Some limited success.
All that I could get was garbled garbage until I took the -g gain setting right out of the command line. That enables AGC and that got rid of the garbage.
Now it is understandable but the audio is choppy, like in a poor reception area. I am not in a poor reception area, get a very strong signal. I have tried adjusting the -l squelch setting but it doesn't seem to make a difference.
Here is the link to the feed:
Franklin County Fire and EMS Dispatch 1
Don't expect a lot of activity.
Ok, Jack, I am back home and back at it again. This morning I seem to have found a somewhat sweeter spot. I have set up the rtl-sdr stick on my feed again. Use the link in the above post to access it. See how it compares to your audio. I have some background noise also. Is that similar to what you were experiencing?
Here is the command that starts it:
~ $ sudo /usr/local/bin/rtl_fm -d 0 -M fm -f 460.400M -p 54 -g 49.6 -l 60 -t 2 -s 12k -E pad | /usr/bin/lame -r -s 12 --resample 22.05 -m m -b 16 --cbr --lowpass 4 - - | ezstream -c /etc/ezstream_bcfy.xml
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
ezstream: Connected to http://audio1.broadcastify.com:80/136987518
ezstream: Streaming from standard input
Found Rafael Micro R820T tuner
Tuner gain set to 49.60 dB.
Tuner error set to 54 ppm.
Tuned to 460463000 Hz.
Oversampling input by: 21x.
Oversampling output by: 1x.
Buffer size: 32.51ms
Exact sample rate is: 252000.000300 Hz
Sampling at 252000 S/s.
Output at 12000 Hz.
