DSDPlus DSD+ FL 2.465 Released
TheButcher
Hey Dave3845.
Good point. I failed to mention that the PSTNI (Phone Patch) occurs only on Private Call. So I tried Manually adding and blocking that ID of "16776896" and "PSTNI". Both of which DSD+ FL removes from the Radios file. ie. I add them and DSD+ FL removes them.
Any ideas? Or can the DSD+ team please add this as a feature in a new release please ?
Ignore the "disgarded WaveOut blocks" as when PC enters then exits power save mode sound output fails.
Cheers.
dave3825
Suffolk County NY
Are there other Private calls of interest you listen to? If not, does setting Private calls to L/O help you? To be honest, I never even messed with this and I dont have Private Calls on any systems I monitor.
TheButcher
"Are there other Private calls of interest you listen to? If not, does setting Private calls to L/O help you? To be honest, I never even messed with this and I dont have Private Calls on any systems I monitor."
Thanks for the tip. Unfortunately, yes. I do monitor other Private Calls. Probably 95% of what I monitor is Private Calls and the remaining 5% are Group Calls. So sadly, that won't work.
Cheers.
fourwatt
I am currently on version 368 attempting to update.
I have tried both my home network as well as using my cellphone as a hotspot (disconnected from home network) to no avail.
I was able to download the new base files successfully. I get the prompt to update to 465, when I click on update it immediately
returns update failed in both cases.
I emailed DSDplusfastlane@gmail.com 6 days ago with no response.
I did subscribe to the unlimited program.
Any help and or advice would be greatly appreciated.
I did also try direct download from the link provided in email changing the version number.
Thank you
Ken
BM82557
Berkeley Co WV
Are you connected to a VPN? In my case I have to disconnect from the VPN in order to download Fastlane updates.
dave3825
Suffolk County NY
If your good with PC stuff, take the link you tried from your email with the new version number and stick it on a thumb drive and try from work or library PC to see if it downloads and save it to the stick.
W8MKG
I'm downloading this update, but it appears the zip file is corrupt. I tried it 3 times, and got the same result. I am able to get and open the base files from the menu no problem.
Edit - Nevermind. Program I was using didn't support encrypted zip files and I forgot about the password. Opened with 7-Zip fine after installing that on this PC and getting the password from my email.
devicelab
Whacker Extraordinaire
Nowhere in WA
Well, not anymore.
Seeing this on a NXDN dfa system. Do not see it on non-dfa.
I started seeing this with 2.465 recently as
The issue with "lost control channel" on NXDN networks is still not resolved.
Here is a fresh screenshot from a few minutes ago.
I'm seeing this as well with a local NXDN RAN provider. It seems to reset during passive monitoring. The reset itself seems to occur when there's voice activity. The channel activity window will show the voice frequency/CH ID pop up. Then it resets the CA window and only shows the control channel info once again -- instead of showing the CC and V1 data.
Also, I don't know if this is related, but I'm seeing the detected alias get permanently modified. DSD will change the original lines @ 10:37 too upon the change to this [BP@]
2024/05/01 10:37:29 Group call; TG=207 RID=3035 [BRAVE AR....] Ch=412
2024/05/01 10:37:29 Group call; TG=207 RID=3035 [BRAVE ARROW] 8s
2024/05/01 10:37:41 Group call; TG=207 RID=3031 [DISPATCH....] Ch=412
2024/05/01 10:37:41 Group call; TG=207 RID=3031 [DISPATCH] 6s
2024/05/01 10:37:50 Group call; TG=207 RID=3035 [BP@] Ch=412
2024/05/01 10:37:51 Group call; TG=207 RID=3035 [BP@] 1s
cg
Connecticut
If you want to keep the alias (or make custom ones), you need to edit the RADIOS file and remove the asterisk in front of the alias. If you have done that and it still changes, then that is an issue.
devicelab
Nowhere in WA
I've never had to do that before. Why is it changing the alias from the original data?
cg
Connecticut
Because it is seeing something different, or it is thinking it is. Could be any number of reasons that causes a slight hiccup in the stream...bad signal, interference, too much signal distorting data.
devicelab
Nowhere in WA
Is anyone else seeing problems with the automatically sizing channel window? For some reason, on this specific site, the text gets all screwed up. It doesn't happen on other sites from the system -- just this one -- the primary site (and thus the busiest.)
JamalDoski
Hello everyone, with the permission of the administrator, I have a question, which city in America is the company dsd Plus?
Reconrider
Inside the Galaxy
Radio Galaxy
it happens once in awhile. Typically you can resize the windows.
if that doesn't work, find the dsdplus.bin file and delete it. Then restart dsd and it should fix itself
JamalDoski
سلام با اجازه ادمین میخوام ویدیویی هست که مرحله به مرحله نحوه خرید dsd Plus Fastlane با پی پال رو نشون بده یا کسی هست که کمکم کنه نمیدونم چطوری با پی پال خرید کنم ما پی پال نداریم، خیلی ممنون
u2brent
OAMPT
KRWDPAXKRS1
