Sticky Thread for MilAir
lburke19
TinEar said:
NOTE: Anyone know which AR track the 266.4 freq is primary for? It doesn't belong to any of those tracks that were posted the other day by freqhopping. If no one knows, I'll look it up later when time allows in the FAA data supplements..
266.4 was the Kiwi Refueling Track, which was/is located near Cherry Point. When I monitored the military heavily, I heard it regularly from Tidewater Virginia. It never showed up on any refueling track lists. I can't recall how we stumbled across it, but an ATC controller confirmed it.
Mateo
The Dee Sea
TinEar said:
0012: (So, wherever HUNTRESS is broadcasting from, he can't hear BLACKJACK so he's not that close to him. YOu would think that if HUNTRESS is transmitting out of Andrews, he'd be able to hear DCA ground based aircraft. Davidsonville maybe?)
For what it's worth, from Gravelly Point (which is 1000' from the threshold of DCA rwy 19, and about 1.3mi N of the Customs ramp at DCA), you can't hear ground comms from ADW, since there's a ridge in the way.
CitationJet
Northern Virginia
Re: HUNTRESS QTH
Hi Tin,
I'll go back through the forum and have a look for specifics, but I recall that on some of my first CAP catches, I could hear the controller side when in far Western FFX County and Centreville, so my guesses would be the Falls Church PAL remote in Merrifield, or Potomac TRACON at Vint Hill, at least for some of the frequencies in use - 228.9/260.9 if I remember correctly.
Right, out the door now with PRO-2055 in tow...
Best regards,
Tony
TinEar said:
0012: BRAVE 61 relays for BLACKJACK 01 that he's on the deck at DCA. «139.7» BLACKJACK relays also that he's done for the evening due to fuel. (lack thereof) (So, wherever HUNTRESS is broadcasting from, he can't hear BLACKJACK so he's not that close to him. YOu would think that if HUNTRESS is transmitting out of Andrews, he'd be able to hear DCA ground based aircraft. Davidsonville maybe?)
TinEar
Glen Burnie, Maryland
Thanks very much for that piece of info. It's appreciated.
It's worth a lot. Thank you. That certainly explains why an antenna at ADW can't hear ground transmissions from DCA or vice versa.
Appreciate that Tony. One of the problems is that HUNTRESS can apparently transmit from a variety of antennas/locations. I've heard him on one of the CAP freqs - 228.9 or 260.9 - talk to one aircraft and sound like he's in my back yard and then talk to another and be completely inaudible. When the CAP or scramble involves Andrews F-16s, he seems to transmit from an antenna that services the immediate Andrews area. However, your suggested locations could also be right on the mark and probably are. That sure was an unexpected and interesting scramble last night even if some of the suspense was taken out of it by having HUNTRESS announce the exercise at the start. Usually, we at least get to think it's a real intruder scramble for a little while before realizing it's an exercise. One of the neat things was hearing HUNTRESS talking to BRAVE 61 while he was still on the ground pre-takeoff.
Late in the 1200 hour I'm hearing helicopters all over the place heading for the Havre De Grace area - at least two Troopers and various news helos. As one of the news helos said, "A train and car met and the train won." Enough said.
1308: Dave, if you're reading.......hearing A-10s with Philly App/Dep....probably Willow Grove based and might be headed out your way.
1310: Nevermind Dave...it is A-10s from Willow Grove, callsign FLYER, but they've switched to Bollen Range controller BALKY on 237.2. Maybe in your direction when they finish here. FLYER is asking BALKY for the ground FAC callsign...he repeats it but I can't understand it because he's mocking it.
1329: PACK 11 (KC-135R, 133d ARS, Pease ANGB NH) calling FURY Ops (VA-ANG Richmond Command Post) on «289.3» to announce he's on time for the refueling operation with TBOLT 31-34 at 1800Z. He wants to know the status of that flight. Answer is that "they're in the green." (TBOLT=F-16 VA-ANG Richmond)
1339: PACK 11 to Giant Killer on «238.1» for a radio check. Establishes comms and will stand by.
1341: PACK 11 descending from FL 360 to 240. «238.1»
1343: U/I fighter flight on tac «138.45»
1343-48: HARCAR 21 flight with ZDC-Calvert «281.4» climbing from 16000 to 26000....later sent to 325.625 where he calls Washington Center with no joy...back to 281.4 where he learns it should have been 235.625 (ZDC-Blackstone) so goes there and checks in. (A bit of audio dyslexia on his part. Is there such a thing?)
1345: PACK 11 sent to «249.8» by Giant Killer and checks in there.
1349: REACH 9012 arrival msg to Dover CP «349.4» IDs as a C-5.
1350: TBOLT 31 flight off the deck at Richmond and with Norfolk TRACON «370.925» for climbout.
1352: TBOLT flight using tac «141.875»...one of them says he's going to check on PACK 11.
1352: TBOLT to Giant Killer on «249.8» to say the flight is 15 minutes out and wants to know status of PACK 11. Told he's already established in AR-636...goes back to tac and repeats that info.
1355: TBOLT flight passing over their favorite golf course and discuss its merits. «141.875»
1356: TBOLT flight handed off from Norfolk to Giant Killer on «249.8» where all four jets check in and say they're headed for AR-636 to refuel and then over to area W-386 for their work. It's mission V-2112 today.
1401: PACK 11 calling TBOLT on AR-636 primary freq «238.9» (Taking bets on whether they answer up on this freq.)
1404: I lose....TBOLT 1-2-3-4 all check in on «238.9» but then I hear nothing further from them or PACK. (A few minutes later I hear a couple of broken transmissions but that was it. Not sure what flight level they went to for the refueling op but it must have been low.)
1407: Leesburg Radio on FSS «255.4» makes an announcement to "All Aircraft" warning of hazardous weather and advising them to check with Flight Watch on 122.0.
1410: BICEP 11 flight (F-16 NJ-ANG Atlantic City) going airborne and climbing with Atlantic City Approach «327.125» Their tac freq is «138.425»
1415: BICEP 11 to Giant Killer «238.1» and are apparently sent to «350.0» where they try to check in but have no joy with GK. Back to «249.8» this time where they check in as mission V-2105, flight of three. They are told to do their work on 312.3 but request 238.1 instead and get it. The flight changes to 238.1 to do their thing.
1423: BICEP flight working with HUNTRESS on «138.425» and on «238.1» but believe it's simulated only.
1432: Have a couple of F-16 sounding fighters chatting on tac freq «138.9»
1434: DUKE 11, flight of two (F-16, 178th FS ND-ANG Fargo or T-38s from Vance) with ZNY-Middletown «322.4» checks in at FL 250...then to 240....then to 140. (Might be the same guys on 138.9.) (The DUKE flight got handed off and I missed the freq...sounded like 305.65 but I heard nothing there.
1439: It isn't...flight from 138.9 goes to ZNY-Middletown «322.4» and checks in at FL 150 and descending to 9000...callsign sounded like STING 21. He sends his wingman to 118.8 to pick up the ATIS report (Okay, which airport uses 118.8 for ATIS?)
1440: TBOLT flight on tac 139.625.
1444: Fighter pair on «138.9» gets louder and louder...certainly coming to this general area.
1444: PACK 11, TBOLT 31 and BICEP 11 all check in with Giant Killer on «249.8» and begin leaving the work area.
1445: BICEP 11 flight handed off to ZDC-Casino «285.4» where they announce heading for Atlantic City.
1448: BICEP 11 flight to ACY App «327.125» for initial approach and full stop landing at ACY.
1450: Have had a U/I flight with ZDC-Hagerstown «227.125» and then handed off to ZNY-Harrisburg «270.3» but can't, for the life of me, make out his callsign. Has that sort of B-52 muffled sound.
1450: DUKE 11 with Philadelphia Approach «291.7» checks in as a flight of two.
1452: DUKE 11 down to 4000 feet and fading fast....going into Willow Grove maybe. «291.7»
1452: BICEP 12 to Command Post «261.0» Says 11 and 13 are together about 10 minutes behind him.
1455: The Hagerstown-Harrisburg guy is now handed off to ZNY-Philipsburg «306.2». Still can't get his callsign. He's at FL 270.
1457: He's next handed off to ZNY-Milton «269.1» and now his callsign sounds like TALON 44. If so, there are many choices for that callsign so can't ID him.
1458: TBOLT 31 out of GK's area and going to RTB. East of HEELS and direct Richmond. «249.8»
1503: TBOLT 31 flight with Norfolk TRACON (East) «370.925» as they approach Richmond
1504: ?TALON 44? handed off to ZNY-Elmira «298.9» where he checks in at FL 270
1505: TBOLT flight with Command Post on «289.3» to announce all jets Code 1
1506: TBOLT 31 flight with Norfolk TRACON (West) «360.6» check in as flight of four at 12,000 feet.
1507: And it's time for me to move on. Back later.
dparana
Ref Above....
Tin,
118.80 is the ATIS for Harrisburg. That flight on 138.90 has been flying around up here getting switched from freq to freq. The mentioned earlier about flying the VR-705 training route and then landing in Harrisburg. I got most of this info from my scanner recorder, I was out of the office all day.
I could have sworn the callsign they were using was STINK 21 but it was probably STING 21.
Dave
TinEar
Much appreciated Dave. STINK/STING were almost certainly F-16s from the transmitter sound and the fact they used a VHF tac freq. Of coure, they could have been A-10s based on that but the sound was more F-16 like. I think the DUKE 11 flight went the same place. I guessed Willow Grove but it could just as easily have been Harrisburg.
Alan
freqhopping
Lo Co VA/ FM19
When I went to Iraq I left Cherry Point in a C-5. It wasn't too long after take off that we were told that we would be doing some midair refueling. I wonder if this is that track.
A couple noted today here....
1018 am ZAPPER 21 flt of 2 F-18's VFA-81 with Philly appch 291.700 dropping
into Willow Grove NAS
1643 VADER 06 C-130 calling Dover CP 349.400 no joy arriving there.
Maryland
Mateo
The Dee Sea
Wish I could have seen more of these from Gravelly Point - very thick haze today.
1709: -118.4 (ADW Tower)- SAM42 landing
1729: -119.85 (Potomac Approach)- DOLL 325 (C-130 seen - should be 80-0325 GA ANG) being vectored for ADW arrival. To -119.3 (Potomac Approach- and -118.4-. Arrived 1742
1752: -118.95 (Potomac Departure)- REACH 18 departing ADW, direct LDN
1754: -118.4- AIR FORCE 2 (C-32 seen) landing
1810: -118.4- MARINE 009 landing
1836: -119.85- JOSA 507 vectored for ADW arrival
1841: -279.57- DRAGO 51 is holding at the IP for 1858. Wants to know if he can use this as the tactical [1858 is a little late for Arlington, but makes sense for a 1905 first pitch. Hmm...]
1847: -349.4 (calling McGuire CP)- JEEK 62 'on the diversion' expects to block in at 2320z. He's A-1, cancelling his ERO, and offloading 2 pallets.
1853: -119.85- JOSA 862 vectors for ADW arrival
1856: -119.85- "There's a fly-by at RFK, you'll number 2 for arrival." [Yup, for the baseball game]
1856: -279.57- DRAGO 51 "We're early. Somebody let me know when the target area's captured."
1901: -349.0 (ADW Tower)- DRAGO 51 gear in transit, cleared to land 19R. DRAGO 52, 53, and 54 all check in with gear down. [DC ANG F-16s, perhaps?]
1907: -118.4- JOSA xxx landing
1910: -349.0- "580 on Uniform"
1913: -118.95- REACH 3119 (C-17A 03-3119 MS ANG), climb 17K. To 121.67
1915: -118.95- REACH 332T (prob C-17), turns to 270/300/340/360/330. To 123.82
--and now from home, listening very passively--
2156: REACH 345T being vectored for ADW
CitationJet
Northern Virginia
Up late programming the PRO-2055...
0141Z 378.100 GRIFFIN CP Andrews - REACH 345T (C-17 presumed) - ETA top of the hour, 30 pax req. parking, A1.
0148Z 119.850 Potomac APP - REACH 345T () - dir ELDEE for the ILS to 19R @ ADW.
0156Z 119.850 UA flight asking what a/c type they were following (REACH 345T) - "no wonder we got bumped pretty good! 15 degree wing rollover experienced..."
0313Z 118.675 Potomac APP (late night combined) - SAM 0461 () - out of ELDEE 050 vectoring for the app to ADW.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Tony, you don't need to program by hand! If you get the proper cable and Win97, several of us here can send you files you can use. Even ARC250 files could be used - they're nothing more than reformatted .csv files that could be renamed and modified to fit your needs. And of course, you can download directly from the RRDB.
73s Mike
CitationJet
Northern Virginia
Re: programming the PRO-2055
Hi Mike,
Thank you very much for the offer, and I know this is going to sound bizarre, but I actually ENJOY programming each frequency in by hand. Besides, it actually didn't take that long and was thoroughly enjoyable! :cool:
It's a throwback to my earliest days with VHF radios and to my first Realistic models...:cool:
Best regards,
Tony
73s Mike
bigred10
PA
FLACK flight of 4 arrived at Willow Grove this morning (1100-1130 local). I didn't pick them up until they were on Philly approach <291.7> and then Willow Grove GCA <266.8><299.6><314.8><325.2>.
I am not able to find a reference for the FLACK callsign. I'm pretty sure I heard it correctly. Any ideas? I'm going to take a drive by the base in a little bit and maybe I'll see something.
TinEar
Nothing here on the FLACK callsign either.
Glad to hear that Tony. C'mon over and program my new 996 with the 6000 or so freqs it'll take since I haven't learned the programming technique yet. This is like torture to have that great new scanner and not be able to use it yet while I read the 1000 page manual in an attempt to learn programming a dynamic loaded scanner and the 1000 page manual for ARC996 programming software. Okay, so I exaggerate the number of pages...but it seems like that many.
1408: BICEP 11 (F-16 NJ-ANG Atlantic City), flight of three, on tac freq «138.425» and then calling Giant Killer on «238.1/350.0/249.8». They finally made contact on that last freq and announced they were on mission V-2204 in area W-386, work areas A-F, from 5,000 to 35,000 feet. There was no mention of refueling as they did yesterday when they went to this area. By 1420, it seems their ops are confined to the tac «138.425» freq.
TinEar
Just so the info won't get lost in a cross thread posting...
Jim (Airfire) posted a message to the Military Monitoring Forum, FAA ATA-100 Data Discussion thread that tips us to yet another new UHF ZDC freq. It's a replacement for the 387.1 freq at Sector 1 Elkins and is 226.675. It sure is nice to get that info before we find the new freq and tear out our hair trying to ID it. It's still paired with the 126.8 VHF freq.
EricCottrell
Boston, Ma
Hello,
NY Center has updated the letter to Airmen listing the sectors and frequencies.
http://web.nbaa.org/public/ops/airspace/ZNY_LTA0601.pdf
There was also some realignment and several new sectors for the Cleveland and Indianapolis centers bordering ZDC. See pages 7, 8, and 9.
http://www.fly.faa.gov/tfmlearning/files/MASE_System_Change_Overview.pdf
Maybe it explains some of the changes over the past month or so.
I am going to be over near Dulles Airport this friday and saturday and possibly in Hagerstown the next friday. Looking forward to listening to some good MilAir.
73 Eric
TinEar
Nice catches Eric. ZNY is about the only center that releases those Letters to Airmen on a somewhat regular basis - at least that I've seen. I note they have neither of the two newest UHF freqs I've discovered in the past week - 285.65 and 292.15.
Based on their Sector chart, it looks like 285.65 could be a replacement for the Hyper Sector 11 322.5 freq. An aircraft was handed off from ZNY-Lancaster to 285.65 and then to ZNY-Modena which makes that one look pretty good. The 292.15 freq had a handoff from ZNY-Kennedy 282.3 but nothing heard after that to be able to fill in the middle Sector.
EricCottrell
Boston, Ma
n3bxv said:
Hey Alan,
Boston Center also recently published an LTA with freqs http://web.nbaa.org/public/ops/airspace/ZBW_LTA0602.pdf
Hello,
I saw that as well but considered it off-topic as ZBW is not adjacent to ZDC.
Yesterday while tuning around I picked up some aircraft traffic on 133.125. I thought it was a NY departure frequency but after listening for a while I heard calls to Washington Center. Checking the list I see it is the Sea Isle High sector.
73 Eric
