ProScan
Software Provider
Ontario, Calif.
As the subject line says, How do you decipher what the logs give you?
I stumbled across what it is showing as LTR
and get output like:
02/28/14 10:16:43,LTR,1-0D-1C-6E-1A
02/28/14 10:19:35,LTR,0-19-18-45-00
02/28/14 10:54:20,LTR,1-11-18-05-00
02/28/14 11:00:46,LTR,1-11-18-05-00
02/28/14 11:36:14,LTR,1-1F-1D-7F-13
02/28/14 12:46:36,LTR,0-01-18-45-00
02/28/14 14:31:52,LTR,0-17-17-CF-1F
02/28/14 03:45:46,LTR,1-17-1B-EB-16
02/28/14 04:30:51,LTR,1-11-18-05-00
02/28/14 05:10:25,LTR,1-11-18-05-00
02/28/14 05:17:54,LTR,0-09-18-01-00
02/28/14 06:08:41,LTR,1-0E-1F-AB-1B
02/28/14 06:43:20,LTR,0-10-18-47-00
02/28/14 07:03:06,LTR,0-1E-1F-AF-1F
02/28/14 07:17:59,LTR,0-11-18-15-10
02/28/14 07:48:57,LTR,1-11-18-05-00
Then anything P25 is like this:
02/28/14 03:19:52,P25,35CF904E0F6A800000008033
02/28/14 03:26:14,P25,1556A8002A55555801555150
02/28/14 03:26:14,P25,37FD001B1077813A0000B1AE
02/28/14 03:26:14,P25,1B1B25FA1596710068053C07
02/28/14 03:26:15,P25,155697EAFF00555801555155
02/28/14 03:26:15,P25,37FD001B1077813A0000B1AE
02/28/14 03:26:15,P25,1B1B25FA15AA710068053C07
02/28/14 03:26:16,P25,A9004F4F0E280007A404E14B
02/28/14 03:26:16,P25,37FD004F1077813A00009AFF
Your question may be better answered in Trunking Control Channel Decoding - The RadioReference.com Forums by one of the the Control Channel gurus. ProScan just displays the C-Ch output from the scanner and doesn't interpret or alter the output.
ProScan
Software Provider
Ontario, Calif.
ProScan 7.0 Just Released
Version 7.0
  • Added - Start Up Options - Added options for auto starting the Source Client, Web Server, and Scanner Over IP when program loads.
  • Added - Source Client - Broadcastify My Feed button. Click to see your feed details on the Broadcastify web site.
  • Improved - Changed the RS-232 Serial Port .Net framework control as it was causing high CPU cycles for a few users.
  • Improved - Audio meters changed from peak to RMS average values.
  • Fixed - DMA Database - Sort wasn't working if individual system was selected.
  • Fixed - Recorder Options - Prepend buffer setting needed ProScan restart to take affect.
  • Fixed - Web Server - If a "#" character was in the file name then file wouldn't server.
  • Fixed - Intermittent lockups and/or high CPU usage.
  • Many more small improvements.
ProScan supports the BCD996XT, BCD396XT, BCT15X, BC346XT, BC346XTC, BCD996T, BCD396T, BCT15, BR330T, BC796D, BC785D, BC780XLT, BC296D, and BC250D scanners.
ProScan is the most powerful and feature rich scanning software in this world.
ProScan
Software Provider
Ontario, Calif.
Bob, will Proscan ever work the new Uniden's?
Not sure yet. I'll like to but it will take 6 months or so to do it. Don't really have the time now. My day job of 28 years seems to be around the clock which is taking most of my time and the wife planning a vacation so we'll see.
KC2ZHY
Somerville, NJ
Is there any way you can throw together a "lite" update for the x36HP's that only involves the features that involve downstreaming data from the scanner but none of the upstreaming features (i.e. logging / recording, source client, and remote control over IP)? I figured just doing these things wouldn't be so intensive but it would at least give current feed providers like myself the ability to remote control over IP, which is really what I'm looking for at this point. At least something to hold me over until you add all the other features we're accustomed to.
Of course, I have no idea how long that might actually take to integrate into what is already done, so if this is still not feasible, then disregard!
ProScan
Software Provider
Ontario, Calif.
ProScan for the BCD536HP - First Look
The development is underway. The BCD536HP and BCD436HP support should be ready for beta testing end of May.
First look of the virtual scanner.
MesquiteWx
Texas
WHAT, WHAT, WHAT!!!! This is GREAT news! I am so happy you decided to add support for this.
THANK YOU SO MUCH!!!
Let me be the first to sign up for beta testing if possible!
How is the recorder going to work with no record out line?
kruser
Well Known Member
W St Louis Cnty, MO
Proscan 7 works pretty well with the x36HP models for logging right now. Even some of the keys work and the volume/squelch controls work form the virtual scanner screen.
Of course no database functions work plus Proscan cannot parse and display the LCD display data correctly so the virtual scanner display window is all goofy looking.
For logging, the only thing I could find wrong was that it truncates all but the last three digits of a radio ID. Not sure if it does the same for talkgroup numbers as the system I was testing with only uses single digit TG's. It logs the other info correctly but I did not test tone logging (PL DPL).
You just need to set the scanner type to a 396 or 996 XT model and Proscan will log and allow some of the virtual control buttons to work as well as the volume and squelch controls on a 536HP.
Even though ProScan does not currently support the x36HP models, it does do nice logging and I already like the log display better than the others out there that are made for the x36HP models only. Even with the RID truncating the data down to the last three digits. I was very surprised at how well ProScan logged knowing that it does not yet support the x36HP models. I guess Uniden left a lot of the serial control commands the same as they are in the XT models.
I like it as it displays and logs the actual frequency, TGID, RSSI along with any tone and RID and text tag info unlike Butel's log and ScannerScreen's log which both replace the actual frequency with the TG number in their log screens when monitoring a trunked system. Both are still being developed though and that info could be added.
I've always found that info handy when working on a problem system as not all frequencies hit me with the same signal strength likely from different antenna placement on the tower. Logging the actual frequency and RSSI along with the TGID is handy in my eyes.
I do like the looks of the virtual control screen for the upcoming new version!
I see it has a database button also so maybe there is a way to get access to the SD card and your favorites when in serial mode. I suppose it could require one to place it into mass storage mode first when using the database functions but it would be cool if all could be done while in serial mode or when using the rear serial port that many are now doing to get around the USB disconnect issue that many are seeing.
Keep up the great work Bob!
ProScan
Software Provider
Ontario, Calif.
You're welcome No need to sign up. The beta testing / suggestion program will be open to all. I'll post here as significant progress has been achieved.
One way is if normally using the computer speakers to listen to the scanner audio then just use the ProScan loopback function to feed the audio back in to the speakers. The database will have a Record setting "Off, Marked Channels, All Channels"
MesquiteWx
Texas
Just a suggestion as none of us know exactly how the app is suppose to work but, knowing how networking and remote based apps work. I am assuming there will be a firmware update to the radio to include an internal web server so the app can connect to it. If this is indeed the case would a LAN based recording option be possible? Like instead of selecting a sound card like you do now you would enter the LAN IP of the scanner? In theory it sounds logical but computer programing is out of my pay rate so I don't know how that would work if possible. If it is something that could work I think the only issue I would see would be lag between what it is reading from serial vs what it is recording.
ProScan
Software Provider
Ontario, Calif.
I'm not sure at this point if the SD card can be read /written from/to the serial port. I hope it can be. It's about a week or two from getting hands on with the database.
eaf1956
Evansville, IN
Proscan version 7 and Norton
Anyone else getting a Virus alert from Norton? I have had ver 7 for over a week now and all of a sudden this pops up. Even tried to d/l 7 from Bob's site and when it installs I get a virus alert and it deletes Proscan. Went to my feed computer had it had a virus alert too. I had to reinstall Proscan version 6.8 for my feed to run. Even the file I d/l ed a week ago of ver 7 gives me the virus alert.
BTW Bob the version with BCD536HP support looks good
ProScan
Software Provider
Ontario, Calif.
The false positive has been reported to Norton. I suspect the latest virus definition caused this as I haven't heard of this problem until this morning.
eaf1956
Evansville, IN
It deletes the proscan program completely. It didn't do it with version 6.8 So you say this is a false positive from the Norton Internet security? It started on this computer by denial of internet access to Proscan. Then upon trying to fix that the virus thing started and deleted the proscan.exe file. Not sure when Norton was updated. Anyway thanks Bob!
ProScan
Software Provider
Ontario, Calif.
Here is Symantec's response
In relation to submission [3468161].
Upon further analysis and investigation we have verified your submission and as such this detection will be removed from our products. The updated detection will be distributed in the next set of virus definitions, available via LiveUpdate or from our website at Virus Definitions & Security Updates - Symantec Corp.
JWaller
Arroyo Grande, Ca
The scanner records to the SD card, so no output connection is necessary. Therefore, you can record even when you are on just battery power.
