Erie County P25 System
Railbender
NW PA
Yes. The give away was the all call alarm test. My Unication will record by talk group. I just played it back this morning, after letting it run two days.
scnrfrq
Erie, PA
I wonder if they will keep using 154.98 also? They just went digital on that frequency a few years ago. Also, I see that frequency was removed from the Erie County database page at some point. It was correctly listed as digital, but now I don't see it on that page.
n3obl
ØAES-1024
PA
I believe the on site channels are conventional off network channels for short range comms on scene of an operation.
Railbender
NW PA
Looking at the Erie County database page, there is a list of UHF onsite fire frequencies after the 2 paging channels. Are these new, or now contained in the new system somewhere?
They were licensed in March 2016, over a year before any of the P25 licenses.
scnrfrq
Erie, PA
I now have an SDS200. I'm receiving Countywide Simulcast TG's, which I haven't seen on my 536. Right now South County TAC 2 was on. Why would I get Countywide TG's on the SDS200 but not on the 536?
GTR8000
NY/NJ Database Guy
BEE00
Programming error? Simulcast distortion? Who knows, only you can answer that question, we don't know what your programming looks like or how much simulcast distortion the 536 was fighting that the SDS doesn't care about.
Railbender
NW PA
As explained before the TAC talk groups, unlike the dispatch talk groups, are only carried on the associated site. As has also been explained before reception on the rural sites is very poor in your area.
maus92
OCMD
Finally took my advice and bought the SDS200 - and it works!
scnrfrq
Erie, PA
Yes it does! Still trying to understand why it picks up County Simulcast TAC channels, while the 536 is silent. Must be a combination of simulcast distortion and my poor location for rural sites, as Railbender mentioned.
maus92
OCMD
I'd have to examine your programming to rule it out as a cause - did you use the same Sentinel files to program both your 536s and the SDS200? What antenna are you using for the SDS200? Does it work well anywhere in your home? Do you have both sites programmed? It is my understanding the the Countywide TACs are only carried on the Countywide site - is that correct?
scnrfrq
Erie, PA
I'm using Sentinel with the same favorite lists for both scanners. Both sites are programmed in. So far the 200 is only used on the 2nd floor, right next to a 536. Yes, Countywide TACS are only on the Countywide site. The 536 keeps on scanning while the 200 is stopped on a TAC channel.
Railbender
NW PA
Yes the TAC talkgroups are only carries on the associated sites. Reception of the Rural sites is very poor in his area. I have been in that area and checked. Even my Unication G3 was at 3 of 4 bars. In spite of what you may think there only TWO sites providing that signal in his area. I have plotted the radiation pattern for all of the surrounding sites. A cheap Yagi would probably help the 536s and the SDS200.
scnrfrq
Erie, PA
Both scanners have telescoping antennas. Other than the County TAC channels, reception on both scanners is pretty similar.
