DSD+ 2.465
Fixed dual receiver TIII monitoring.
Added menu option to control decoding of inbound P25 control channels.
Correct me if I’m wrong, but aren’t you the only one that has reported this issue? It would be very good to have raw audio of when that happens, and the screenshot of what the audio looks like in the audio window at the time as well as an excerpt from the Log file at the time that this happensThe issue with "lost control channel" on NXDN networks is still not resolved.
Here is a fresh screenshot from a few minutes ago.
Is there any chance that it really did lose the control channel (site either went off air or switched to a different frequency as the control channel)? And do you use "Hunt for Lost Control Channel" in the menu?The issue with "lost control channel" on NXDN networks is still not resolved.
Hmm. Might want to get some raw audio of that stuff occurring (won't take much), zip it up and send it to dsdplusfastlane@gmail.com with an appropriate description in the subject. Or upload the raw audio somewhere and link it here.Well, not anymore.
Seeing this on a NXDN dfa system. Do not see it on non-dfa.
That's on my todo list. Going to try later when system is busy.raw audio
Unfortunately I am not the only one.Correct me if I’m wrong, but aren’t you the only one that has reported this issue? It would be very good to have raw audio of when that happens, and the screenshot of what the audio looks like in the audio window at the time as well as an excerpt from the Log file at the time that this happens
2024.02.26 14:55:55 Sync:+NXDN48 TB DATA IDLE
2024.02.26 14:55:55 IDLE
2024.02.26 14:55:55 ERR1 IDLE
2024.02.26 14:55:55 Sync:+NXDN48 TB DATA VCall Group TG=621 RID=7763 4800 bps/Half Rate
2024.02.26 14:55:55 VCall Group TG=621 RID=7763 4800 bps/Half Rate
2024.02.26 14:55:55 Sync:+NXDN48 TB VOICE
2024.02.26 14:55:55 Sync:+NXDN48 TB VOICE VCall Group TG=621 RID=7763 4800 bps/Half Rate
2024.02.26 14:55:55 RAN=31
2024.02.26 14:55:56 Sync:+NXDN48 TB VOICE
2024.02.26 14:55:56 Sync:+NXDN48 TB VOICE VCall Group TG=621 RID=7763 4800 bps/Half Rate
2024.02.26 14:55:56 RAN=31
2024.02.26 14:55:56 RAN=31 e:1
2024.02.26 14:55:56 Sync:+NXDN48 TB VOICE e:11
2024.02.26 14:55:57 Sync:+NXDN48 TB VOICE VCall Group TG=621 RID=7763 4800 bps/Half Rate
2024.02.26 14:55:57 RAN=31
2024.02.26 14:55:57 Sync:+NXDN48 TB VOICE e:2
2024.02.26 14:55:57 Sync:+NXDN48 TB VOICE e:1
2024.02.26 14:55:58 Sync:+NXDN48 TB VOICE VCall Group TG=621 RID=7763 4800 bps/Half Rate
2024.02.26 14:55:58 RAN=31
2024.02.26 14:55:58 Sync:+NXDN48 TB VOICE e:1
2024.02.26 14:55:58 Sync:+NXDN48 TB DATA TX_REL_EX Group Call Tgt=621 Src=7763
2024.02.26 14:55:58 ERR17
2024.02.26 14:55:59 Sync: no sync
Managed to get a small IQ recording from FMP24 showing it not tuning back to the CC after the voice grant.
Anyone know a better file share site?
Close ad, file will download
Transfer expired – TransferNow
Click to download the files for this transfer with TransferNowwww.transfernow.net
But I'm pretty sure you can't feed IQ from FMP24 into FMPA or FMPP, and vice versa.
I use Mega.nz its free, a bit slow, but works.Managed to get a small IQ recording from FMP24 showing it not tuning back to the CC after the voice grant.
DSD+ 2.444
Fixed console log output formatting.
Added checks for bases files integrity. Functionality is controlled via the DSD+ Misc menu.
DSD+ 2.268
Added menu entry to download newest base files. Provides access to up to date copies of
all DSD+ companion programs, configuration files, batch files, data files and required DLLs.
DSD+ is configured to talk to one of the FMP programs via a direct link, but you're not running any of the FMP programs with direct linking enabled.Hello, can someone tell me what's going on here, why such errors occurred
Umm. Assume your DSDPlus folder is "DSDPlus". Just right-click / drag / copy the folder to a new location. pretty simple. The only requirement (if you didn't do anything silly like modify locations in files) is for it all to be in one folder.someone can tell me how to properly make a dsd backup
