Gmatthews120
New Wilmington PA
Hello. I am looking to aquire an nx-5200 to use as a ham radio and to scan my county fire frequency’s. They use a p25 phase 2 ICORRS system. I currently have a Uniden sds100 and it works just fine with the system. I confirmed that some agency’s in the counties use 5200s but they said they are pretty sure that when the radio connects it sends its serial number and the system will “block” the radio from being able to receive. Does anyone have experience with this? Obviously I would want recieve only.
hill
Middle River, MD
Kenwood radios can't do non affiliated scan like you can trick a Motorola radios to do NAS.
Best bet is Unication pagers or just keep using your SDS100 these radios are designed to monitor these type of systems and no crazy programming or getting your high dollar bricked for transmitting on the system.
Giddyuptd
Here and there
As said above you're best bet is a unication pager, bendix king, and Harris radio with proper firmware and software to non affiliate scan. Kenwood can do it however you would need a system key which is beyond a act of God to obtain unless you're the admin or dealer themself. With it one could passive monitor but you'd need to be on a system using the same system which you'd be authorized like fire needing to monitor police but not transmit. Average Joe it would be no go. Even then it's a controlled and locked down process for a agency to even do. Kenwood doesn't play and their dealers won't risk loosing their license.
Giddyuptd
Here and there
They are probably using the Viking vp5000 unless they need nxdn or dmr. Same radio different firmware with nx5000. But same process mentioned above no go for average user to do non affiliate scan. The ones showing it on YouTube got their friends to use a system key and they are at risk of Kenwood pulling their friends dealer license. They don't play around with the system key and non affiliate scan for legit agencies needing it.
