Muxlow
Super Secret
Iv got me one of these. works good
I'm working on this one; had the same problem myself last week while roaming.- Channels entered while a site is active go away when the site does.
This is by design. I can't presume site 01. The worst part is the RR DB only provides frequencies - not channel numbers.Jay911 said:- Single-site Motorola systems (I think just Mot systems) report as Site 0 in UT, but are listed as Site 1 in the RRDB, so the downloaded data from the DB doesn't get recognized. This doesn't affect EDACS systems or multi-site (SmartZone) Mot systems because they specify site numbers.
It should pop-up a new site window and prompt you to enter the new control channel frequency. Do both systems have the same site number?Jay911 said:- If you go from one EDACS system to another EDACS system, the program doesn't recognize the new one until/unless you stop and restart the associated signal receiver.
When you download the system from scratch - are the control channel(s) marked as such?Jay911 said:- Still not able to get the program to automatically recognize a given EDACS system once the freq of the control channel is input.. but only when the data has been downloaded to a fresh, new system first. Example: If I download system 2345, then go tune in to it and try to get UT to use the downloaded data, it's a no-go. If I start UT first, let it tune in and find the system, then later download the data, it will accept the saved system when tuning it in again.
Snap! I'll fix that.Jay911 said:- This may have been mentioned before by you or others, but I can't seem to edit/add band plans on the fly. There's no + or - on the toolbar on that pane of the window.
Cool find. I never noticed this before.Jay911 said:- Lastly, if you open a receiver that's running and choose the Scope tab, it shows flatline even if the receiver is running. The scope is only shown properly if you started running the receiver in the same "window session" as when you chose to view the scope. Hope that makes sense.
The bandplans are per-site. Are you monitoring a T-band site which has 450 Mhz neighbor sites? Unless you directly monitor a site - the program won't assume the same bandplan applies. The previous generation had a "push bandplan to all sites" menu option - which is probably what is needed here.Mattsenft said:It does not however populate the 450 sites with the frequencies. I checked all the LCNs against the frequencies and they are correct. Is it possible that the program is thrown off with the multiple bandplans?
That was reported - and fixed. I need to get this new version out there.And the delegate function isnt working on NSWGRN
Several folks have reported problems; they were able to successfully download bandplans from the RR DB and import bandplans from their old data files - but not create / edit new plans.Tried stopping / starting, also used + button to add a new blank band, but they're not editable. Anything I'm doing wrong?
Zero out the frequency for the incorrect channel. Make sure none of the channels are marked as "Confirmed". The bandplan won't override these. Note: the highest possible channel number is 759 (but the 809 won't cause any harm).The site I'm on has 10 channels, but the program only shows a freq for the first one, and it's not right yet.
It is in kilohertz ... just as you described above; so entering "12.5" should work. I don't know why you're getting 484.1250 instead of 482.2125.Based on that, the program says ch 397 is 484.125, but it should be 482.2125. I'm getting 125 KHz instead of 12.5. What's the right format for this field?
