APX7500X2
NY/CT
I beleve they can put it up and down as they please, Its mostly for the DEEP units to talk to Madison PD from Hammo state park.
Madison is not changeing over to the CLMRN system
Firebuff66
CT
I remember last year I used to hear Madison PD on the DEEP west channel when they sent the ambulance to Hammo, Not sure if that happens anymore, I don't listen as much as I used to
WoodburyMan
Southington, CT
Been monitoring Site A, L, and I for the past 5 days or so. Some new TG's anyone can help identify:
TG3037 - Site L Simulcast - UID's 1851011, 1851065, 1859009.
Appears to be Prison/Judicial Marshals North TG. Heard bits about transporting/opening gates at (MacDougall)-Walker, coming from Garner, and Cheshire.
There's already South, West, East, Statewide, and Transports TG's for JM's. What could this be? (Still monitoring to see if I can hear more). I see on the old CSP system they had a North makes sense. Submitted to Database.
TG2017 - Site A Simulcast - UID 65056.
No idea. Heard some references to DOT. This appears to be a State Police TG as the UID's line up with some other 65,xxx's heard on L, A, and Statewide Commons.
TG1544 - Site L Simulcast - UID's 1871002, 1824187.
Appears to be DEHMS TG. UID's line up with other DEHMS UID's and the TG is near other DEHMS TG's.
Heard some talk about Busses picking people up at a Marriott, and referred to dispatch as "Command Post"
CT
UID 65056.
65XXX are normally Dispatch positions but I have this one logged as an NCC UID.
disp-jpg.74598
jmorrissey23
D14
From the old system I have
3037 as DOC North
2017 as Unknown CSP Central District?
I will submit 3037 and the new 800 voice channels on the Troop H site to the DB tomorrow.
mgranoth
Milford, CT
Does anyone know the TG's for the CMED's. I was told that all of the CMED's will each be getting their own designated TG. Thanks.
matt04
Anyone catch TG 5662 and 5663 on the H site? Sounded like DOT service trucks of some sort, with 5662 giving locations along I91 in the Windsor Locks area.
Also got 5641 with "station 40" as a base calling several other units. No idea what agency though.
matt04
Service Patrol?
Maybe 56XX units are DOT?
The only other DOT TGs I ever heard was 1701 which was a patch from the Low Band channel. I woder if that could have been a test and DOT will use 56xx you suggested. It will probably take a lot of listening as DOT was always very quiet in the past.
gofasters4
I heard reference to "...Service Patrol channel" on TG 5662, from site 27. The UID on that call was 187xxxx - referring to themselves as "Hartford operations center". Most of the other calls on TG 5661 and 5663 had no UIDs, and sounded like patches from an analog system.
matt04
I wonder if 5661 and 5663 are patches from the low band? IIRC prior to CLMRN ConnDOT only used low band for wide area comms and UHF or VHF hi simplex for flaggers, etc.
XPS720
Windham County, Connecticut
I started with CT ST Police then CSERN and now I see CLMRN. Is CLMRN better than CSERN and is it the latest system? If used do I need to add frequency to it?
cg
Connecticut
CT State Police was the Motorola Type 2 system that is all but shut down.
CSERN was the original name used only within Radioreference to ID the P25 system
CLMRN is the official name of the new P25 system and RR has recently changed to using it.
chris
coolrich55
connecticut
Bunch of testing going on the last few hours in Stonington with radio service.Not sure if they're having problems or testing new equipment.
GTR8000
NY/NJ Database Guy
BEE00
Thanks to @KevinC for renaming the thread to match the actual system name. It's nice to know that we have a moderator who cares about minor requests such as renaming a thread to match the RRDB entry, instead of blowing it off as being an apparent waste of his time. ;) (y)
oneadam-12
Connecticut
I just found a new Site which is 33, it's being used for Rentschler Stadium, cc is 774.86875 voice channels are so far are 769.73125 and 769.88125. Talk group herd was 3003 which according to the database is special EVTA .
