From Notes.txt file included with FastLane --
FMPP 1.0
DSD+ compatible SDR software for SDRPlay RSP2 receivers.
Other SDRPlay receivers are not supported, but some functionality may be possible.
Operation is similar to FMPA; refer to FMP.txt, FMPA.txt and
FMPA feature updates documented in this change log.
Use Notepad to add your SDRPlay serial number(s) to the FMPP.cfg file.
FMPP help summary:
Usage:
FMPP [options] Normal operation
FMPP -h Show help
Options:
-i<num> SDRPlay device number (1-255) [-i1]
-o<num> Output audio device (1-255) [-o1]
-o<port> Output audio TCP port (256-65535)
-A<num> RSP2 antenna select (1-2) [-A1]
-N<num> Enable/disable RSP2 notch filters (0-1) [-N0]
-L<num> LNA gain (0-8) [-L8]
-M<num> IF gain (0-59) [-M30]
-T<num> Enable/disable RSP2 bias tee (0-1) [-T0]
-f<MHz> Initial tuned frequency [-f99.9]
-b<kHz> Initial filter bandwidth (4, 7.6, 9.5, 12.5, 22) [-b7]
-u<num> Enable/disable unlicensed spectrum display (0-1) [-u0]
-z<num> Show zoomed spectrum (0-1) [-z1]
-n<num> Select noise filter (0-2) [-n0]
-v<num> Set volume level (0-500) [-v100]
-s<num> Enable/disable scanner mode (0-1) [-s0]
-wsl<v>.<h> Spectrum window location [-wsl50.50]
-_<num> Minimize windows at startup; bitmapped
-rc Role is trunk control/rest channel monitor
-rv Role is trunk voice channel monitor
Active keys:
0-9 . Enter set frequency
[/] select step size
Cursor </> step frequency
Ctrl Csr </> step frequency by 250 Hz
U toggle unlicensed spectrum display mode
M toggle spectrum memory overlay
X reset spectrum memory
Z toggle spectrum zoom overlay
I select injection mode
b/B select bandpass filter
F select noise filter
Cursor ^/v adjust volume level
spacebar toggle muting
A toggle RSP2 antenna select
O toggle RSP2 notch filters
j/J adjust LNA gain
k/K adjust IF gain
R toggle raw I/Q and FM demod recording
S start scanner mode or exit hold mode
C start trunk control/rest channel following mode
V start trunk voice channel following mode
? list active keys
Esc exit scanner/CC/VC modes or exit program
Left click on spectrum: retune
