SDS100/SDS200: Finally got my sds100 need some guidance on programming it.
AngWay
Curious
Buchanan, Va
Is your SDS100 running off the Jpole thats hooked to DSDPlus?
Are you sure its 152.6825 and not 152.6900?
Something out of whack. 152.6825 is listed on the Honaker site on Stars, yet the license listed for that site does not reflect the freq.
I have all of it running off the J pole. and that is the site in radio ref for honaker 152.6825
AngWay
Curious
Buchanan, Va
here is a pic of it
AngWay
Curious
Buchanan, Va
I am going to reconsider this statement. Although the scanner is not tuned to the frequency you think is causing the interference, the attenuator will affect everything within the window that the sdr tuner is receiving.
so if i turn on attenutor for that site it will affect the signals around it as well turning those down to?
dave3825
Suffolk County NY
No, go into your DSDPlus folder and look for DSDPlus.P25data file and copy it somewhere, leaving it in your DSDPlus directory, then zip/compress it, and post it here.
AngWay
Curious
Buchanan, Va
Nothing at all with SDRTrunk.
Ok @RMason had said sdrtrunk ...but anyways' here it is i have not used it much accept for maybe the last hour so thats where u will see the most with the honaker trunk site.
why do you need this anyways?
  • DSDPlus.zip
RMason
Mississippi / Colorado
remiind me where is the data file at in sdrtrunk?
Aargh: I see where the confusion is coming from:
Out of curiosity: What frequencies are listed in your SDRTrunk.P25data file for the Honaker site? Are these the same as what is listed in the RR database?
I should have said DSDPlus.P25data instead of sdrtrunk.....
It is in the DSDPlus directory.
Sorry for the confusion - it's getting late.
RMason
Here is the information in the p25data file for the Honaker site:
Site: 2.13 NAC=192 BSI=WQBN418V ; Honaker
Neighbor: BEE00.19E-2.10 ; Whitetop Mountain
Neighbor: BEE00.19E-2.12 ; East River Mountain
Neighbor: BEE00.19E-2.14 ; Norton
Neighbor: BEE00.19E-2.16 ; Abingdon
Neighbor: BEE00.19E-2.17 ; Oakwood
Neighbor: BEE00.19E-2.28 ; Big Walker Mountain
Neighbor: BEE00.19E-2.32
Channel 3-2673: 152.6825 CC
Channel 3-2685: 152.7125 SCC VOICE
Channel 4-2350: 161.875 VOICE DATA
Channel 4-2400: 162. VOICE DATA BSI
AngWay
Curious
Buchanan, Va
yep i'm able to monitor the abingdon site and norton site as well and hear different talkgroups . the honaker site which is causing the problems doesn't have as many talkgroups on it and i can monitor abingdon and norton and hear everything i don't need the honaker site
RMason
Remind me: Did you try IFX and ATT on the Honaker site? What was the result?
AngWay
Curious
Buchanan, Va
yes i tried it but it didn't help when the overload hit the traffic completely cut out.
also is there a way to change the delay time for the whole system instead of doing it one freq at a time
AngWay
Curious
Buchanan, Va
also just to make sure i done it right with the IFX i put in all the sites in the 150mhz is that the right way or was i suppose to only put the one offending freqs?
AngWay
Curious
Buchanan, Va
And something that just bothers me to no end. i have dsdplus running and the sds100 running both on the same antenna both on the same channel and the sds100 will miss traffic sometimes and dsdplus picks it up. any clue why this might be .
