Baofeng Issue Programming BTech DMR 6X2 Pro
Engine79-7
Literally just purchased this radio. I like the features offered and I like the options the software gives. I have downloaded the CPS and ALL drivers for this cable. The radio seems to acknowledge the download and everything says it acknowledges and has been completed. But when the radio refreshes, it says "Program error, Please Initialize the Radio!" makes me hit confirm, then factory resets the radio. Does anyone have any guidance to this?
mitaux8030
Silent Key
Home
Sounds like the codeplug you're uploading to the radio isn't compatible. The firmware version installed in the radio, the CPS version software you use, and most critically the codeplug produced must all match in version number.
Using a codeplug that was initially created with a CPS of the wrong version won't match - and in some cases the radio will reject it (as it appears in your case) or in other cases more subtle unwanted effects can occur like PTT lag, random rebooting, features not working etc.
Best to learn how to build your own codeplug - that way you can have the radio set up exactly how you want it, not how someone else wanted it.
bharvey2
Try writing a minimal codeplug with one or two channels, talkgroups and such and see if you can upload that successfully. the firmware/CPS mismatch mentioned above could very well be the problem.
Engine79-7
So I read the radio, then started inserting frequencies then reuploading in small increments. This seemed to work. This is my own codeplug. Hopefully, this works. Thank you all for the feedback!
jaspence
Michigan
My experience finding on-line code plugs has not been great. As mentioned above, the version used to create the code plug must agree with the radio firmware. DMR CPS varies from radio to radio brand, and using another code plug from the same model radio to check formatting can be helpful when the code plug itself is not usuable.
bharvey2
Radios can get really picky about firmware/CPS mismatches and the inability to upload is just one possibility. I had an issue a while back with a new radio and a minor mismatch that allowed the codeplug to be downloaded to the radio just fine. However, the appeared to be malfunctioning. Once I got the firmware/CPS issues sorted out, the radio worked fine. - Lesson learned.
K2ERI
SC
would anyone know if i can use a codeplug from the 6x2 base model into a pro model?
KI5EDJ
WRDB542
Oklahoma City
Yes. You would need to import it into the CPS that matches the receiving radio's firmware. Codeplugs from the AnyTone 868 and 878 series are compatible in the same manner.
AF1UD
I know I'm a little late to the party. But I just tried to program one of my buddies radios. I upgraded the firmware, the icon firmware and wrote a brand new codeplug using the most recent release.
No matter what I do it will not take it. Did he get lucky and get a dud? Or did I mess something up here? I even tried programming a blank codeplug with 1 channel in it and it wouldn't take.
AF1UD
BTECH didn't send the correct programming software with the firmware package. K =/= J
Engine79-7
Read the radio, build your code plug once it is read then upload
radiochuck
Traffic Reporter
Phoenix, AZ
This radio has been driving me bonkers. While I’d prefer to use the RT Systems software that’s a bit sexier, the data that it writes to the radio is often a mess (wrong channels in scan lists and little annoyances like that). I don’t have that issue with the CPS from BTECH, but that software is sooooo slow and clunky.
Programming has definitely been the sore spot with this radio. I wish someone would build a CPS for this radio that just works.
I’m thinking about doing all of the codeplug programming in the RT software, exporting that data and importing it to the BTECH software, then writing to the radio from there. Maybe that’s the right combination. ??
This has been very frustrating. ):
W1SPS
Torrington, CT
Hey all, does anyone have a code plug for a 6x2 for anywhere in Connecticut? I've had this radio for 2 years and barely use it. I can get the local analog repeater but still can't get anything digital to connect. Also for some reason Parrot breaks up on receive. I really need something to follow.
AF1UD
On the CT ARES page there are basic code plugs for all the repeaters. Export it as an excel file and then load what you want into your code plug!
W1SPS
Torrington, CT
I will check that out, thanks. I may just get the new 6x2 pro, not only does it have upgrades but it can import codeplugs from anytone radios.
ems55
New Milford
Hi, just came across your January 2024 post about exporting the files on the ARES page in Excel format. Good idea !!! The code plug is 4-5 years old. Do you know of a more recent code plug ?? Want to program my Btech 6X2 (non pro)...
Going to try my RT Systems program.
Thanks & 73,
Michael WA1UZO
AF1UD
Not much has changed in 4-5 years around here. It's still good.
