Sticky Thread For MilAir VI (2011)
Tech792
Central NJ
Have also heard BDU-33's (practice bombs) in use at the Warren Grove Range.
05/16/11
HOIST 92 landing McGuire 118.65
TEAM 15 & 16 working A/A 303.0
A lot of EVERGREEN and GIANT AIR coming in and out of KWRI last few days (Contracted aircraft)
05/17/11
1530 local- MAPLE 04 coming through NJ/NY 282.3 then 350.3 @ FL270 (sounded like a flt of 1)
1910 local- OPEC 03 setting up an AR on 324.6 with ROUGH99? (sounded like)
I've had 126.2 in radio last 3 days. Absolutely nothing received here in CNJ on the counter.
freqhopping
Logged the prototype YC-17A 87-0025 today as ARRIS08. Seems to have landed somewhere relatively local since I had it down to 4300ft. Staging somewhere for the JSOH?
C-130 08-3173 has been around the last two days as TBIRD15.
AE1245 was RCH2784 today, so it's most likely 62-1784.
Nice catch on that Edwards C-17 (ADFC4A) #87-0025.
Hopefully sticks around for the airshow.Rarely leaves Edwards test range.
AE1245 C-130E is on weekly Tuesday Dover milk run.Nobody has posted this tail yet but is probably in 62-**** range.
Reach # is mission number.A while back into Dover was Reach 2041.
Will depart tommorow back to Scott AFB then onto Colorado then Travis by Friday and then back to the 19AW.Same routine every week from the 19AW.
Guess you could call it the old AMC C-5 weekly base milk run.
mdmonitor
Logs, 17 May
ACY-Atlantic City NJ (KACY)
ADW- Andrews AFB MD (KADW)
BW- Bay Watch-NAS PAX Area Advisory Control
DAA- Davison AAF, Ft Belvoir VA (KDAA)
DCA- Reagan National Airport/CGAS Washington, Wash DC (KDCA)
DOV- Dover AFB DE (KDOV)
GK- Giantkiller (FACSFAC, Virginia Capes)
LFI- Langley AFB VA (KLFI)
MTN-Martin State Airport, Baltimore (KMTN)
NGTF-Northrop-Grumman Test Facility, Baltimore (KBWI)
NTPS- Naval Test Pilot School, PAX
PAX-NAS Patuxent River MD (KNHK)
PTC- Potomac Area TRACON
WRI-Joint Base-McGuire-Dix-Lakehurst NJ (KWRI)
ZBW-Boston ARTCC
ZDC- Washington ARTCC
ZNY- New York ARTCC
1. VHF/UHF: ((Times are EDT))
((Some acft idents from local Mode-S collection))
0735- PAT 222-land at ADW. Depart ADW at 0845 then w/ZDC Calvert (133.9) cleared to Richmond VA. At 1422 w/ZDC Calvert (133.9) w/flt route up to New Jersey area.
0737- Reach 644T (C17A 02-1103 62AW McChord AFB WA)-land at ADW.
0940- 7A501 (UC-12 # 161501, AOD PAX)-land at PAX.
1124- JA 513 (Id as P-3-VSX-1 PAX-pilot has heavy German accent)-w/PAX departure (121.0) for restricted area for 45 mins of "work"in block 5-7,000 ft then return for the tower pattern.
1125- Blackjack 1 (HH-65C, CGAS Wash)-calling Pit Boss (157.05)
1140- Marine 101 (C-37, MWHS-4 ADW-usually USMC Commandant's acft)-land at ADW,
1141- PAT 1268 (C-12, DAA)-depart DAA.
1151- Army 1778 (C-37 # 04-1778, OSACOM ADW)-land at ADW.
1200- Reach 643T (C-17A # 07-7178, 3rd AS DOV)-depart ADW
1400- 7A326 (UC-12 # 161326, AOD PAX)-depart PAX (121.0) then w/ZDC Calvwert (133.9)
1430- Navy 7C196 (UC-12, AOD NAS Chambers VA)-land at DAA. Depart DAA at 1503
1440- Convoy 4046 (C-40 # 165832, VR-58 NAS Jacksonville FL)-w/ZDC Cape Charles (132.55)
1441- T-Bird 15 (C-130 #08-3173 317AG Dyess AFB TX)-w/Griffin CP (378.1) w/inbound msg.
1445- Army 301 (UC-35 # 01-0301 OSACOM ADW)-land at ADW.
1446- PAT 396 (C-12 # 84-24380 2-228th Avn KWRI)-depart ADW
1448- Reach 0315 (KC135R 60-0315 126ARS Mitchell Field WI)-land at ADW.
1512- PAT 262-land at DAA
1514- Tester 22 (T-6B # 166042, NTPS PAX)-w/BW (256.5).
1519- Plane Finder shows E-6B # 163920 (VQ-4 Det PAX) at FL330 over MD Eastern Shore. At 1521 now at FL360 and appears to be orbiting just southeast of PAX. Not on ATC freqs.
1619- Army 052 (UC-35 # 001052, OSACOM ADW)-land at ADW.
1707- Marine 740 (UC-35 # 166740, MWHS-4 ADW)-land at ADW
1709- Banger 21 flt (F-16s, 119th FS NJ ANG ACY)-w/ZDC Snow Hill (236.825) then w/ZDC Casino (285.4)
1922- Plane Finder shows E-6B # 163918 on the approach to PAX at 3,000 ft.
2. HF: ((Times UTC, Freqs KHz))
08971.0 Falcon 71A (P-3C, NAS Jacksonville FL): 1439 USB w/Fiddle (TSCC Nas Jacksonville FL-not heard) w/QSL for unheard info.
Ron (mdmonitor1@verizon.net)
Baltimore MD (390747N 763711W)
VHF/UHF: BC-895XLT/RS Pro-2045
Diamond D-130J discone
HF: Icom R75
45-ft PAR EF-SWL
freqhopping
AN-124 RA-82047 VDA107 inbound for Andrews now.
The NASA Super Guppy is on it's way back to KPHL again this evening.
2025- E-6Bs 410 and 388 are chatting on Shadow Ops 310.15
Looks like 410 is outbound. 388 is 45 minutes and not on mode-s yet.
2028- 388 just showed up
Tech792
Central NJ
05/18/11
1045 local- JEDI 41 landing KWRI runway 18
1143 local- HOSER 34 working HUNTRESS 255.0
2100 local- BICEP flts (x4) working HUNTRESS in one of the warning areas 135.225, 255.0, 312.3, A/A 140.175, then AR with OPEC 38 on 288.0
2120 local- Sounded like "8000" calling "91" then idol chit chat, poss mechanical problem on 292.8
freqhopping
Looks like 2307 may be the HC-144A on display for the JSOH. Seems it may have landed at ADW around 1400 today.
mdmonitor
Logs, 18 May
ZBW-Boston ARTCC
ZNY- New York ARTCC
0723- Reach 609T (C17A 07-7180 437AW Charleston AFB SC)-land at ADW
0732- SAM 49 (C-20C #85-0049 SENEX acft 99th AS ADW)-depart ADW.
0745- Reach 628T-land at ADW. Depart ADW at 1021.
0831- CG 101 (C-37, CGAS Wash)-depart DCA.
0841- Venus 23 (C-20C # 86-0203, 99th AS ADW)-depart ADW. Returns to ADW at 1043 for some pattern work.
0842- Army 053 (UC-35 # 00-1053, OSACOM ADW)-depart ADW.Return to ADW at 1630.
0902- Tester 16 (T-38C # 70-1575, NTPS PAX)-w/Tester Base (123.2) w/area wx PIREP
0912- Nighthawk 2 (HMX-1 MCAF Quantico VA)-w/Wash helo (134.35)
0915- SAM 797 (C20B 86-0206 99th AS ADW)-land at ADW. Departs ADW at 1509.
0920- Marine 740 (UC-35 # 166740, MWHS-4 ADW)-depart ADW.
0921- Venus 41 (C-37B # 97-0401, 99th AS ADW)-depart ADW. At 0940 Plane Finder shows 97-0401 over DOV at FL 110 heading north into NJ.At 0953 Plane Finder shows him at 2,000 ft doing some patterns at ACY. At 1105 Plane Finder shows 97-0401 doing some patterns at DOV.
0925- Acft 929 (poss V-22 Osprey, VX-20 PAX)-w/VX-20 Base (285.2) advising they are 10 mins out--will leave left engine running & want to swap out SDPS (???) unit for new then go back out to restricted areas. Departs PAX again at 1033.
0929- Convoy 2951 (prob C-20G # 165151 VR-48, ADW)-depart ADW.
0930- Score 92 (unid, VX-20 PAX)-check in w/BW (305.2 & 270.8) to operate in the restricted area for one hour.
0938- Army 112 (C-12J # 96-0112, CARA Avn Det Phillips AAF Aberdeen MD)-depart ADW.
0951- Reach 624T (C17A 09-9210 )-depart ADW
0956- PAT 1204 (C-12, DAA-Tidewater Shuttle)-depart DAA.
0957- Reach 618T (C17A 06-6165 3AS DOV)-depart ADW.
1004- Reach 620T-depart ADW
1011- Evac 30115 (KC-135R 128th ARG, WI ANG Milwaukee, WI)-depart ADW. Started to use callsign Upset then changed to Evac.
1013- Yankee 95 (KC-130 VMGR-452, Stewart ANGB, NY)-land at ADW.
1015- Venus 93 (C-32A # 99-0003, 1st AS ADW)-depart ADW then w/ZDC Calvert (133.9). Return to ADW at 1403.
1021- Score 34 (unid, VX-20 PAX)-w/ZDC Calvert (133.9)
1023- Plane Finder shows C-32 #00-9001 from 150th Special Operations Squadron NJ-ANG Joint Base-McGuire-Dix-Lakehurst NJ (KWRI) doing some patterns work at ACY.
1044- Blackjack 2 (HH-65C, CGAS Wash)-w/Wash Helo (134.35)
1051- Unid acft (no call noted)-w/Crab Ops (384.1) w/inbound msg. Will be RON at MTN.
1144- Two acft (no calls noted)-working on KWRI tanker A-A (139.875) coordinating rendezvous in block FL210--220
1145- Omaha 47 (US Customs BE-200 N72472)-land at ADW
1154- Army 052 (UC-35 # 00-1052, OSACOM ADW)-depart ADW. At 1645 w/PAX Base Ops (302.55) w/inbound msg.
1201- Army 1778 (C-37B # 04-1778 OSACOM ADW)-depart ADW.
1204- Navy 692 (C-20D # 163692, VR-1 ADW)-w/ZDC Calvert (133.9) requesting to hold over Richmond VA due to wx.
1208- PAT 245-land at DAA
1400- Army 00257- w/ZDC Calvert (133.9)
1423- Nighthawk 8 (HMX-1 MCAF Quantico VA)-w/Wash Helo (134.35) enroute to NAS Anacostia.
1428- Southern 9820 (B-747-200 N820SA Origin Chicago O'Hare Intl (KORD) Destination Mc Guire (KWRI)-w/KWRI CP (134.1) w/inbound msg. Also shown on Plane Finder.
1429- Air Transport 540 (DC-8 N71CX)-landing at BWI after departing Patrick AFB FL. Thanks to Al Stern in FL for the tip off.
1430- Crab 16 (C-27J #09-27016 135th AS MD ANG MTN)-w/Crab Ops (384.1) advising they are in a wx hold. Advises next crew that wx at Harrisburg PA is "iffy". Will do ERO (engine running offload).
1447- SPAR 11 (C9C 73-1681 73AS Scott AFB IL)-land at ADW
1448- Navy 7A501 (UC-12 # 161501, AOD PAX)-land at PAX
1514- Visual of N161NG & N162W (both BAC-1-11s, NGTF) departing BWI and going out to "play" at the PAX areas, near Wallops Island VA. At 1522 up on NGTF discrete (123.225). Also w/ZDC Cape Charles (132.55). At 1613 they advise ZDC that they are complete and are RTB BWI. At 1649 N161NG works w/Rooftop (123.225).
1517- SAM 91 (C-32 # 98-0001, 1st AS ADW)-depart ADW.
1535- JOSA 632-depart ADW.
1553- Cougar 92 (C-21A # 84-0077, 457th AS ADW)-w/Griffin CP (378,1) w/departure msg.
1620- Navy 209 (-C37B 166378 VR1 ADW)-depart ADW.
1622- Plane Finder shows E-6B # 163920 (VQ-4 Det PAX)-on approach to PAX.
1624- PAT 2402 (C-12, DAA)-land at DAA
1632- Jumbo 82 (C-5M # 83-1285 9th AS 436th AMW DOV)-land at ADW.
1639- PAT 453-w/ZDC Calvert (133.9)
1643- N405ZH (unid)-land at ADW.
1647- N??1DA (unid)-land at ADW. NOTE: Both N405ZH & N??1DA landed at ADW with very few comms w/PTC or ADW tower. Very quick approaches & landings.
1648- Reach 4131 (C-17A #04-4131 305AMW | 6AS [KWRI)-w/Quantico Ops (355.3) w/inbound msg.
HF: Icom R75
45-ft PAR EF-SWL
mdmonitor
Guys,
Got this article off the Milcom Blog.
With this level of activity you'd think we'd see more reflections of it in our logs. I've only heard the F-35 once that I know of (used callsign Lightening)
If they are moving up to McGuire thi summer hopefully we'll see them move as well as some support activity between KWRI & PAX.
F-35C Test Aircraft Exceeding Test and Evaluation Goals
The U.S. Navy variant of the F-35 Joint Strike Fighter, the F-35C, conducts a test flight over the Chesapeake Bay. Lt. Cmdr. Eric "Magic" Buus flew the F-35C for two hours, checking instruments that will measure structural loads on the airframe during flight maneuvers. The F-35C is distinct from the F-35A and F-35B variants with larger wing surfaces and reinforced landing gear for greater control when operating in the demanding carrier take-off and landing environment. (U.S. Navy photo courtesy Lockheed Martin/Released)
From F-35C Integrated Test Force, Naval Air Systems Command Public Affairs
PATUXENT RIVER, Md. (NNS) -- Naval Air Systems Command announced May 17 that the test aircraft for the carrier variant of the F-35 Joint Strike Fighter is exceeding test and evaluation program goals so far this year.
According to the announcement, the F-35C test aircraft, 'CF-1,' currently at Naval Air Station Patuxent River has completed 36 test flights as of May 11, nearly half the program's goal for the year of 85.
"CF-1's been flying well, even with a number of planned and unplanned maintenance periods," said U.S. Marine Corps Col. Roger Cordell, military site director. "It's a great sign for the fleet that the aircraft is doing well so early in the test program."
In April, CF-1 completed 13 flights, tying a record for the number of test flights for any aircraft at Naval Air Station Patuxent River. Additionally, the integrated test team has completed seven CF-1 test flights this month.
"The team has been doing a great job staying on top of maintenance requirements," said Jim McClendon, Lockheed Martin site director vice president. "Just last week, CF-1 flew six flights in six days, which is a great accomplishment in any test program, let alone test and evaluation for a brand new aircraft."
Coupled with this week's arrival of the second carrier variant, CF-2, and arrival of CF-3 later this year, the F-35C test program is making rapid progress toward initial carrier suitability testing this year at Joint Base Lakehurst-McGuire-Dix in New Jersey.
First carrier suitability testing this summer is scheduled to include the first catapult launches, and the F-35C is scheduled to commence shipboard testing in 2013.
The F-35C is the carrier variant of the F-35 Joint Strike Fighter, with larger wing control surfaces and reinforced landing gear to operate in the maritime environment. The F-35C is undergoing test and evaluation to evaluate flutter, loads and mission systems at NAS Patuxent River prior to eventual delivery to the fleet.
jsoergel
Cincinnati/Dayton, OH
DRAGON 99 inbound to Andrews - overhead KFFO and just called Patterson Dispatch with a relay to home station DSN, "in the green." Interesting note: single UHF radio.
346.300 ZID > 133.775 ZID
freqhopping
Unknown apparent JSOH arrival was AE0943 TURBIN01 landed about 1800.
Logged AE26FA down to 2400ft at 1110.
U-2 80-1083 AE095E looks to have landed at ADW around 1815.
TURBIN 01 is odd one that hangs out on West Coast.Possible C-12 type or UC-12 type?
Will look for it at Andrews Saturday.
AE26FA is listed as CV-22B #05-0029? Again will double check # while there.
Heard DC-41 inbound Andrews after local mission req parking on active ramp
for the airshow. KC-135 #57-1479
NASA 850 F-18A 161703 also into Andrews from Edwards.
Civ Mode s is (ABA885) but like all F18s it doesn't show.
http://flightaware.com/live/flight/NASA850
mdmonitor
Mark,
DC 41 tried to get in this afternoon and was turned away becasue of airshow preps. so he diverted to PAX. Finally made it home
mdmonitor
Logs, 19 May
ZBW-Boston ARTCC
ZNY- New York ARTCC
((Alot of arrivals today for the Joint Service Open House this weekend))
0718- Marine 200 (C20D 163692 VR-1 ADW)-depart ADW
0752- SPAR 11 (C-9C #73-1681 73AS Scott AFB IL)-depart ADW then w/ZDC Calvert (133.9)--w/NAS Chambers VA Ops (268.8) w/inbound msg.
0757- SAM 634 (C37A 97-0401 99th ADW)-depart ADW.
0830- SPAR 29 (C-37A # 01-0029 310th AS, MacDill AFB FL)-land at ADW.Depart ADW at 0940.
0925- PAT 01 (helo)-w/PTC (126.65)
0927- Tester 16 (T-38C # 70-1575, NTPS PAX)-w/BW (270.8) working w/Salty Dog 404 (F-18C # 164869, VX-23 PAX)
0932- Greyhawk 3 (E-2C, VAW-120 NAS Chambers VA)-w/ZDC Salisbury (257.7) at FL170.
0934- SAM 0050 (C-20C # 85-0050, SENEX acft, 99th AS ADW)-depart ADW.
0946- Army 1944 (C-37 # 97-1944, OSACOM ADW)-land at ADW. Depart ADW at 1121.
1025- Navy JT 178 (C-9 #160048, VR-52, WRI)-depart ADW.
1027- HU 702 (UH-3 HC-2 NAS Chambers VA)-land at ADW.
1030- N250PD (AUTOGYRO GMBH, CALIDUS 912 ULS, CSP LEASING LLC, LAUREL, DE)-land at ADW.
1105- DeeCee 41 (KC-135R #57-1479, 756th ARS ADW)-depart ADW. Returns to ADW at 1518.Cannot land due to airshow restrictions so diverts to PAX.
1106- Army 053 (UC-35 # 00-1053 OSACOM ADW)-depart ADW then w/ZDC Calvert (133.9)
1108- DeeCee 91 (KC-135R # 57-1487, 756th ARS ADW)-depart ADW.
1109- Yanky 65 (KC130T 165352 VMGR452 Stewart ANGB NY)-land at ADW.
1110- Reach 30T-land at ADW.
1114- PAT 776-depart ADW.
1118- N713JT (id as Corsair--CHANCE VOUGHT F4U-4--BAMBERG, SC)-land at ADW.
1120- North American 103 (B-757-200 (-land at ADW
1121- Hoist 93 (KC-10A 2/32nd ARS, Joint Base-McGuire-Dix-Lakehurst NJ (KWRI))-land at ADW.
1122- N213YS flt (2 X helos--AGUSTA AEROSPACE CORP, AW139, AGUSTA AEROSPACE CORP, PHILADELPHIA, PA)-land at ADW.
1123- N395DC & N??3LT-land at ADW.
1126- CAP 1822 (Cessna 182, Civil Air Patrol)-land at ADW.
1129- N405MA (DIAMOND DA 40 HIGH WAYS LLC) & N?85TP-land at ADW.
1137- Plane Finder shows E-6B # 163920 (VQ-4 Det PAX) at FL260 northeast of Richmond VA.
1139- Cougar 92 (C-21A # 84-0077 457th AS ADW)-land at ADW.
1144- Demo 1 (unid)-land at ADW.
1227- Navy 6E172 (unid)-land at ADW
1235- ??? 692 (id as T-34)-land at ADW.
1237- N51HY (P-51D Mustang--RANCHO LINDA VISTA LLC, MAXWELTON, WV)-land at ADW.
1245- Cougar 69 (C-21A, 457th AS ADW)-depart ADW.
1335- N382RP (id as experimental--MX AIRCRAFT LLC, MXS GREG POE AIRSHOWS INC,MERIDIAN, ID)-land at ADW.
1449- Tester 14 (T-38C # 57-4943, NTPS PAX)-w/BW (270.8)
1500- Devil 11 Flt (F-16s, 119th FS NJ ANG ACY)-w/ZDC Woodstowne (363.0) then ZDC Kenton (354.15). Also w/Devil Ops (261.0)
1503 Tester 10 (T-38C # 15-8198 NTPS PAX) & Tester 11 (T-38C # 68-8158 NTPS PAX)-w/BW (270.8)
1510- Maple 81 flt (F-16s, VT ANG Burlington VT)-w/ZDC Snow Hill (236.825)
1527- Reach 7042 (C-5B #87-0042 60AMW | 22AS Travis AFB CA)-calling Huntress & Oakgrove (364.2)
1528- Plane Finder shows E-6B # 163920 just southwest of PAX on approach for landing.
1551- Acft 277 flt (id as flt of 3)-land at ADW.
1556- Tester 15 (T-38C # 61-4586, NTPS PAX)-w/BW (270.8)
1605- Sabre 11 (unid helo)-w.Wash Helo (134.35) then QSY to ADW (118.4)--advises ADW that they are with the airshow.
1614- Omaha 5 ( US Customs AB139 N139HS)-w/Wash Helo (134.35)
1656- N14MW flt (2 X PIPER PA-34-220T PITTS S2B LLC, SALINAS, CA)- land at ADW.
HF: Icom R75
45-ft PAR EF-SWL
Tech792
Central NJ
05/19/11
1701 local- JENA 249 landing Lakehurst NAS 127.775
1755 local- MAPLE 81 @ FL260 254.3
1813 local- JOSA 74 calling POLO OPS on 349.7, IDed as a C-21
freqhopping
Good job catching all the arrivals.
That 85TP is N85TP a Harmon Rocket from KHEF.
N51HY is mode-s equipped
3LT could've been N103LT North American SNJ-4
Today I logged N102JK John Klatts EA300/L at 1025.
Right now T-28B N281CM is airborne at 7k ft.
1625- TOPHAT1 flight 254.35>291.625> 360.7. Luke AFB F-16s?
Heading Baltimore, then direct Linden. Out of Martin State?
1630- To ZDC Hagerstown 227.125 at FL230. Sounds like at least three.
1633- to Linden 322.55 at FL260. Haven't found a VHF A>A freq.
1638- to 371.9
1643- Finally IDed as flight of three.
mdmonitor
Another C-27J?
Guys,
1600EDT- Crab 17 (C-27J # # 09-27017, 135th AS MD ANG MTN)-w/ZDC Calvert (133.9)--maybe the second C-27J for the 135th? Any confirmation on an SBS box?
