cg
Connecticut
I would say you had some interference or a poor signal. None of those logged on the 5 sites I can monitor.
adamfancher
Winsted, CT
P25, BEE00.3A9, 30838, 43672, 50, Normal, 0, 2024/11/24 7:48, ""
P25, BEE00.3A9, 31092, 4212401, 50, Normal, 0, 2024/11/25 7:34, "Radio ID Range 421xxxx Unknown"
P25, BEE00.3A9, 31095, 3162240, 50, Normal, 0, 2024/11/25 7:57, "Radio ID Range 316xxxx Unknown"
P25, BEE00.3A9, 31100, 12505835, 50, Normal, 0, 2024/11/25 8:38, "Radio ID Range 1205xxxx Unknown"
P25, BEE00.3A9, 31102, 3044424, 50, Normal, 0, 2024/11/25 8:49, "Radio ID Range 304xxxx Unknown"
According to the timestamps, the affiliations were not all at once. If it was noise, what are the chances that the same noise would repeatedly occur such that it would cause a certain subset of talkgroups to show up?
Not trying to be argumentative, just trying to wrap my brain around it.
cg
Connecticut
I can't say what is causing the hiccup (heavy rain, RF from cellphone perhaps), but they are all fairly close on time. Also, there is no voice to confirm the TGID or radio is real. If the TGID and the RID don't mesh with the typical layout, be doubtful. If there have been no other radios in the range, don't be too sure that it is legit.
How many other 8 digit RIDs are there (that aren't ISSI)? I have logged 12,500 or so but no legit 8 digit ones.
How many other RIDs have you logged that are numerically close? Very few agencies only have a couple radios.
adamfancher
Winsted, CT
By ISSI are you referring to the internal patches on the 65xxx talkgroups and 1677xxxx ID's?
Omitting these, I would say they are pretty random and sporatic with no pattern. They are all a single affiliation with one possible other activity, a few in the troop talkgroups, a couple of municipalities, and a whole lot of unknown with no other activity. I would agree that considering my logging started in early 2022 (though I've not yet amassed quite 12500 :) ), most or all of these seem attributable to random loss of signal and/or interference
P25, BEE00.3A9, -2, 10090127, 50, Normal, 0, 2024/09/18 1:47, "Radio ID Range 1009xxxx Unknown"
P25, BEE00.3A9, 101, 10190323, 50, Normal, 0, 2022/09/02 14:04, "Radio ID range 206xxxx Unknown"
P25, BEE00.3A9, 7424, 10257817, 50, Normal, 0, 2022/11/29 14:05, ""
P25, BEE00.3A9, -2, 10268995, 50, Normal, 0, 2022/12/01 15:36, "Radio ID range 10xxxxxx Unknown"
P25, BEE00.3A9, 5673, 10783756, 50, Normal, 0, 2022/09/08 11:47, ""
P25, BEE00.3A9, -2, 10785982, 50, Normal, 0, 2024/11/21 8:39, ""
P25, BEE00.3A9, -2, 10793487, 50, Normal, 0, 2023/04/17 11:33, "Radio ID range 10xxxxxx Unknown"
P25, BEE00.3A9, 5002, 11049888, 50, Normal, 0, 2022/02/25 8:46, ""
P25, BEE00.3A9, -2, 11055254, 50, Normal, 0, 2023/08/07 3:22, "Radio ID range 11xxxxxx Unknown"
P25, BEE00.3A9, -2, 11055459, 50, Normal, 0, 2023/10/24 16:38, "Radio ID range 11xxxxxx Unknown"
P25, BEE00.3A9, -2, 11055639, 50, Normal, 0, 2022/11/21 14:24, "Radio ID range 11xxxxxx Unknown"
P25, BEE00.3A9, -2, 11056077, 50, Normal, 0, 2023/08/07 14:31, "Radio ID range 11xxxxxx Unknown"
P25, BEE00.3A9, 26202, 11058190, 50, Normal, 0, 2024/11/06 13:41, ""
P25, BEE00.3A9, -2, 11767969, 50, Normal, 0, 2023/08/12 3:50, "Radio ID range 11xxxxxx Unknown"
P25, BEE00.3A9, 51, 11276106, 50, Normal, 0, 2024/11/16 15:35, ""
P25, BEE00.3A9, -2, 11834782, 50, Normal, 0, 2024/11/27 7:59, ""
P25, BEE00.3A9, 51, 11864976, 50, Normal, 0, 2024/11/05 13:02, ""
P25, BEE00.3A9, 20854, 11819617, 50, Normal, 0, 2024/10/17 8:53, "Radio ID Range 1181xxxx Unknown"
P25, BEE00.3A9, 501, 11998269, 50, Normal, 0, 2022/02/25 8:12, "Radio ID Range 1199xxxx Unknown"
P25, BEE00.3A9, 5611, 12262255, 50, Normal, 0, 2022/08/16 6:43, "Radio ID range 12XXXXXX Unknown"
P25, BEE00.3A9, -2, 12174138, 50, Normal, 0, 2022/09/26 8:40, "Radio ID range 12xxxxxx Unknown"
P25, BEE00.3A9, -2, 12144333, 50, Normal, 0, 2022/01/13 0:01, "Radio ID range 12xxxxxx Unknown"
P25, BEE00.3A9, -2, 12360356, 50, Normal, 0, 2024/11/04 9:54, "Radio ID range 12xxxxxx Unknown"
P25, BEE00.3A9, -2, 12361044, 50, Normal, 0, 2022/09/07 12:50, "Radio ID range 12xxxxxx Unknown"
P25, BEE00.3A9, -2, 12457156, 50, Normal, 0, 2022/09/12 13:30, "Radio ID range 12xxxxxx Unknown"
P25, BEE00.3A9, -2, 12628567, 50, Normal, 0, 2022/09/16 10:11, "Radio ID range 12xxxxxx Unknown"
P25, BEE00.3A9, -2, 12710909, 50, Normal, 0, 2024/11/19 23:47, ""
P25, BEE00.3A9, -2, 12928051, 50, Normal, 0, 2024/10/24 6:50, "Radio ID range 1292xxxx Unknown"
P25, BEE00.3A9, 15221, 13453449, 50, Normal, 0, 2024/09/27 8:46, ""
P25, BEE00.3A9, 2725, 13765734, 50, Normal, 0, 2023/08/10 18:46, "Radio ID Range 1376xxxx Unknown"
P25, BEE00.3A9, -2, 13767631, 50, Normal, 0, 2022/11/21 5:34, "Radio ID range 13xxxxxx Unknown"
P25, BEE00.3A9, 342, 14649410, 50, Normal, 0, 2022/01/16 19:13, "Radio ID range 14xxxxxx Unknown"
P25, BEE00.3A9, 1292, 14727025, 50, Normal, 1, 2024/07/01 12:16, ""
P25, BEE00.3A9, 0, 14680026, 50, Normal, 0, 2024/10/24 19:56, ""
P25, BEE00.3A9, -2, 15058344, 50, Normal, 0, 2022/08/17 7:09, "Radio ID range 15xxxxxx Unknown
P25, BEE00.3A9, 350, 16057855, 50, Normal, 0, 2024/11/14 19:30, ""
P25, BEE00.3A9, 5488, 16077461, 50, Normal, 0, 2023/08/10 8:24, ""
P25, BEE00.3A9, 5488, 16087973, 50, Normal, 0, 2024/09/24 14:46, ""
P25, BEE00.3A9, 5856, 16131581, 50, Normal, 0, 2024/09/25 8:08, ""
P25, BEE00.3A9, 12103, 16205100, 50, Normal, 0, 2024/11/02 12:41, ""
P25, BEE00.3A9, 101, 16481859, 50, Normal, 0, 2022/12/20 9:07, "Radio ID range 164xxxxx Unknown"
P25, BEE00.3A9, 56828, 16563212, 50, Normal, 0, 2024/04/23 12:29, ""
I suppose it's possible these are the CTS radio gods that can assume the form of any 8 digit (or any really) Radio ID on any talkgroup and establish a one time patch for testing purposes as they see fit, but who knows...
The ones in the 31xxx talkgroup ones are strange, another one surfaced today:
P25, BEE00.3A9, 31612, 11916954, 50, Normal, 0, 2024/11/27 8:37, ""
APX7500X2
NY/CT
Im hearing a Paid fire dept. on TG 31092 its on troop G system and they are talking about transporting to Brigham Hospital and getting mutual aid amb from Woburn
Firebuff66
CT
I pulled up sdrtrunk running on the troop G system all day and low and behold TG 31092 had 12 hits during the day.
If they are transporting to Brigham and getting M/A from Woburn then that would be someone in the Boston area.
W1KNE
Not a forensic scannist.
New England
What's strange is, the only 3xxxx series talkgroups are all 389xx, which are Interop and municipal TGs in the same range as New Britain at 189xx. (All in N.B.) 110xx would be Bethlehem, so highly unlikely they're related.
This is going to be someone at Motorola screwing with folks to cause a stir on the message boards. (Just like when folks were hearing Troop G stuff on CoMIRS near Boston). And it's working.
ecps92
Taxachusetts
or like what both the Mass systems had a few years ago when we heard TG's passing NYPD and VTSP traffic :)
O the fun that can be had with spare/mutual TG's and the ability to network into other trunks
adamfancher
Winsted, CT
I see that on the Mass State Police Type II SmartZone network there are a ton of 3xxxx talkgroups, of course that's a different system and I have no idea if there is any correlation with a crosspatch into CLRMN...
adamfancher
Winsted, CT
Continuing to get hits on new 31xxx talkgroups, still just single radios with previously unknown prefixes. Will post tonight.
adamfancher
Winsted, CT
I was mistaken, these were in the 34xxx-35xxx range:
P25, BEE00.3A9, 34132, 571020, 50, Normal, 0, 2024/12/05 3:32, "Town of Greenwich (Portable)"
P25, BEE00.3A9, 34717, 8242288, 50, Normal, 0, 2024/12/07 12:44, "Radio ID Range 824xxxx Unknown"
P25, BEE00.3A9, 35080, 12741755, 50, Normal, 0, 2024/12/08 22:06, "Radio ID Range 12xxxxxx Unknown"
P25, BEE00.3A9, 35463, 3392739, 50, Normal, 0, 2024/12/10 13:57, "Radio ID Range 339xxxx Unknown"
P25, BEE00.3A9, 35486, 1728160, 50, Normal, 0, 2024/12/10 12:48, "Radio ID Range 172xxxx Unknown"
P25, BEE00.3A9, 35501, 4765224, 50, Normal, 0, 2024/12/10 18:42, "Radio ID Range 476xxxx Unknown"
paul612
mass
Not sure if it has anything to do with anything but on my way back to Mass from NYC Wednesday morning I did pass a Greenwich ambulance on I84 east bound up near Tolland.
Thought that was a bit strange.
cg
Connecticut
More likely a repair trip than a patient trip, Eastford Truck Sales is up that way in Ashford and I have taken ambulances there for work. Greenwich RIDs are not typically seen outside their area. I have never seen one that I recall and have not logged any Greenwich radios since my last big RID reset on 1/1/24 and that covers B, C, H, L, & Hartford sites.
Firebuff66
CT
Probably going to Eastford Fire Rescue for repairs
adamfancher
Winsted, CT
Looks like Winsted PD is joining the party:
; Winsted Police Department (Encrypted)
P25, BEE00.3A9, 26211, 1624208, 50, Normal, 19, 2025/01/11 12:08, "Winsted Police Officer Twombly (Portable)" 01786DD42B971C08209B6C2FCC253B8F6FBDE8A2637C34D80D68834639C2000000C6FC368A"162 TWOMBLY-P"
P25, BEE00.3A9, 26211, 1624222, 50, Normal, 15, 2025/01/11 8:36, "Winsted Police Officer #239 (Portable)" 01786E7BAFFE7F9287DAD20AC944F110D9258348C8EB863A7639F99C5DC621BC00C9772B44"162 PD M0239-P"
P25, BEE00.3A9, 26211, 1624227, 50, Normal, 11, 2025/01/11 8:45, "Winsted Police OIfficer#234 (Portable)" 01786E7BAFFE7F9287DAD20AC944F110D9258348C8EB863A76388FA80FB175B30028D4CAC7"162 PD M0234-P"
P25, BEE00.3A9, 26211, 1624228, 50, Normal, 19, 2025/01/11 13:54, "Winsted Police Officer #233 (Portable)" 01786E7BAFFE7F9287DAD20AC944F110D9258348C8EB863A76860A54E238F7D400D8AB21CB"162 PD M0233-P"
P25, BEE00.3A9, 26213, 1624220, 50, Normal, 26, 2025/01/11 12:59, "Winsted Police Department - Main (Portable)" 01786DD42B971C08209B6C2D0E01DEAD85D8429D9250ADEFFED0C1BF3FB80000008B8297A9"162 PD MAIN-P"
