ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
Shirebx
Would there be any conflicts installing two basic sound blaster sound cards? Then plus the motherboard sound card would give me the three jacks thats I need.
wireless_friendly
Banned
No. You can install as many Sound Cards as you need. Even identical ones. They will appear with numbers in brackets (1), (2), etc.
ProScan
Software Provider
Ontario, Calif.
In theory it should work but never can be sure with Windows.
I don't think you will need two sound basters plus the motherboard? Does the motherboard have two inputs and one of them stereo? That should be all you need. I believe your Akai EIE Pro should work. The ASIO driver will need to be disabled first .
Shirebx
You think the Akai would work if I disable the driver? Doesn't the device need a driver to work? Im open for trying, Im looking at soundcards (pci-e) are not as cheap as your standarc pci card.
richad
Sydney, NSW
Hi all,
Not sure if that is even possible, however I want to attempt to embed the live scanner display into a website. So instead of having to enter the admin password to see the display, it will show up instantly.
Please let me know if that is in the range of possibilities.
regards,
RIchad
lep
my 785 was just returned from Uniden repair where they restored the ability to use computer control. I have now connected to my PC and downloaded an 800 MHz system from rr.com. It all looks good in ProScsn and a log is being created under virtual control,
query? how do I make the "text tag lines" which are in the downloaded database appear in the log? what is logging is just the channel number althogh the correct label IS in the db, I am sure the fix is simple, I just don't know how to do it.
ProScan
Software Provider
Ontario, Calif.
The Text Tags should show in the log. Does the Text Tags Lines 1 & 2 show on the scanner display? Does any of the text tags show in the log or none at all?
Go to the "Test" tab and look at the box on the left showing the returned scanner data. Do you see the text tags there?
What ProScan version are you running?
The next version not out yet has an option. "Scanner Data To File" that may be helpful in this case If you email me, I can send you a pre-release version of 6.7. Turning this option on writes the returned scanner data to a text file. Email me the scanner data file and I can see what''s going on.
ProScan
Software Provider
Ontario, Calif.
Version 6.7 Is out
Version 6.7
  • Added - BC346XTC scanner support.
  • Added - Database - XT Series scanners - HTML & CSV export / print now with a Numeric Tag section.
  • Added - Option "Scanner Data To File". Logs all data from scanner to a file.
  • Added - Performance graphs showing CPU utilization and memory consumption.
  • Improved - Logging & Recorder - Improved grid performance.
  • Improved - Remote Scanner Over IP Client connecting reliability.
  • Improved - Remote Scanner Over IP Client Auto Start reliability.
  • Fixed - Logging & Recorder - Option "New Entries Auto Sort" wasn't working correctly.
  • Fixed - Logging & Recorder - Option "Logging Grid Auto Delete" was deleting data when computer Region set to other countries date formats.
  • Many more small improvements.
ProScan supports the BCD996XT, BCD396XT, BCT15X, BC346XT, BC346XTC, BCD996T, BCD396T, BCT15, BR330T, BC796D, BC785D, BC780XLT, BC296D, and BC250D scanners.
ProScan is the most powerful and feature rich scanning software in this world.
kma371
Not able to get the "Remote Scanner Over IP" function to work.
I'm running ProScan 6.7 on a remote location. When trying to connect on the client end, I get a "Server Not Responding Code 1" error. Was working in previous versions 6.6 <
lep
I was using 6.6 but have now switched to 6.7 Under the 'Test' tab what I see on the 3rd line is the proper 'test tag' and it is displayed on the screen. But what appears in the LOG is Text Tag line 2, not the label which is in the database as Text Tag Talk Group label.
So, the data is all in the db, I it appears to be just a mis-understanding on my part of how to set-up the options. I normally use my 996XT to log my 700 MHz system but one of my systems is still on 800 MHz so I got Uniden to repair my 785 so I could log both side-by-side on the screen.
ProScan
Software Provider
Ontario, Calif.
Send me an email and I'll send a test file or two and we will get it fixed. The sooner, the better. Thursday will be a good time.
ProScan
Software Provider
Ontario, Calif.
What do you think the timeline is for the new scanners and proscan?
I may or may not do depending on my work load and schedule. I'll give it consideration in January after I had time with the unit. It will be fun to do and will take five or six months to complete but not saying yes or no at this point.
INDY72
Indianapolis, IN
Considering they won't be on open market til Marchish, that will not be too bad a wait for the guys getting them. 6 Months puts possible PROSCAN for them only 3 months after they hit open market. Thats not bad at all Bob.
N1IRL
Budd Lake, NJ
ProScan 6.7 and BCD996XT
Hello Everyone,
I used ProScan 6.7 to load the Morris County MIRS system in my Uniden BCD996XT. Everything seems to be working except I get no audio! (yes, the volume is turned up). I see talkgroups on the display but no audio. Anyone have any ideas or experienced this? Can the BCD996XT monitor the Morris County MIRS system?
Appreciate any input.
Rick
N1IRL
