTT might not show up during system hang time on the voice channel depending of the system setup.
It's always worked in other DMR system types, except DT3. Private calls doesn't trunktrack, they stay on one channel the whole conversation. It was probably an oversight that Uniden forgot to support this in cap+
I guess so.
RAS means that you'll need a system key to calculate the correct checksum of the data. Scanners have to ignore this and accept checksum errors which could increase bit errors resulting in bad audio and bad coverage. If the RAS detection doesn't work properly the scanner could ignore the whole data and not monitor the call as it thinks it's all bit errors and a too bad reception to be able to monitor.
The Uniden scanner skips any calls that it thinks is encrypted and continues to scan. It probably didn't detected that reliable enough in cap+ systems. (I now notice that my 536 detect both enc and dmr falsely on pure conventional channels, so they seem to have done this a bit too much)
It was problems to properly detect which slot a conversation was using and switched over to the other slot if another conversation where ongoing there and then jumped between the two slots which resulted in a monitoring mess.
Yes, it's related to the previous problem with the slot jumping. It was impossible to keep track of the avoided TGs as Uniden stores TG avoids associated with a particular slot.
Hytera systems can use their own kind of system called XPT. A standard system have one slot with data and the other slot with voice, or two voice slots with each slot dedicated to different users. XPT allows both slots for voice for all of its users. The advantage is that one user group can use two TGs at the same time when a standard system only allows one TG. I guess Uniden must properly detect a system as XPT to be able to follow a conversation if it travels between slots. This is probably related to that previous slot jumping problem.
/Ubbe
marksmith
Anne Arundel County, MD
Not using the DMR enhancement. I noted someone had an analog search issue with this upgrade.
Is the improvement in p25 reception significant enough to go to this upgrade, as opposed to waiting on a more significant one?
It's the only thing I see for non-DMA users.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
CanesFan95
Was Homeboys-Scanna
Banned
FL
It's a shame that the scanner only shows the color code and not the talk group ID and slot #. There's enough unused pixels on the screen that it could show it. If the frequency was moved all the way over to the left and there was only 1 space between the frequency and color code, there's room to show the TGID and maybe an S1 or S2.
RoninJoliet
ILL
I'm not sure one could see a improvement in "decode of digital signals" unless you have a decent signal and depends on your area and distance from the tower sites....Its questionable for me to do the upgrade as a non-DMR user as I already get very good coverage here on the site towers I monitor on IL-Starcom in the Chicago area....Sure need more input from area users.....Not much input on this upgrade as yet.....
marksmith
Some of the input suggests some things working now are a problem after upgrading.
Think I will wait...
cg
Connecticut
Confirmed this is an issue with the new firmware.
I reverted to the previous Firmware version and the Control Channel Only works on Motorola analog trunked systems.
chris
My 325P2 no longer works on Motorola analog TRS using Control Channel Only during a search of 851-860MHz.
milcom_chaser
chris
Tech1
Hudson Valley NYS
I'm having trouble installing this update. I know there's a particular sequence to doing an update and right now I can't remember it.
cg
Connecticut
You run the program called BC_VUP3 and follow the directions.
chris
Tech1
Hudson Valley NYS
Cancell the request for help, It's done. I did the DMR Update back in March, but I forgot where I put the file for the Uploader.
cg
Connecticut
The latest release is a General release and is available via the BC_VUP3 updater.
chris
