New Alinco DJ-X100 wideband receiver
dsankir
Adana-TURKEY
Thanks dsankir!
Main main PC still doesn't like the scanner (AMD CPU) , but parallels on my macbook did the trick.
Ran the upgrade, which went fine (see caveats below).
  • The hidden code (sqrt[2]) to enable POCSAG is now gone in the E-Model
  • All DMR channels where changed to NXDN(N) mode
  • All dPMR channels to NFM
  • ACARS,NFM,AM,D-STAR remained as is/was
  • CTCSS was also untouched
CSV Export does not include the bank information...
I definitely need better programming software for this unit !
All same here on T model.
Did hard reset after update,still no nxdn both 48 & 96.The rest working fine.
wokaokf
Can someone tell me that T version can decode NXDN 4800 ? Xingaonai got no luck even i had a full signal on single channel.İ m sure it s a n48 channel.
JensLK
Can someone confirm that newest firmware for E-Version works properly with original ALINCO program software? Especially Scan Banks and Bank linking? (Win11)
Many thanks.
Jens
dsankir
Adana-TURKEY
Same here,nxdn4800 single channel with full signal but no voice decoding.With Uniden i can listen all conversation.
imkesun
Many thanks.
Jens
Works on my Win10 Desktop and Win11 inside Parallels
Scanner is not recognized on my Windows Desktop with AMD processor, so xfer is done on the Mac
Cheers
JensLK
Same here: reading from scanner shows correct DMR on DMR channels in Edit Tool Ver. 1.0E but in the scanner same channel is switched to NXDN. That sucks!
Any solution? Has anyone contacted Alinco in Japan regarding this problem?
Brunlea
A bit of a GEEK!
Lancashire
Did you update the firmware? Alinco said that updating the firmware will reset / alter settings so channels will be on the wrong setting until you import again.
Always make a backup first with the EditTool before updating firmware :)
JensLK
For me the edit tool didn't work prior the firmware update...
And you still have an English Menu or is it in Japanese now? Sorry… this doesn’t look professional for me. I’ll try 4.00-04 for the E-Version later and when there’s any issue with wrong mudulation or wrong language the device will go back to the dealer.
jeanlouish
Saverne, France, Alsace, Bas-Rhin
After installing the latest version for European equipment, I have the menu which remains in English.
imkesun
Engilsh menu before and after firmware upgrade.
European Version
JensLK
Update successfully done. All menu still in English. First transfer of channels to the scanner was perfect: all Mods were sent correctly. No Problem!
I begin to love this thing… thanks guys!
dsankir
Adana-TURKEY
I stll dont have nxdn comms:(
JensLK
Does anyone see the HAM’s callsign when receiving in D-Star? I just can see the message text.
