American Electric Power (AEP) P25 WACN 92715
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I wonder if 1F5 Site 47 is Muncie (Delaware county) Callsign: WPCQ247. It's either very low profile, or not online. A few of those frequencies came up as DMR freqs on UT. WPCQ247 and WQHT567 are not very far away from each other geographically.
It is odd though that mjdewey reported Site 47 online with CC Of 854.2125 but some neighboring sites 45 and 48 do not report it as a neighbor. We do not have a peer list for Bryant yet, so I'm not sure if it shows the peer online or not. Maybe it's in a state of being brought online and was shut of sometime between the time mjdewey caught it and now.
west-pac
Unknown TGs observed on 1F5 site 45: TG1205 & TG1222. UT has ran for almost 24 hours and this one radio changing channels 20 minutes ago has been the only traffic on this site.
ralexander5
Mathis, Tx
I'm picking up a site 87 on System 1F8 from South Texas. CC of 855.3375. Possibly Corpus Christi site but other frequencies don't match license (855.6375, 856.7875, 857.7875, 858.7875). No peers reported and no activity yet
mtindor
FMP24 PRO USER
So to be clear, you are picking up:
1F8-87.87
855.3375 cc
855.6375 ac
856.7875 ac
857.7875 ac
858.7875 ac
Is that right? Are you sure about the 855.6375?
I wonder if you could be pulling in a distant site via tropo?
Texas is one of the areas where AEP has a large number of licenses with a large number of frequencies attached to a site. Makes it very difficult to pin down sites based upon FCC data. They are trimming that down with updates to FCC records that they have been doing, but there are still a ton of licenses with 50-60 frequencies on a site.
What I would suggest is that in whatever program you are using to copy that site, delete all information for 1F8 and start brand new. If you still get the same results, then the results are right. But I am just suggesting this to make sure there haven't been any channels picked up other sites inadvertently because of switching between control channels of different sites.
Then, I suppose the next thing I would do is make note of whether I can pick it up 100% of the time, day/night. Or if it's weak/strong constantly. You want to figure out if it's a site far away that you are pulling in via tropo, or a closer site that can be copied 24/7 regardless of atmospheric conditions.
Mike
Mike
firemantom26
Wintersville Ohio
Mike, it’s great to see some folks from Texas chiming in. We pretty much got Ohio covered with an exception of a few. I am happy to see more folks posting here on the forum with more confirmed sites.
west-pac
Mike,
Is there a better place to post unknown TGs seen on these systems?
Also, 1F5 site 45 is now showing site 47 as a peer.
west-pac
Mike,
1F5 site 42 shows 47 as a neighbor as well. As you said earlier, 47 may have been in a testing phase when it was first discovered. Maybe that's why it wasn't showing as peers/neighbors on the other sites over the past week.
mtindor
FMP24 PRO USER
Mike,
What is Site 42 showing as the current control channel for Site 47 ?
As for unknown talkgroups, navigate to the AEP system in the RRDB, then click on "Wiki" at the top right, then click on the section for INdiana-MIchigan Power 1F5. On that page you can enter in unknown talkgroups that you have them documented, if you want. That's the only place I know of to post them. I have already put the two that you talked about yesterday in the wiki.
Mike
ralexander5
Mathis, Tx
1F8-87.87
855.3375 cc
855.6375 ac
856.7875 ac
857.7875 ac
858.7875 ac
Signal is somewhat weaker this morning but all channels reappeared as above. Don't believe it is skip as not getting anything else outside of about 50 miles. Will check north and south of here over next few days and see if can locate.
mtindor
FMP24 PRO USER
I know that up here in Ohio, when some new sites came online, I had seen some with frequenciees that weren't associated with the site. But once the site went "live" to where it was broadcasting peers and had talkgroup traffic, they had eventually switched the frequencies to the ones on the license.
And in Ohio, even after the sites went live, oftentimes the new P25 replacement site would broadcast the Alt CCs as part of the P25 system when they were, in fact, still in use as EDACS channels before the corresponding EDACS site was decomissioned.
So maybe it's just a matter of time before characteristics of Site 87 change on their own, as AEP does testing.
Mike
west-pac
Mike
Mike,
Site 42 shows the current CC for site 47 as 854.2125. Also, of note, the current CC for site 42 has rotated to 855.4125.
Just now TG 1222 was active on Site 42. It popped up a Voice Channel on UT of 854.1875 LCN 08-510. That same frequency, but with LCN 00-255 is also an ACC for site 42. Why/How would the ACC and Voice Channel be the same frequency, but different LCNs?
mtindor
FMP24 PRO USER
Mike,
it is a phase 2P 25 system. Talk group surveys to TDMA. So voice activity is going to be with a different LCM prefix
west-pac
Ok.
I'll submit additional 1F5 site 44, and 47 data in a few minutes.
mtindor
FMP24 PRO USER
Ok.
OK sounds good. Sorry about that last post. I’m dictating into my phone rather than typing, and the phone isn’t doing a very good job
i meant to say that since it is a Phase Ii P25 system, the talkgroups are TDMA. Each voice channel supports two simultaneous voice calls. You will see LCN 8-#### on voice channels.
mike
mtindor
FMP24 PRO USER
IN is looking very nice thanks to the guys up there.
OK is coming along quite nicely as well
Additional new neighbors for 1F9-10.10 (Leonard OK) were submitted today
- 856.9125 ( 1F9-7.7 ) - Most likely Tulsa OK (Tulsa), much less likely Grove OK (Delaware)
- 854.4625 ( 1F9-49.49 ) - Stigler OK (Haskell)
OK 1F9 Wiki
IN-MI 1F5 Wiki
RakkFO
Central ohio
Site: 89.89 NAC=059
Neighbor: 92715.1F6-27.27 ; Mount Vernon (Knox)
Neighbor: 92715.1F6-32.32 ; Dresden (Muskingum)
Neighbor: 92715.1F6-33.33 ; Etna (Licking)
Neighbor: 92715.1F6-35.35 ; Newark (Licking)
Neighbor: 92715.1F6-43.43 ; Columbus (Franklin)
Neighbor: 92715.1F6-44.44 ; Johnstown (Licking)
Neighbor: 92715.1F6-45.45 ; Powell (Delaware)
Neighbor: 92715.1F6-46.46 ; Leonardsburg (Delaware)
Neighbor: 92715.1F6-47.47 ; Mt Sterling (Pickaway)
Neighbor: 92715.1F6-91.91 ; Utica (knox)
Channel 0-257: 854.2125 CC
Channel 0-271: 854.3875 SCC
Channel 0-365: 855.5625 SCC
Channel 0-455: 856.6875 SCC
Channel 0-491: 857.1375 SCC
Channel 0-615: 858.6875 SCC
2020/08/19 23:07:44 DSD+ 2.256 / Fast Lane Release
2020/08/19 23:07:44 P25 data loaded; 2 networks, 72 sites, 186 channels
2020/08/19 23:07:45 Fusion decoding enabled
2020/08/19 23:07:45 D-STAR decoding enabled
2020/08/19 23:07:45 NXDN4800 decoding enabled
2020/08/19 23:07:45 NXDN9600 decoding enabled
2020/08/19 23:07:45 DMR/MotoTRBO decoding enabled
2020/08/19 23:07:45 P25 Phase 1 and Phase 2 decoding enabled
2020/08/19 23:07:45 X2-TDMA decoding enabled
2020/08/19 23:07:45 ProVoice decoding enabled
2020/08/19 23:07:45 Checking for updates
2020/08/19 23:07:45 TCP link established
2020/08/19 23:07:46 You are running the most recent copy of DSD+
2020/08/19 23:08:53 854.2125 22.3 km 321 deg American Electric Power Service 8081 Harlem Road/Westerville/FRANKLIN 8K10F1E 19K0D1W
2020/08/19 23:08:54 Current site: 89.89
2020/08/19 23:08:55 Current network: 92715.1F6 American Electric Power (P25)
2020/08/19 23:08:55 Current site: 92715.1F6-89.89
2020/08/19 23:08:56 92715.1F6-89.89 neighbor: Site 92715.1F6-33.33; CC=0-351 855.3875 Etna (Licking)
2020/08/19 23:08:56 92715.1F6-89.89 neighbor: Site 92715.1F6-35.35; CC=0-241 854.0125 Newark (Licking)
2020/08/19 23:08:57 92715.1F6-89.89 neighbor: Site 92715.1F6-43.43; CC=0-373 855.6625 Columbus (Franklin)
2020/08/19 23:08:57 92715.1F6-89.89 neighbor: Site 92715.1F6-44.44; CC=0-313 854.9125 Johnstown (Licking)
2020/08/19 23:08:58 92715.1F6-89.89 neighbor: Site 92715.1F6-45.45; CC=0-353 855.4125 Powell (Delaware)
2020/08/19 23:08:58 92715.1F6-89.89 neighbor: Site 92715.1F6-46.46; CC=0-297 854.7125 Leonardsburg (Delaware)
2020/08/19 23:08:59 92715.1F6-89.89 neighbor: Site 92715.1F6-47.47; CC=0-281 854.5125 Mt Sterling (Pickaway)
2020/08/19 23:08:59 92715.1F6-89.89 neighbor: Site 92715.1F6-91.91; CC=0-549 857.8625 Utica (knox)
2020/08/19 23:09:00 92715.1F6-89.89 neighbor: Site 92715.1F6-27.27; CC=0-385 855.8125 Mount Vernon (Knox)
2020/08/19 23:09:00 92715.1F6-89.89 neighbor: Site 92715.1F6-32.32; CC=0-427 856.3375 Dresden (Muskingum)
mtindor
FMP24 PRO USER
Site: 89.89 NAC=059
Man you are a brutal sleuther! I'll get it added :) This is the Westerville OH site (Rakkfo knows that -- just stating it for others).
Mike
mtindor
FMP24 PRO USER
It was all you, all I did was turn on the airspy!
It's like talkgroups vs sites. Talkgroups are useless without sites. Similarly, you can't find a site if there is nobody there willing and able to sniff it out.
Thanks again!
M
RakkFO
Central ohio
Thanks again!
M
Well I have been focused on sites. I can set up a SDR to start targeting TG's but I am not as good as listening to recordings. What helps you map the TG'S?
