ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
Hillside1
I removed my BCD536HP dongle and want to record using straight audio cable. I changed my input sound device to Primary Sound Capture Device but I get the Proscan error message "Unable to open source client...….Undefined external Error". The cable itself does not appear to be the problem because I can hear the scanner audio on my computer speakers. I've tried using a BCD996T and I still get same message. I've tried changing to MIcrophone input, but still with same results. I've tried both the back and front input jacks and still the same message. Any thoughts? TIA.
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
Excellent. Thanks Paul
Here is the latest preview of ProScan version 14.8 with NXDN support for the BCD325P2 & BCD996P2 scanners.
If you downloaded the earlier preview version 14.8, I suggest downloading this.
This isn't the official release so it's not packaged into a setup file and will not show if checking for newest version within ProScan.
This is just the executable. Unzip and copy the exe file over the original. Stop ProScan first.
https://proscan.org/ProScan.zip
Let me know of any issues and especially with NXDN.
{edit} Also, as UPMan advises "Color Code, RAN, and Area Code will probably be changed to Search. " so you will need to check the trunking frequencies on DMR and NXDN systems.
Downloaded this version and imported REM Comm: https://www.radioreference.com/apps/db/?siteId=22856
LCN CH ID's are not correct
IMPORT:
RR:
Houk
ProScan
Software Provider
Ontario, Calif.
Getting an FTP write error
Error Writing To The Scanner.
I have read and written to this in the past.
Try Again.
ftp://192.168.1.207/favorites_lists/f_000008.hpd
System.Net.WebException: The remote server returned an error: (550) File unavailable (e.g., file not found, no access).
at System.Net.FtpWebRequest.SyncRequestCallback(Object obj)
at System.Net.FtpWebRequest.RequestCallback(Object obj)
at System.Net.CommandStream.InvokeRequestCallback(Object obj)
at System.Net.CommandStream.Abort(Exception e)
at System.Net.FtpWebRequest.FinishRequestStage(RequestStage stage)
at System.Net.FtpWebRequest.GetResponse()
at FrmFTP.FTPDeleteFile(String ServerAdress, String Path, String File, NetworkCredential Credentials, String& Error)
Did you try again? Does it happen repeatedly?
ProScan
Software Provider
Ontario, Calif.
The OS is sending the error. I would first try to select another selection. If that doesn't work then restart ProScan. If still doesn't work then reboot the computer.
ProScan
Software Provider
Ontario, Calif.
Here is another preview of ProScan version 14.8 with NXDN support for the BCD325P2 & BCD996P2 scanners.
If you downloaded an earlier preview version 14.8, I suggest downloading this.
This fixes the incorrect LCN numbers on NXDN systems.
jasonhouk
Uniden AlphaMan
Marion, Ohio
Issue is still present importing from RR.
Houk
Hillside1
I've restarted both computer and ProScan. All attempts result in the undefined external error. I also thought maybe OS problem but I wouldn't know where to look next.
