Scanner Screen software for 436 and 536
Vonskie
Allen, TX
Thank you very much for the program I am using it with my Uniden 396t scanner and it works with Windows 8.1, I also tried it on my 55 inch LED flat scree TV and it looks perfect, The only question I have is how do you get Text to Speech to work ???.
Steve
Just click the check box and it should work.
davenlr
North Little Rock, Ar
Thanks. Nice program. Ill second the request for a resizable window. ARC wont resize either and it costs $60 :)
Vonskie
Allen, TX
Glad its working for everyone, let me know what uniden scanner you are using and OS.
Also send me comments, and I may add some more features based on the comments.
Happy scanning!
redburgundy
Doesn't always shut down properly.
Sometimes I have to go into Task Manager to kill it.
Even then, a Process called ScannerScreen.exe *32 persists that I can't kill.
phask
zanesville
No joy - HP1 and Win8.1. Changed default com to 115200, tried all 4 com ports.
Vonskie
Allen, TX
Could be that it is trying to talk to the scanner via the serial port or the Text to Speech routine has not finished yet.
If you wait for about 20 or more seconds does it go away?
chuck_e7
Grayson, GA.
Scanners with display pgm
Happy scanning!
I'm using with BCD536HP and BCD996XT, work great. Long names sometimes cause the text-to-speech to choke though. get occasional crashes with TTS running. Good job though!
davenlr
Happy scanning!
Windows 8.1, Uniden BCD536HP
Request: Resizable screen and/or a smaller font version I can hide off in a corner of the screen.
pratzert
Vonskie,
Thank you for that very useful program. Now I don't have to keep the backlight on all the time.
It's great !
Vonskie
Allen, TX
Just posted a new version .02 closes the speech object when finished speaking.
<see latest post for URL>
Just copy the new version of scannerscreen.exe over the old version on your desktop
DrCranky
Stark Co. Ohio
Vonskie,
Nice little program, using on XP & Windows 7 on the 536 & 436 with no issues. But would like to see a adjustable window size if that is possible.
NYRHKY94
Brunswick County, NC
Thanks for the newer version! Using it here on XP (32-Bit) & Win7 (64-Bit) with a BCD536P. Adjustable window size would be a nice enhancement, along with a 12-Hour clock.
chuck_e7
Grayson, GA.
Still crashes after a bit with TTS. Using Win 7 64bit. With TTS off, works fine. If no one else has pblm, could be my machine. Will chk with LapTop later. Tks for your work, at least you are ahead of some of the other projects coming.
Vonskie
Allen, TX
Have you installed the serial driver for the HP-1? And confirmed the comm port sometimes it puts it on com port 20. Look at device manager once serial driver is installed.
Vonskie
Allen, TX
Newer version am/pm clock
