NX-5700F variant programming challanges
ejd91717
Summerville, Ga
I was given a NX-5700F variant as a gift for Christmas, radio was purchased from an electronics recycler on ebay. I have a valid and licensed copy of KPG-d1n along with firmware from a dealer.
I'm able to read the radio's entitlements, and get its basic personality, but anything beyond that I encounter one of the following error messages:
"Reading data from this transceiver is not permitted"
When attempting to write a blank codeplug with a single analog conventional channel, I receive the following message:
"Writing this data is not permitted for this transceiver"
Radio was received with 3.0.0 firmware, I attempted an upgrade first to 4.6.0 and then 5.1.0, without any change, I'm using 5.2.0 for the FPU version.
Is there anything else to try before sending this radio back to the seller? Is this something a dealer or depot can assist with or is it better to cut losses and attempt to return the radio?
Radio has P25 Phase 1 conventional, p25 OTAP, nxdn, nxdn OTAP, a AE-30 SCM (FW 2.0.1) and the simplified license.
I'm trying to remember what the "F" destination code on the model number means. It's not one of the standard ones, but I'm having trouble finding any reference to it, or remembering what it meant.
But I think that's your issue.
If you can return it to the seller and get your money returned, that's probably your best plan. Software would be the challenge in reading/writing to that radio, and I'm not sure if there's an easy solution.
Maybe someone else remembers what the F destination code is and can enlighten both of us.
Did some searching of previous posts, and it looks like the F market code were for federal radios, or radios bought under federal grants. Kenwood NX-5000 Model Number Meaning
As for why it's not readable/writeable, that might be the password, but it should pop up and ask for it. If it's not asking for it, there may be something else going on.
dapaq2
Northwest Indiana
I am thinking the "F" designation may be for the forestry service? KPG-D1 is usually for "K" designation, but you have "F". It sounds to me like you have the wrong version/model of software for that radio.
ejd91717
Summerville, Ga
No prompting for password, Interestingly enough, the d1n lists the radio as a K/F under model name. this is a weird one for sure.
ejd91717
Summerville, Ga
I attempted to write a clean codeplug with the multideck feature unchecked, also tried to write to the radio with the multi deck feature without success.
I'm not super familiar with the 5000's
tweiss3
Is it time for Coffee?
Ohio
I have a 5300F6 that I have no issues with D1N. That sounds like it's password protected.
kd4efm
EL98 Florida
Simplified license means it's a special radio for a specific (like fw specific aka custom data code plug) agency. Which no clue but think of it as a locked to agency key.
I will check with some inside people and get a you a clue as to what it means.
AM909
Radio/computer geek
SoCal
F is for Fed – there is at least a USFS version of the radio that's an "F" model. There appears to be a KPG-D1NSLK that is for "federal and class I railroads". The railroad versions of the 5700 appear to be "K" models.
It doesn't look like a password issue, though maybe that's what happens when you exceed the try count, which I don't recall having seen.
The firmware shows 5.10.00. You could try updating to 5.20 to match the KPG-D1N – there was some kind of issue about version matching in the last year or so but the details escape me.
I'll note it has a KWD-AE30K SCM crypto module. I'd wonder where the radio came from.
kd4efm
EL98 Florida
This is the reply I got this morning, along with some other non-public information.
"There is no work around for this, only way to make it work with regular KPG-D1N is to have the option removed from the radio by Kenwood."
Be prepared to explain how this came into possession when you take it to your local dealer to have it sent to Long Beach Tech Support to have it removed.
AM909
Radio/computer geek
SoCal
... "There is no work around for this, only way to make it work with regular KPG-D1N is to have the option removed from the radio by Kenwood." ...
Do you know which option he meant? The simplified license?
