AngWay
Curious
I'll try to get a pictureI have no clue what you are seeing. What do mean by "just shows everything on that site"? A screen shot may be helpful.
when i first got the scanner i remember being able to hit function and 0 LVL and it would show gain in the bottom right of the screen i remember following the direction on google but now when i hit those buttons i don't get nothing. it's weird i know it's there because i seen it
by the way i got sentinel working on linux and it actually runs greatWhat Gain?
well why does google say this? Link
yeah i guess i missed it it was all the way at the bottom and when it starts out it says nothing about it only working in waterfall mode.Did you read the post you linked? This is specific to the waterfall feature and as far as I know/can tell, not to do with regular scanning.
Oh - you have jumped to the waterfall featurewell why does google say this? Link
Yes - this is in sentinel.and this is in sentinel ?
RMason said:
For a trunked system, nxdn, p25, dmr, etc. is specified in the System Type. This is defined at the system level.
Ok great thank you i see it now...why are the single freq P25 sites called conventional isn't it digital
There are two types of channels in the SDS100: conventional (single channel) and trunked (part of a system). Either can be analogue or digital, or a mix of the two, depending on how it's used.Ok great thank you i see it now...why are the single freq P25 sites called conventional isn't it digital
Got it that's a great explanation ... what's your opinon on using the sds100 to listen to ham radio?There are two types of channels in the SDS100: conventional (single channel) and trunked (part of a system). Either can be analogue or digital, or a mix of the two, depending on how it's used.
Pretty good, with some caveats.....Got it that's a great explanation ... what's your opinon on using the sds100 to listen to ham radio?
That sounds awesome thanksPretty good, with some caveats.....
1: It won't decode all voice modes. It will handle AM, FM/NFM, P25, DMR and NXDN, but not SSB, D-Star and other digital voice systems not already mentioned. Fortunately, much of the digital voice activity in the last couple years have been moving to P25, NXDN and most especially, DMR, and away from D-Star and others. FM/NFM can be heard from the 10m (28MHz) band upwards, with most activity in the 144MHz and 440MHz bands.
2: Can it receive the ISS? Yes. Just be mindful of when the ISS passes over. You might not always receive voice, depending on time of day, but you might hear the bips of the packet repeater! (I have!)
The local ham repeaters, and the ISS voice channel, are in the Sentinel database.
I have a freqs that is really really strong and it causes a overload on my radios and i have noticed it only works when i'm around that one freqs i was wondering could i turn the attenuator on for that channel on the sds100 to help that?Pretty good, with some caveats.....
Ok what is IFX? i googled how to turn it on and it said function and then 7 . is that all or do i need to be on a freqs or what?Try the IFX feature, first. Otherwise, try the ATT feature.
I never could do it with the dongels but the sds100 has the option so just wondering . Thanks
